RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 1st Nov 2007, 14:44   #1
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
Mozilla introduces a new way to work
http://www.bit-tech.net/news/2007/11..._way_to_work/1
Mozilla Labs has released software that integrates web applications into the desktop, allowing instance-specific control of particular web functions.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 1st Nov 2007, 15:08   #2
will.
A motorbike of jealousy!
will.'s Avatar
will. will become famous soon enoughwill. will become famous soon enough
Sounds cool. Now why can't Microsoft do this:
Originally Posted by the article
It conforms to all of the current standards in web protocol
__________________
work | play | blog
PS3 & 360: willblack
Flickr my twitter. Last.FM
Check out my Last.FM & iToggle & Nav-o-Matic jQuery plugins.
will. is offline   Reply With Quote
Old 1st Nov 2007, 15:25   #3
Bluephoenix
Spoon? What spoon?
Bluephoenix's Avatar
Bluephoenix is on a distinguished road
but.... but... what about my extensions!!!!!!
ok drama over.
I think this is a great tool for Presentations that involve the web, but for general use nothing beats firefox and its extensibility
agreed, though IE7 has come a long way from 6, it isn't there yet
Bluephoenix is offline   Reply With Quote
Old 1st Nov 2007, 15:36   #4
Anakha
Supermodder
Anakha's Avatar
Anakha is on a distinguished road
I would say that MS has had this for a LONG time (Since IE5.5), in the form of HTAs. That doesn't mean I prefer HTAs over Prism, however. I've been using Prism for a couple of weeks now (It's great for GMail), and have had no problems with it so far.
__________________
Robert "Anakha" Johnston
Going to Canada on Nov 28th! I'm going home!
Anakha is offline   Reply With Quote
Old 1st Nov 2007, 15:41   #5
Jamie
bit-tech Staff
Jamie's Avatar
Jamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of light
Doesn't seem to work on my Mac :/
__________________
bit-tech hosted by tsohost.co.uk
twitter | flickr | xbox live | last.fm | moot
Jamie is offline   Reply With Quote
Old 1st Nov 2007, 15:45   #6
BioSniper
I Mod, Therefore I Own
BioSniper's Avatar
BioSniper has a spectacular aura aboutBioSniper has a spectacular aura about
I've given it a go and I still don't quite understand the point of it all when a regular browser works just fine.
I guess it really isn't aimed at the home user anyway but it doesn't even appear to have tabs so its kinda weird, it just means having loads of instances of the app open surely?
__________________
My Flickr :: Bit-tech Flickr
Wii: 1792 1527 2926 7945 :: Xbox Live: BioSnipr :: PSN: Biosnipr
BioSniper is offline   Reply With Quote
Old 1st Nov 2007, 15:48   #7
will.
will.'s Avatar
ok drama over.
Actually, I had the new outlook in my mind when writing that. Microsoft made the clever decision to use the word rendering engine to display html emails. Lazy b******'s
__________________
work | play | blog
Old 1st Nov 2007, 16:05   #8
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
Okay, after reading the summary, I'm still not really sure how this is different from disabling tabs and using the F11 mode. Sounds very 2002-ish.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 1st Nov 2007, 16:38   #9
DeX
Mube Codder
DeX's Avatar
DeX is on a distinguished road
There's more info (including screenshots) here: http://labs.mozilla.com/2007/10/prism/
But as far as I can make out, all it is is a separate Firefox window with no buttons or menus for each individual website that you happen to use often. How is this different to an IE6 window with menus and toolbars disabled?
__________________
Play my game: Shyguy's Cave of Death!
If you dont have the time to check your spelling and grammar, you dont have the time to post! -Liquid K9
DeX is offline   Reply With Quote
Old 1st Nov 2007, 16:53   #10
TheEclypse
Supermodder
TheEclypse is on a distinguished road
Running Leopard?
__________________
Current Rig: Shuttle ST20G5 | AMD Athlon64 4000+ San Diego | X1950Pro | 200Gb Samsung SpinPoint P120S SATA | 1GB OCZ Performance | NEC ND3540A | 7-in-1 Floppy
TheEclypse is offline   Reply With Quote
Old 1st Nov 2007, 17:01   #11
The Chugnut
Minimodder
The Chugnut's Avatar
The Chugnut is on a distinguished road
Running Leopard?
:O
Drama!
The Chugnut is offline   Reply With Quote
Old 1st Nov 2007, 17:20   #12
GoodBytes
mother into a board?!
GoodBytes's Avatar
GoodBytes is a name known to allGoodBytes is a name known to allGoodBytes is a name known to allGoodBytes is a name known to allGoodBytes is a name known to allGoodBytes is a name known to all
You can just do F11 in Firefox and you get the same thing... or you can simply remove all the bars....I don't get it...
Beside there is no address bar... I don't want to make scripts to make it go on every web site I want...
This is a joke...
__________________
AMD Athlon 64 X2 4400+ S939 | 3GB of Corsair/Kingston (mix) RAM @ 400Mhz 3-3-3-8-2T | ASUS A8N32-SLI *Deluxe* | Geforce 260 GTX | X-Fi XtreamMusic | Western Digital 250GB SATA-II 16MB of Buffer | Corsair HX620W | Antec SOLO case | Monitor: 24inch Dell U2410 | Win 7 64-bit Go for Pro!
GoodBytes is offline   Reply With Quote
Old 1st Nov 2007, 19:20   #13
Anakha
Supermodder
Anakha's Avatar
This is a joke...
It's not meant as a web browser. It's meant as an "Application shell" that happens to use web technology.
For instance, I use it to run GMail as a "Desktop" application. You could do the same with Google Docs/Maps.
It's ALSO meant for running, say, corporate intranets, where you don't want/need extra toolbars/plugins/addons/extensions messing around with the security of the data internally (The last thing you want is the Google Toolbar submitting your private intranet links to Google for PageRank analysis).
This would be great for a POS system, say, or a library computer, where "Fullscreening" a browser won't do (Multiple sessions/screens), and also for when you're developing a potentially problematic site (Writing AJAX, with the risk of an infinite loop in there? Run it in prism and you can kill just that app, leaving all the others running just fine).
The "Add/Remove Programs" in every version of Windows from 2000 uses exactly the same thing. It's a HTML Application, run using Microsoft's version of this, MSHTA.
It's a great idea, but really not all that necessary for most people.
__________________
Old 1st Nov 2007, 20:32   #14
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has a spectacular aura aboutCupboard has a spectacular aura about
Isn't this just a shell/box for web apps? if so, it sound great to me, instead of having them all in different tabs of Firefox (why doesn't the Firefox spell check recognise that?!), you can have them in their own window, that instead of having the normal browsing stuff is just a shell that lets them bring their own buttons and stuff. I think it is a major step in bringing web apps more into the mainstream (whether that is a good thing or not is a different question).
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker
Samsung Q45.
Cupboard is offline   Reply With Quote
Old 1st Nov 2007, 21:20   #15
Anakha
Supermodder
Anakha's Avatar
Yup. WebApps, here we come! (Valid XHTML1.1/CSS)
__________________
Old 1st Nov 2007, 23:03   #16
cebla
Multimodder
cebla is on a distinguished road
I don't know why you compare this to Silverlight as it has nothing in common with it.
cebla is offline   Reply With Quote
Old 2nd Nov 2007, 01:21   #17
seanap
Modder
seanap is on a distinguished road
This seems pretty handy, but it uses way to much system resource to really justify having another tab open or such. Right now it's at 42,376K with 2 windows open (one a gMail account, one an outlook express email page). Now to use FireFox to open these same 2 windows it uses 36,572K in comparison. I really like the whole concept and idea behind Prism, but honestly it doesn't quite justify it's own use yet... using 6+ mb more ram than a full on web browser?
Here's to hoping it's memory usage is better in the versions to come, it has quite a potential IMO.
seanap is offline   Reply With Quote
Old 2nd Nov 2007, 06:56   #18
DAE_JA_VOO
Supermodder
DAE_JA_VOO is on a distinguished road
No joy in Lunix either...
DAE_JA_VOO is offline   Reply With Quote
Old 2nd Nov 2007, 08:56   #19
jezmck
____
jezmck's Avatar
jezmck will become famous soon enough
Not looked yet, but this sounds ideal for 85% of the stuff we do where I work (intranet systems).
EDIT: After looking, it seems a little pointless - currently, we create web apps then tell the clients to simply open their web browser, point it to an address, login. That opens a new browser window sans nav buttons, sans 'location bar'. Result - a new chromeless window w/o them having to install anything.
__________________
Have you seen The SketchUp Components Collection's latest items?
Interested in a DXF Blueprints Collection? Discuss it here.
jezmck is offline   Reply With Quote
Old 2nd Nov 2007, 14:24   #20
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul has a spectacular aura aboutBauul has a spectacular aura about
I can see it being useful for something like Google Docs, which is a webpage trying to be a desktop application. But for web pages that are simply web pages there's not real point to using it. It'd be really useful if they integrated it fully into Firefox, so you could for example save a shortcut to a webpage on your desktop, then click a tag in it that says "open as own app" and voila, you have your own desktop app. But for only that, it seems a bit excessive to be an entire program.
__________________
Pentium 4 CPU 3.4 Ghz | 1Gb + 2x512Mb Corsair DDR2 667 Mhz
Sapphire Radeon HD 4770 512Mb| WD Raptor 36Gb, Seagate 300Gb | Asus P5LD2 SE
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
