RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Nov 2007, 13:24   #1
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
Cooler Master debuts ESA Cosmos
http://www.bit-tech.net/news/2007/11...s_esa_cosmos/1
The Enthusiast System Architecture is now upon us with the release of the Cosmos ESA from Cooler Master.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 13th Nov 2007, 17:09   #2
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has a spectacular aura aboutCupboard has a spectacular aura about
I forget if the fans are power by USB as well as controlled by it. If so, that would be quite cool (sorry). It definitely beat running 3 fans of one motherboard header
Nowhere seems to sell it though, do you know how much more it is that the usual one? $229 is cheaper than £140 in the original article, but that is in the US
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker
Samsung Q45.
Cupboard is offline   Reply With Quote
Old 13th Nov 2007, 21:24   #3
Risky
Mod Master
Risky's Avatar
Risky is on a distinguished road
Still the weakness of this is that is will relay on the OS, so in the event of a crash you lose all control. Now a software controllable system outside the primary system is what you really need e.g. something grown out of the t-balancer concept.
__________________
As a rule watercooling can be simple, affordable and effective... I guess I just like to break the rules.
Risky is offline   Reply With Quote
Old 13th Nov 2007, 22:09   #4
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
the ideal would be a second, behind the scenes OS, like some flavor of linux, running on the background out of your way...... and i very much doubt the fans would be powered by USB.....
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is offline   Reply With Quote
Old 13th Nov 2007, 22:46   #5
Cupboard
I'm not a modder.
Cupboard's Avatar
no reasons I can think of why not. If you can power a hard drive/light/fan/drinks cooler from one, why not a couple of case fans?
I don't really know though (hence the question)
__________________
Samsung Q45.
Old 13th Nov 2007, 22:51   #6
completemadness
Hypermodder
completemadness is on a distinguished road
A 80mm case fan is usually about 0.1A (in my experience) - maybe more depending on size/speed, However, that's at 12v
Don't forget, USB is 100mA max (non negotiated) or 500mA (negotiated) but that's at 5v
completemadness is offline   Reply With Quote
Old 13th Nov 2007, 23:31   #7
DXR_13KE
DXR_13KE's Avatar
exactly what i was thinking...
maybe it is powered by the psu, but has a usb connection for speed control and noise control.
__________________
Old 14th Nov 2007, 01:18   #8
completemadness
Hypermodder
I would be very surprised if it wasn't done that way
Old 14th Nov 2007, 03:31   #9
Anakha
Supermodder
Anakha's Avatar
Anakha is on a distinguished road
I think a board like that would operate so when there isn't a negotiated connection with some controlling software, the fans run at 100% (Or use an onboard thermistor, or have some other setting stored in a tiny CMOS chip so you can control how the system starts/runs). That would be the sensible way to do things.
__________________
Robert "Anakha" Johnston
Going to Canada on Nov 28th! I'm going home!
Anakha is offline   Reply With Quote
Old 14th Nov 2007, 04:12   #10
Woodstock
So Say We All
Woodstock's Avatar
Woodstock is on a distinguished road
i think that bit needs to get one as a follow up to the esa article
__________________
Hell hath no fury like a hippo with a machine gun.
Woodstock is offline   Reply With Quote
Old 14th Nov 2007, 08:42   #11
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn is on a distinguished road
wait Im confused dont most motherboard already have the ability to control fans? or at least CPU/SYS/Chassis fans for one and then you can get USB Fan controllers already that can do the same thing so whats the point? If someone could explain a little more that would be great.
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding •
Retired Rig: Project F.E.A.R.
• TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory •
HourBeforeDawn is offline   Reply With Quote
Old 14th Nov 2007, 08:51   #12
HourBeforeDawn
a.k.a KazeModz
oh there was rumor that CM was going to release an all aluminum version of the cosmos around Dec/Jan, could that also be whats different with the ESA Cosmos? as that was the case I was holding out for. ^_^
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
