Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Zalman ZM-MFC2 Multi Fan Controller
http://www.bit-tech.net/hardware/200...n_controller/1
Zalman reinvents the fan controller - transforming it from something boring and unappealing into a sleek, multifunctional panel with a cool looking LCD display. But what if it's all bling and no follow through?
__________________
#2 |
Learning to mod
Too bad...It looks amazing, and I might have bought it if not for that.
__________________
~Asulc~ |
#3 |
The cake is a lie
I were nearly buying this thing once! I'm really happy I didn't...
It sure looks cool and the idea is great but if the LCD panel is that bad it's not worth the money.
__________________
Q9550 @ stock || Asus P5Q Pro || 4x 2GB Corsair XMS2 800MHz CL4 || Radeon 4870 512MB || Asus Xonar DX || 2x WD 640GB || Thermalright Ultra 120 eXtreme || Corsair HX620 || Antec P182 || Windows Server 2008 R2 64-bit |
#4 |
Hypermodder
Damn, I was all set to buy this little beauty, shame its naff. Oh well I guess I'll spluge the £35 on something else then.
| johnnyboy700 |
| View Public Profile |
| Find More Posts by johnnyboy700 |
#5 |
Richard Swinburne
bit-tech Staff
Once they fix it I'll be sure to tell you then
#6 |
What owl?
tbh i'd probably have bought it despite the viewing angle if it had OS level recording. But then i'm a sucker for statistics and graphs.
__________________
No boom today, boom tomorrow... there's always a boom tomorrow. |
| steveo_mcg |
| Find More Posts by steveo_mcg |
#7 |
Pie Eater
whilst it looks great and appeals to the exhbitionist crowd in the computer world, a few years ago a bought the Akasa AK FC-03 Fan Controller Pro and it tells me fan speed, tempartures if i wanted to connect the temp nodes (x4) and has the usual fan failing alarm system etc and in my opinion as a 'practical application' is much better than the zalman one reviewed, plus the 4 knobs make it easier to turn all 4 fans (2x120mm hdd cooling, 1x 120mmcpu cooler, 1x120mm GPU cooler) to max when gaming really quickly and easily, the zalman wouldnt appear to be quicte so quick as control has to be shifted to each fan through one control knob.
As for viewing angle that is resticted slightly as the screen is set back some 5-8mm so the facia gets in the way but there are no magic 8's to be seen at all. IMO the akasa is better for £30, but if you solely want something that looks nicer the zalman is the obvious choice, but for doing what it says on the tin i'd favour the AKASA due to a delightful experience (as much as that is possible with a fan speed controller :P ) @Bit-tech staffing - Might it be worth the bit-tech review possy checking out these one's... http://www.kustompcs.co.uk/acatalog/...ntrollers.html the mCubed T Balancer BigNG ones as i was interested in knowing if they are anygood at all as they can be hidden behind a facia this leaving the front of a pc nice and sleek. And i think i read that they can be used to regulate the water pump on a water cooled system also...interesting, but is the hardware/software combination reliable and/or worth the money, who knows? peace
__________________
Core 2 Quad Q6600 @ 3600Mhz ¦ Asus Maximus II Formula ¦ ATI Radeon 4890 (1000Mhz Core + 1200Mhz Mem OC) ¦ 2x2G Corsair Dom. PC 8500 @ 1080Mhz ¦ Aquacomputer WC ¦ Creative X-Fi Fatal1ty ¦ 150G Raptor, 2x1500 + 1x750 + 2x500 Seagate (SATA2) ¦ Pioneer DVD burner ¦ Lian Li - PC 73SL Aluminium Silent Server Case ¦ Dell 2007WFP 20" Widescreen ¦ Logitech Z-5500 5.1 Speakers ¦ Sennheiser HD270
#8 |
Ultramodder
I found that only the cheap fan controllers actually work. After trying out one of those piece of crap ultra fan commanders, which I read good reviews for, it was complete crap. I thought I was going to crush the thing putting it in and when I got it working one of the buttons broke the first time I tried using it, this is after I realized the poor build quality and took extra care not to smash the thing. And then it kept crashing, freezing up and shutting off all your fans. It didn't matter how long you computer was on but it would just stop without any warning, your case temperatures would skyrocket and if you didn't have your cpu fan plugged direct to the motherboard then things would get really really hot.
I found since then that all fan controllers are crap and at least not to get anything that can actually shut off your fans or even worse your cpu fan. I suspect that this will have the same problems as my fan commander and that its not worth it.
__________________
New Rig, Quad Core and 8800 baby! now my server|Athlon 64 3700(2.64ghz)|7800gs|2gb XMS 2-3-3-6|2tb+ total HD space... In raid|I have a problem. New Laptop: HP EliteBook, its fast! |
| speedfreek |
| Find More Posts by speedfreek |
#9 | |
Richard Swinburne
bit-tech Staff
#10 |
Why so serious?
How about keeping one for case reviews? that way we can find out how the tool-less cases handle half length bay devices...
__________________
The Bit-Tech.net X-Box Live! Leaderboard
My X-Box Live & X-Fire GamerTag: BladeMRK WII#: 0379 8536 3210 2060 My Flikr albums |
#11 |
Spoon? What spoon?
I like my NZXT Sentry, same sort of deal, but more readable
| Bluephoenix |
| Find More Posts by Bluephoenix |
#12 |
S p i t F i r e
Was going to get this a week ago, so glad I didn't.
The viewing angle is just pants.
__________________
Latest project ¦ Project | Black-SpitFire ¦ 89% still Move house clear out, buy my stuff! 360 Games for sale![]() UV . Silent . waterCooled - AMD 64 X2 4800+ . 2GB DDR400 . DFI SLi-dr . BFG 8800 GTX WC . Audigy2 ZS
#13 |
Supermodder
thats a real shame.... i need a fan controller too.
__________________
Current Rig: i7 D0 2.66GHz, 6GB 1066MHz Corsair "Dominator", 285 GTX. |
#14 |
Mod Master
There are literally dozens of others to choose from... including the original ZM-MFC1 +/or ZM-MFC1 Plus
__________________
Beauty is in the eye of the beer-holder
#15 |
Powered by the PG Monkey...
Why do I keep looking at it and thinking that it would be good to have a volume control included as a function for the dial, and play back info for music?
Anywho, I was tempted by this like many others to replace my akasa controller, but it looks like i'll still be some time before a replacement..
__________________
Scorpion - Opteron 146 - 1GB RAM - 120GB Maxtor ATA133 HDD - 8x DVD-RW - 16x DVDROM - nVidia 7800 GTX Graphics - Gigabyte GA-K8N51GMF-9 Mobo - Undergoing Case Mod Phoenix - Toshiba A120 - 1.73 Celeron (Dothan) - 1GB RAM - 60GB HDD - ATi 200m Graphics Salamander - Intel Pentium III @ 733MHz - 256Mb RAM - Total HDD @ 80Gb
#16 |
Hypermodder
Big fan of the T-Balancer aye. Got to admit that the software is a bit buggy, and it's a pain to get it setup... But once it's done it's a really good fan controller you can forget about.
It doesn't have an LCD, but personally prefer a more software LCD Smartie type of setup... You just get a nicer design (in my option) and more usable output... Ach, beyond that, if you have time, even one of those modded PSOne screens is more useful and pretty in my opinion... However, looks like a good attempt by Zalman to put something more consumer friendly together... shame about the viewing angle.
__________________
Jimmy Carr - "It's easier to get forgiveness than permission" |
#17 | |
hmmmm....
I have never really seen the point in Fan controllers personally.
__________________
Fight my Brute
The quantum limit of reality might be scaled up because we're all holograms. Obviously. Once more we see that sufficiently advanced physics is indistinguishable from getting really stoned. From here |
#18 |
Ultramodder
Well if you look at the shots from zalman here are they misleading custommers this way.
Are there any other fan controllers with 4 temp probes and avarage power wattage measuring?
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#19 | |
Richard Swinburne
bit-tech Staff
Obi - no, that's why this is so disappointing: so much potential but it just fails on the one thing. |
#20 |
What's a Dremel?
I did purchase the Zalman ZM-MFC2 controller and thought something was wrong with it until I read the review on this forum. Yes, the viewing angle is not the best especially if your computer is on a floor. I moved the Zalman to the top drive bay of my system and that seems to help. Once you get over the viewing angle issue, the unit is awesome. I like the fact that it has the power meter also and it does not require a software. Its well built and very easy to setup too. You can dial down your fans to the lowest (actually until they stop spinning) to regulate the noise level.
| Thread Tools | |
