RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 26th Nov 2007, 08:27   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
MSI HydroGen - Watercooling, MSI Style
http://www.bit-tech.net/news/2007/11...ng_msi_style/1
bit-tech has obtained some exclusive photos of MSI's new "HydroGen" waterblock that is due to arrive in a limited edition with its next generation Intel X48 motherboard.
Digg if you love <3
Tim S is offline   Reply With Quote
Old 26th Nov 2007, 08:33   #2
Woodstock
So Say We All
Woodstock's Avatar
Woodstock is on a distinguished road
i like how motherboard companys are integrating water cooling products, but im not so sure about the whole heatpipe array...
__________________
Hell hath no fury like a hippo with a machine gun.
Woodstock is offline   Reply With Quote
Old 26th Nov 2007, 08:58   #3
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
It's not a heatpipe - it's a single tube that fills with water which makes it travel from top to bottom (or bottom to top)
Bindibadgi is offline   Reply With Quote
Old 26th Nov 2007, 09:00   #4
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
Looks nice, but I'd be worried about the inner diameter of the copper tubes... Might be good on a sepereate 6/8mm loop, but not on a larger diameter tubing loop ...
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is online now   Reply With Quote
Old 26th Nov 2007, 09:01   #5
Woodstock
So Say We All
Woodstock's Avatar
fine then the part of the loop that is attached to the south bridge and mosfits and of cause the actual copper tubing, you still knew what i meant lol
__________________
Old 26th Nov 2007, 09:08   #6
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Oh yea, totally, but at least this is the first complete solution - it's a step in the right direction if I was wanting to watercool everything. The problem with the Asus ones is that you still need some airflow for the heatpipes, which kind of defeats the object to an extent.
Old 26th Nov 2007, 09:47   #7
(RFFN)-SqUeD
What's a Dremel?
(RFFN)-SqUeD is on a distinguished road
Looks good, The board has got a great layout ..... me like a lot!!!! can't wait for the first reviews
(RFFN)-SqUeD is offline   Reply With Quote
Old 26th Nov 2007, 10:40   #8
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Unfortunately it doesn't have a great layout - the yellow slots are x4 only which make them almost pointless. Better to have had an extra PCI slot and an x8.
Old 26th Nov 2007, 11:19   #9
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
I wonder what the switch is in the bottom right corner.
Old 26th Nov 2007, 11:33   #10
Jamie
bit-tech Staff
Jamie's Avatar
Jamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of lightJamie is a glorious beacon of light
Is it me or does the exit on the southbridge look a little close to the seconds pci-e slot? With a large 1/2" barb plus tubing and a hose clip it could foul on longer graphics cards.
Really like the concept though, much better than the Asus which was reviewed last week in my opinion.
__________________
bit-tech hosted by tsohost.co.uk
twitter | flickr | xbox live | last.fm | moot
Jamie is offline   Reply With Quote
Old 26th Nov 2007, 12:21   #11
nemesis80
Modder
nemesis80 is on a distinguished road
From the pictures below, the awesome laser cut design might say enough watercoolers to spend the money
Laser cut? Sorry to disappoint but those are cnc milled for sure, as the shape of the piece wouldnt correspond to a leser cutted piece...
__________________
Asus P4P800 SE|P4 3.0E @ 3.6ghz |Utra 1536 mb PC3200 dual channel|Maxtor 80gb| Maxtor 120gb|Saphire X800 pro vivo-> xt pe @550/560|Artic Cooling V4|Thermalright xp-120|Lian Li pc-6077
nemesis80 is offline   Reply With Quote
Old 26th Nov 2007, 12:32   #12
airchie
Mod Master
airchie's Avatar
airchie is on a distinguished road
I love the idea of this.
I had a water-cooled PC before my laptop and having to find blocks that fit your NB, SB and MOSFETs is a major PITA.
Buying a board with them custom-made and pre-fitted is a really nice idea IMO.
I'd buy one.
__________________
Laptop:C2D P8600 2.4GHz, 4GB, 9800GTS, 120GB SSD, 15" 1680x1050, Vista64
Projects: 1.2TB Fileserver housed in a cardboard box!|Retro HTPC for my GF.
Originally Posted by astralwandrer
Being a legitimate customer of the games industry is increasingly like being in a relationship with an abusive spouse.
airchie is offline   Reply With Quote
Old 26th Nov 2007, 13:05   #13
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Yes, you're right
Old 26th Nov 2007, 13:42   #14
[USRF]Obiwan
Ultramodder
[USRF]Obiwan is on a distinguished road
no sli ;( Where are the nforce7xx boards???
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..."
The answer is 42, so... whats the question again?
If you know what 'Peek' and 'Poke' represents, then you are probably as old as me.
[USRF]Obiwan is offline   Reply With Quote
Old 26th Nov 2007, 14:15   #15
TomD22
Modder
TomD22 is on a distinguished road
Layout looks a bit dodgy though...only 1 pci slot and if you use a dual slot pci-e in the lower of the blue one, no pci slot at all. So there goes the space to plug in my sound card, tv card, or whatever. (not that I would afford this mb anyway ^^)
TomD22 is offline   Reply With Quote
Old 26th Nov 2007, 14:37   #16
Tile
Banned
Tile is on a distinguished road
Deleted
Tile is offline   Reply With Quote
Old 26th Nov 2007, 14:43   #17
OleJ
Me!
OleJ's Avatar
OleJ will become famous soon enough
Do you mean the display? As far as I can tell it's a four digit display. I think I remember these being used for status codes from the mobo. I think we first saw them on the Fatal1ty boards?
And it actually is the lower left corner if you turn the mobo standard wise
__________________
Quickr! Clickr to my Flickr!
Canon camera stuff. Some aluminium PC, an HTPC and a MBP 17"..
OleJ is offline   Reply With Quote
Old 26th Nov 2007, 14:56   #18
salesman
Multimodder
salesman is on a distinguished road
it clearly says X38 on the board yet its supposed to be a X48 can someone clear the air on this one for me? I'm confused. Maybe its just showing off what the waterblock would look like on a motherboard and this isn't the actual board or even the chipset MSI is going to use. What do you guys think.
salesman is offline   Reply With Quote
Old 26th Nov 2007, 15:25   #19
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Yea it's X48 - the press release was for X38 but MSI have saved it for the X48 release instead in order to finalise the details of the HydroGen block. The layout stays the same but they haven't changed the ink yet that's all
Old 26th Nov 2007, 15:25   #20
Bluephoenix
Spoon? What spoon?
Bluephoenix's Avatar
Bluephoenix is on a distinguished road
+1
Bluephoenix is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
