#1 |
Pewlius Caesar
bit-tech Staff
Abit IX38 QuadGT
http://www.bit-tech.net/hardware/200..._ix38_quadgt/1
Abit loads its IX38 QuadGT with digital power regulation, fancy looks and buttons and an awesome BIOS, but has the silicon enhancement worked out well? Let's find out...
__________________
#2 |
Lazy Lurker
I expected more out of Abit than a pretty board. What went wrong?
![]() With the BIOS holding back memory performance that much, wouldn't it be a rather mediocre, rather than awesome, one?
__________________
Technology Schmecnology |
| RotoSequence |
| View Public Profile |
| Find More Posts by RotoSequence |
#3 |
Hypermodder
The usual thorough Bit-tech review.
![]() Can you say which BIOS version that you tested with? Obviously it's early days in BIOS development for this board & improvements are expected over time. Your experience with Vcore is interesting as it goes against what most others have been reporting in places like XS etc. - there people are reporting only ~0.04V Vdroop even with a quad which is obviously significantly different from your results. I wonder if that's due to a different BIOS? & there are certainly some people who are looking at buying the QuadGT specifically because it has a x4 slot for a RAID card etc. At the end of the day it's a design choice & whether it's right or wrong for you is upto you to decide. Oh & the bundle appears to have been a cock-up - there are supposed to be wire fan brackets for attaching a small fan to the nb included & yes, apparently somebody forgot to spec. the usual abit combined USB & firewire PCI slot plate in the BOM ![]() I totally agree about P35 still being a very strong competitor if you don't need the 2nd X16 slot to run Crossfire which is why I'm sticking with my IP35 Pro. |
#4 |
Pewlius Caesar
bit-tech Staff
Richard listed BIOS 11 on the test setup page, which is the latest available on Abit's site. I'm guessing there will be more updates in the long run that will improve performance over time... I don't personally think it's a bad board, but it's one that you're only likely to be interested in if you want CrossFire.
__________________
#5 |
Hypermodder
Must have missed that, they're already on 12beta3 so that's probably the difference then.
I totally agree about Crossfire being the only reason for going X38 & probably X48 too. |
#6 | |
Richard Swinburne
bit-tech Staff
![]() I totally agree that if it has the features you want, it's a great board, but when I invest in something I expect it to perform at least a little better than a previous generation product. I don't like it being at the sacrifice of a PCI-Express GbE though. |
#7 | ||
Hypermodder
http://www.clunk.org.uk/forums/revie...review-ii.html Quote:
Other than the 2nd PCI-E x16 slot there is no compelling reason for anybody to go with it over P35 as far as I can see. Personally the PCI LAN doesn't bother me as it's still faster than any single HDD can deal with & it's 10s of time faster than domestic Broadband. Mind you the x4 slot doesn't bother me either (unless perhaps for a physics card if that proves to be genuinely useful). |
#8 |
Richard Swinburne
bit-tech Staff
It's not faster than hard drive. 100Mbit = 8MByte per sec and "PCI" Gigabit is a fair bit slower than PCIe from what I've read. It's better for LAN gaming too - as long as you have a good Gigabit switch to connect to. The Abit doesn't offer a teaming function everyone else does either, only having a single LAN.
It is about a million times faster than broadband, but like you say, how many people use an x4 either. The two x16 Gen-2 are actually worth having now because of the price erformance of HD38s, but if you don't care about that then it's cheaper P35 all the way.
#9 |
Multimodder
why dont you do some Amd boards for a change?
__________________
Cpu:Amd Athlon 3800+ X2 Mobo: Biostar T-Force 7025 Ram: 2x512 MB Patriot Psu: Antec 380w Earthwatts HD: WD 320 GB sata Dvd+-rw drive Vga=2600xt |
#10 |
Banned
Nice review. If it was a third less in price it would be worth having but it's just too expensive for what it is. I was hoping for much more. A step back from abit. Shame.
| Silver Shamrock |
| Find More Posts by Silver Shamrock |
#11 | |
Pewlius Caesar
bit-tech Staff
__________________
#12 | |
Pie Eater
There is one gripe, there was a mention of the inability to use the sata clips on asus boards, now maybe i've been silly and used them but all six on my p5n32-e sli have the clips mention and the onbaord ports and all at 90 degrees to the board, just like on the abit reviewed. peace fatman
__________________
Core 2 Quad Q6600 @ 3600Mhz ¦ Asus Maximus II Formula ¦ ATI Radeon 4890 (1000Mhz Core + 1200Mhz Mem OC) ¦ 2x2G Corsair Dom. PC 8500 @ 1080Mhz ¦ Aquacomputer WC ¦ Creative X-Fi Fatal1ty ¦ 150G Raptor, 2x1500 + 1x750 + 2x500 Seagate (SATA2) ¦ Pioneer DVD burner ¦ Lian Li - PC 73SL Aluminium Silent Server Case ¦ Dell 2007WFP 20" Widescreen ¦ Logitech Z-5500 5.1 Speakers ¦ Sennheiser HD270
#13 |
Richard Swinburne
bit-tech Staff
Using the Asus 90 degree SATA sockets you have to force in so it bends the plastic out - there are no little gaps like the Abit 90 degree SATA connectors.
![]() I do have another AMD board in the pipe but it's kinda hard when we don't have a Phenom to use long term
#14 |
Multimodder
Great review Richard , many points I agree with. Like you I was surprised at the sparseness of the package. I'm not sure about yours but the box / mobo tray is also too big by about 2cm, leaving a mobo that slides up & down the box, which isn't to impressive.
I could see that this had occured by the scuffs on the tray:- ![]() The other thing is the lack of fan retension clips for the NB & PWM, despite being shown in the manual. ![]() I'm running with a Q6600 Go and started off running with a lot of vcore, more than i needed on the Gigabyte X38 Dq6. However i found that tweaking vtt & Gtlref, meant that i could lower vcore, this also added to stability. I've run various >12Hr prime stable settings now. They are detailed here Abit IX38 Quad GT - Living Reviewhad II In most cases this board has out performed the Gigavyte x38 Dq6. so personally i'd give it a little more in the Ocing scorre. AS usual we are waiting for a bios which will enable us to run the 1:1.25 strap which is currently unstable (using Bios 12.B02) luck
__________________
Asus Commando, Core2Dup 6600 on Water , CellShock 8000 DDR2 2X1GB 4-4-4-12 2.2v, 320MB XFX 8800GTS XXX + Dell 2007WFP, Etasis ET-850 12v=70A , Hiatchi Sata 2 :- 4x80Gb Matrix Raid(0) + 250gb+320gb Lian-Li v2000 plus 24/7 OC: 3,600=400x9@4:5 1000 |
| Supershanks |
| Find More Posts by Supershanks |
#15 |
Richard Swinburne
bit-tech Staff
To be honest, I don't have time to go into that much detail. I played with the VTT and GTLRef but we hit our CPU limit, again, at 505. The box fitted the board perfectly though
![]() It's good to know there's another resource out there with details, as well as a beta community still. |
#16 | ||
Multimodder
__________________
| Supershanks |
#17 | |
Hypermodder
daft question - assuming that you have PCI-E Gigabit LAN & a Gigabit switch, how does teaming help you as the switch surely is the limiting factor i.e. you can't get 2 pints into a 1 pint glass? Last edited by BUFF; 6th Dec 2007 at 17:05. |
#18 |
Supermodder
From a layout point of view, that is possibly the best thought out board I have ever come across. It does seem let down in other areas, but definitely not layout.
#19 |
Multimodder
I wonder when Bit-tech will review the DFI LanParty UT P35-T2R motherboard?
http://www.google.com/search?q=DFI+L...5-T2R&ie=utf-8 |
#20 | |
Pewlius Caesar
bit-tech Staff
__________________
| Thread Tools | |
