Thread Tools |
#1 |
Brett Thomas
3D CPUs to speed computing
http://www.bit-tech.net/news/2007/12...ed_computing/1
The Institute of Microelectronics in Singapore and flash memory maker, Fujio Masouka, are claiming huge increases in processing power by making processors in 3D.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo |
#2 |
Multimodder
I feel the heatsinks for these would be interesting.
#3 |
Hypermodder
need for speed of course............
__________________
Monita DFI NF4 Expert - X2 3800+ 2.925Ghz - 2x1Gb OCZ Gold XTC DDR500 - 2x eVGA 7900GT SLI - 2x80Gb Seagate 7200.9 [RAID-0 4k] - Enermax Liberty 500 - Vista Ultimate x86 - Silverstone Kublai [Modded] Keisha DFI BloodIron P35 - Q6600 3.6Ghz - 4x1Gb OCZ Gold XTC2 DDR2-800 - eVGA 8800GTS 640MB - 2x80Gb Seagate 7200.9 [RAID-0 4k] - OCZ GameXstream 700 - Vista Ultimate x86 - Silverstone TJ-06 [Modded] www.pecelayam.com |
#4 |
Minimodder
#5 |
Dont do that...
picture needing enough room for 5 tuniq towers. one for each side. maybe a mini version of each...
__________________
attack life, it's going to kill you anyway. Long-term relationships are like urban tomatoes: they only grow under special conditions. - Prestidigitweeze Don't hold on to the reigns once you've fallen off the horse, your just going to get dragged to death - SNiiPE_DoGG |
#6 |
Web Developer
Haha.. I read article and was trying to figure out how it would work in any manner of high efficiency
__________________
Current Computer: eVGA 780i Motherboard | Q6600 Core2Quad | eVGA GTX260 896Mbs 216-core | 2x Seagate 500Gbs | 8Gbs OCZ Platinum DDR2 800 | Creative XtremeGamer X-Fi | Thermaltake Armor Case Custom WordPress, ZenCart, Joomla, vBulletin, etc installs and skinning, PM/E-Mail for a quote
#7 |
UnSeenly
Does this mean we might be getting Processors that are spears with wire jacks on them?
#8 | |
Web Developer
The Allspark....
__________________
#9 |
I'm not a modder.
Providing that the processors aren't hugely 3D, I see know reason why the cooling would have to change much. After all, current processors are multi layered, and these new ones should be more power efficient. Though I have to admit, the mental image of a processor set up like a mini nuclear reactor with cooling running through it is quite cool...
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker ![]() Samsung Q45. |
#10 |
Victim of AdvancedModernCapitalism
It won't last long, we'll find something even better in 10 years. All we need is a giant to take a step forward.
__________________
Netbook: Asus eeePC 901; 12Gb SDD; Custom Ubuntu 9.04 Minimal Compiz Standalone.
Laptop: Intel Centrino Duo T5500 1.66ghz; 2048mb RAM; ATI Mobility Radeon x2300; Hitachi 120gb iPod Classic 120GB; Maxtor 160GB External; Ubuntu 9.10 x64 and Windows 7 x64. |
#11 |
quad fuelled, GTX200 powered
the processor isn't 3D....... (i know i can't take a joke)
they basically says the gates can be overlapped, so opposed to traditional 1 layer of transistors, they can now have multi-layered, so have multiple times the original building space, thus 100MB cache on a CPU may become possible with the current manufacturing technology.
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#12 |
Madeira's banana is the best!!!
if intel or amd don't pick this up i bet via or any other small cpu maker will pinch this technology and become a serious cpu maker rapist....
imagine a cell processor with this, or IBM snatching this and making God like cpus...
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#13 |
Ginger Nut
I read the Intel tech on this about 3 or 4 years ago. It was a bad idea then and it's a bad idea now. There is no way the heat would be dissipated fast enough.
__________________
Kirk, Spock, McCoy, and Ensign Ricky are beaming down to the planet. Guess who's not coming back. |
#14 |
\/\/ho-isky
somebody better get out and patent the trademark, "cinderblock" or something... it almost seems like an obvious name for a 3d cpu. "The Cinderblock Tephra -- with pyroclastic flow technology!"
(Tephra is air-fall material produced by a volcanic eruption regardless of composition or fragment size. Tephra is typically rhyolitic in composition as most explosive volcanoes are the product of the more viscous felsic or high silica magmas.)
__________________
CoolerMaster Stacker 830, (12in NEON LIGHT, 2 Extra Neon Light LED Case Fans), Thermaltake ToughPower 750W, Asus Striker Extreme Mobo, Intel® Core™ 2 Quad Q6600 @ 2.4GHz 1066FSB (ehhh, for now...), Vigor Gaming Monsoon II Lite CPU heatsink, (2x1GB) PC6400 DDR2/800 Dual Channel Memory Mushkin Xtreme w/ Heat Spreader, e-GeForce 8800 GTX Superclocked, X-FI XtremeGamer Fatal1ty Pro PCI Sound Card, 250GB SATA-II 7200RPM HDD, LiteOn20X&SONY16X, Pro Wiring & Thermal Compound, Vista 32
| serialnuber2012 |
| View Public Profile |
| Find More Posts by serialnuber2012 |
#15 |
Lazy Lurker
Unless I completely missed the boat, the rest of you have. The article isn't (primarily?) about stacking transistors on top of each other, its about changing their functional orientation. At present, the structure of a transistor is a three dimensional mass of columns and other micro-silicon based structures that have varying electrical properties that allow for them to function as the transistors that make up logic circuits. So far as I can tell, all they are doing is changing the basic orientation so that instead of the silicate layers needed to make the transistors being stacked on top of each other, they're piled next to each other, with the "wires" following the typical design methods of today's processors.
Or am I horribly horribly wrong?
__________________
Technology Schmecnology |
| RotoSequence |
| Find More Posts by RotoSequence |
#16 |
inch-perfect
I'm baffled how chipmakers didn't come up with and apply this before... I had an idea exactly like this (staggered vertical arrangement of transistors) to reduce die size as transistor counts began to increase dramatically around the the time of K8. I find die size to be particularly important for video cards rather than processors as they have not yet adopted widespread use of multiple graphics cores on one card rather than one gigantic and powerful one. Besides, transistor size isn't getting smaller as quick as it used to, so this sort of arrangement of transistors will have to be adopted soon enough.
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals |
#17 |
Supermodder
I agree, I think heat would be a serious bottleneck for this technology. I think that however you increase speed, you're going to increase temperature and this is already the biggest limiting factor.
| liquid_gen |
| Find More Posts by liquid_gen |
#18 |
Ultramodder
ehm....
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#19 |
sensational.
I have a need for speed and also a need to pay the bills.
Sadly those two can't exist together so I'll go and cry in the corner now
__________________
█▓▒▒▓█▓▒▒▓█▓▒▒▓█▓▒▒▓ Originally Posted by Greeneyedguy advice to all u masturbators... its a good idea to keep a pringles can with the bottom cut out next to u so u can put it over ur wang when ur parents come and tell em u were enjoyong some delicious low-fat potato chips... |
| Thread Tools | |
