Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Sapphire Radeon HD 3870
http://www.bit-tech.net/hardware/200...deon_hd_3870/1
We have a look at Sapphire's Radeon HD 3870 to find out if it continues in the same direction as the impressive Radeon HD 3870 reference card. We also check out how well the card overclocks too -- could this be the card to buy in the run up to Christmas?
__________________
#2 |
inch-perfect
Note its utility in the coming consumer-level QuadFire arrangements.
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals |
#3 |
Modder
why is it the that the 8800 GTS 640MB does so badly?
#4 |
Pewlius Caesar
bit-tech Staff
It doesn't really do that bad IMHO... it's neck-and-neck with the 2900 XT in Crysis/BioShock and faster than it (and the 3870) when AA is applied in ET:QW and CoH:OF.
The reason why it's slower than the 8800 GT/3870 in some scenarios is a lack of shader horsepower and its memory bandwidth/MSAA resolve performance makes up for this when AA is appled.
__________________
#5 | |
Madeira's banana is the best!!!
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key! |
#6 | ||
Pewlius Caesar
bit-tech Staff
__________________
#7 |
I Mod, Therefore I Own
have you still got the card Tim?
could you do a little test for me, hook up a second monitor and push the mem clocks past stock see if its stable? mine is showing some quite odd dual monitor behaviour the card is unstable past stock mem clocks (even like 10-20mhz which is inside the rated speed for the mem) if i have dual monitors up i could play crysis for hours on end at 860/1260ish if i disabled my secondary in windows before playing but it would hard lock and need to be reset with both screens up supcom did this too, theres some weird flickering on the secondary if its going to crash too |
#8 |
Pewlius Caesar
bit-tech Staff
I have still got the card, but today is going to be tight - I'm working towards another deadline for tomorrow.
__________________
#9 |
__________________
#10 | |
Elitist
Great stuff, it's nice to see AMD actually producing something worth buying.
If only it wasn't red.. ![]() Quote:
__________________
Core i7 920 @ 4GHz <-> 8800GTS 512 @ 785/1946/1990 <-> GA-EX58-UD5 <-> 3GB Dominator 1600 <-> Xonar D1
#11 | |
Supermodder
god how ugly would it be if they decided to carry the green theme of AMD over to their video cards. |
#12 | ||
What's a Dremel?
#13 |
Dont do that...
I would like to buy the 3870 but there are two problems, finding the money, and I dont want to buy a card only to have the company go down the drain like 3dfx did after I bought a voodoo 3.
__________________
attack life, it's going to kill you anyway. Long-term relationships are like urban tomatoes: they only grow under special conditions. - Prestidigitweeze Don't hold on to the reigns once you've fallen off the horse, your just going to get dragged to death - SNiiPE_DoGG |
#14 |
sweet sweet hangin joben
what i would like to see is what that overclock does in terms of performance. a hefty oc like that you would think should put it over a gt. then of course what kind of oc can you get out of a gt and where will it all shake out? my gt has been kinda crummy on the oc, hitting only 710 core and 2060 mem.
__________________
I love me some me e8400 @ 4.45 ghz..ac freezer 7..2 gigs patriot extreme 1150 mhz..abit ip35-pro..xfx 4770 with asus top bios @ 926 core/1077 memory..antec p182b..corsair hx620..seagate 500 gb 32mb cache THE best site ever...1600 signatures under the same avatar...time for a new one
#15 | |
DUHHHH
they said the name ATI would be kept and two weeks later the damn site turned green ...
__________________
Phenom X3 720 Black Edition @ 3.4Ghz - Asus M3N72-D SLI - 4GB PC6400 - MSI GTX260 216 - RAID0 37gb Raptors - 2x 500GB - Corsair TX850 - Samsung 2233RZ 120hz cheesecake - Windows 7 Ultimate 64Bits Kids ! The Samsung 2233RZ is the solution to all your problems in life ! That is, of course, if your biggest concern is not sucking at FPS games |
#16 |
Hypermodder
#17 | |
quad fuelled, GTX200 powered
(second paragraph)any hints Bittech on when's your GTS 512MB review going to come out? can i request it to be tested against GTX in every test please?
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#18 |
When did I get a custom title!?!
killer feature of these cards is that you can 3d acelerate upto 4 monitors using 2 cards so there awsome for those who have massive multi monitor setups
![]() *with matrox boxen thats 12 monitors
__________________
Sn45g game server mod My Electronics Site![]() Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit |
#19 |
What's a Dremel?
Could anyone tell me where I could find this exact package that includes the Black Box bundle. The link that points to the BT shop seems to be the one without it as I read elsewhere that if it has the model number 21122-00-20R its not included. I think the one that has it is one with model number 21122-00-50R. I'm only interested in this because of the Black Box but I can't seem to find that one anywhere
#20 |
Pie Eater
nice review and its good to see amd/ati producing something so nice, i think they have well and truly fallen off of the bandwagon for high end cpu's but atleast the gfx guys are still working hard, i may have to flash the bios and massively o/c my 2900xt to prolong its life before i buy a 3870 or 2 and do the bios on that, go watercooling and really push the envelope on the oc'ing of it. Money money money....
peace fatman
__________________
Core 2 Quad Q6600 @ 3600Mhz ¦ Asus Maximus II Formula ¦ ATI Radeon 4890 (1000Mhz Core + 1200Mhz Mem OC) ¦ 2x2G Corsair Dom. PC 8500 @ 1080Mhz ¦ Aquacomputer WC ¦ Creative X-Fi Fatal1ty ¦ 150G Raptor, 2x1500 + 1x750 + 2x500 Seagate (SATA2) ¦ Pioneer DVD burner ¦ Lian Li - PC 73SL Aluminium Silent Server Case ¦ Dell 2007WFP 20" Widescreen ¦ Logitech Z-5500 5.1 Speakers ¦ Sennheiser HD270
| Thread Tools | |
