Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 16th Dec 2007, 03:53   #1
Pha3dr0n
Where's my Valium?
Pha3dr0n's Avatar
Pha3dr0n has yet to learn the way of the Dremel
Webcam, motion detection & email?
I'm going to the states in a while, and don't have anybody to keep an eye on my place while I'm gone. I currently have a couple of webcams set up that I can remote into via my blackberry, but was wondering if anybody had come across any cam software that runs motion detection software, and can send an email if triggered?
I figure if I can set that up, then if anybody breaks in, I'll get an email to the blackberry, remote into the cams, and call the police if I have to.
Cheers,
Pha3
__________________
"I have not failed. I've just found 10,000 ways that won't work."
Pha3dr0n is offline   Reply With Quote
Old 16th Dec 2007, 13:25   #2
Geektechnica
Geek of the East
Geektechnica's Avatar
Geektechnica has yet to learn the way of the Dremel
Digi-Watcher is what you're looking for. Of the webcam security software I've tried out, its about the best.
You can set it up to email you a single or series of still frames, it has a built in webserver that you can log into to see streaming video, it can upload to ftp, and do just about anything else. I have mine set up to guard over my home office when I'm away, it sends me a pix message to my phone if anything gets in there.
Geektechnica is offline   Reply With Quote
Old 16th Dec 2007, 16:26   #3
Pha3dr0n
Where's my Valium?
Pha3dr0n's Avatar
Cheers Sinn - exactly what I was looking for
__________________
Old 16th Dec 2007, 16:30   #4
DaveVader
Fast Action Response Team
DaveVader's Avatar
DaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run Crysis
I've heard these can be really quite effective. Spme bloke was on holiday and caught people breaking into his home, he rang the police and they got the culprits. anyway, thats my 2 cents.
__________________
Current Rig: Gigabyte EP45 DS3L | E8400 | 4*1GB PC6400 | GTX 560Ti | 80GB Seagate/2*1TB Samsung F1/1TB WD Element
Origin name: Schizomida
DaveVader is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
