RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 18th Dec 2007, 16:34   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Zotac unveils first graphics card with DisplayPort
http://www.bit-tech.net/news/2007/12..._displayport/1
Zotac has today announced the first graphics card to sport DisplayPort - the new display interface standard that's set for widespread adoption during 2008.
Tim S is offline   Reply With Quote
Old 18th Dec 2007, 16:44   #2
Icy EyeG
Controlled by Eyebrow Powers™
Icy EyeG's Avatar
Icy EyeG is on a distinguished road
This is great news: DisplayPort is here before I expected.
Let's hope they don't overprice the card because of this.... (like the HDMI cards)
Icy EyeG is offline   Reply With Quote
Old 18th Dec 2007, 17:09   #3
Nikumba
Supermodder
Nikumba is on a distinguished road
They shouldnt need to, I would imagine there will be a bit of price premium until the market picks up for cards like this. But the main reason it wont be over priced is with HDMI there are royality fees to be paid, where as Display port is a free standard
Kimbie
Nikumba is offline   Reply With Quote
Old 18th Dec 2007, 17:30   #4
Jordan Wise
Baby called to see the boss...
Jordan Wise's Avatar
Jordan Wise is on a distinguished road
Display port is absolutely useless, pretty much the same bandwith of dual link dvi (which I have and I am more than content with) really the only point I can see in it is that its a much smaller connection, but hdmi also has that slight advantage and is already dominating the market. Utterly pointless.
__________________
Favourite Max Payne quote: "He was trying to buy sand for his hour glass, and I wasn't selling any"
Steam ID:jordanwise
Jordan Wise is offline   Reply With Quote
Old 18th Dec 2007, 17:32   #5
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
If its basically a universal port which is compatable with HDMi, DVI and D-SUB then it can only be a good thing...
Lets hope there is no premium on the cards with it tho.
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is online now   Reply With Quote
Old 18th Dec 2007, 19:21   #6
Icy EyeG
Icy EyeG's Avatar
Originally Posted by Mankz.
If its basically a universal port which is compatible with HDMi, DVI and D-SUB then it can only be a good thing...
And better designed also (a single card will be able to hold 4 of them), it doesn't look like DVI, ie, a brick.
Old 18th Dec 2007, 20:31   #7
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
and must be cheaper that HDMI because it is free to use it on your design..... you have to pay a premium for HDMI
__________________
RENEGADE X CONTEST! <---- CLICK if you want to win a free Command & Conquer 4 beta key!
DXR_13KE is offline   Reply With Quote
Old 18th Dec 2007, 21:32   #8
p3n
Hypermodder
p3n is on a distinguished road
surely that DVI converter will cause some issues with using the built in dvi port? Infact the DVI converter pic almost looks like a 'shop as the perspective is a tad odd.
p3n is offline   Reply With Quote
Old 18th Dec 2007, 21:53   #9
Redbeaver
Hypermodder
Redbeaver's Avatar
Redbeaver will become famous soon enough
nice, the complimentary adapters are nice addition and will smoothen the transition, like vga->dvi...
__________________
Monita DFI NF4 Expert - X2 3800+ 2.925Ghz - 2x1Gb OCZ Gold XTC DDR500 - 2x eVGA 7900GT SLI - 2x80Gb Seagate 7200.9 [RAID-0 4k] - Enermax Liberty 500 - Vista Ultimate x86 - Silverstone Kublai [Modded]
Keisha DFI BloodIron P35 - Q6600 3.6Ghz - 4x1Gb OCZ Gold XTC2 DDR2-800 - eVGA 8800GTS 640MB - 2x80Gb Seagate 7200.9 [RAID-0 4k] - OCZ GameXstream 700 - Vista Ultimate x86 - Silverstone TJ-06 [Modded]
www.pecelayam.com
Redbeaver is offline   Reply With Quote
Old 19th Dec 2007, 00:06   #10
woodshop
UnSeenly
woodshop's Avatar
woodshop is on a distinguished road
Is it just me or would you all rather have adaptor that are integrated into like 4 inched of cable instead of some hard plastic thing sticking out of your tower which then getting another rigid plastic thing(cable connector) plugged into it...
I know every time i move the tower or other wise change or move the cable i'm afraid the extra leverage the adaptor provides will torque the thing right off the card.
woodshop is offline   Reply With Quote
Old 19th Dec 2007, 07:02   #11
Tyinsar
6 screens / 1 card
Tyinsar's Avatar
Tyinsar is on a distinguished road
Yeah, I think I'd be afraid to use those adapters too. If the cost is the same and the adapters are improved I'd buy.
__________________
It's not about how life treats you, it's about how you treat life.
Tyinsar is offline   Reply With Quote
Old 19th Dec 2007, 13:53   #12
gvblake22
mmm, yep
gvblake22's Avatar
gvblake22 is on a distinguished road
I was definitely thinking the same thing, that adapter looks pretty precarious hanging out there like that. It looks like some vertical movement of some kind with a DVI cable attached would just break the whole thing right off. HDMI isn't any better though.
that's the only thing I like about VGA and DVI, the connections are very solid and you don't really have to worry about it.
gvblake22 is offline   Reply With Quote
Old 20th Dec 2007, 20:34   #13
salesman
Multimodder
salesman is on a distinguished road
I'm in the boat with everybody else. if the 8800gt is the same price as other 8800gt i would be an early adopter. work out good too cause the 8800gt is the card i will get in time i love it price performance ratio, so if the display port can extend the longevity of the card and the stars align i will buy it, I'll just check and make sure there's no hardware malfuntions on the card before i buy it considering its the first of its kind. maybe you guys at bit-tech could do a review on it, or find one, before its released, I'd love to know your thoughts from a hands on experience.
salesman is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
