#1 |
Pewlius Caesar
bit-tech Staff
OCZ Vendetta
http://www.bit-tech.net/hardware/200...ocz_vendetta/1
We're not sure why OCZ named this heatsink the Vendetta, but we're guessing it's so offended by heat, that it's out to avenge the cold. What we can say for sure is that the Vendetta is reasonably priced and has a few novel features, as you'd expect from OCZ.
__________________
#2 |
hmmmm....
Good review as always, I like the heatpipe idea, I wonder if more companies will do this. The grommets are a nice touch too, from experience they really do help.
__________________
Fight my Brute
The quantum limit of reality might be scaled up because we're all holograms. Obviously. Once more we see that sufficiently advanced physics is indistinguishable from getting really stoned. From here |
#3 |
I *am* a Dremel
The heatpipe idea is a very good 1, I read a review of a larger heatsink using it, and even though the contact dose not look as good, its far better. I think we will soon see more and more heatsinks using it. Great review as always
__________________
Main: AMD X2 3ghz, x1900xt, DFI NF590SLI, 4gb pc2-8500 [Watercooled]
Retro: AMD Barton 2ghz, 9600xt, 512mb pc-2700 Animal Crossing: LGTTC - 2492-7863-6464 Member of CK Appreciation Society Group |
#4 |
Wetsander
The heatpipe idea sounds really cool, but I can't help but feel those ridges are going to take away from the advantage of having the heatpipes against the proc in the first place.
| Sparrowhawk |
| View Public Profile |
| Find More Posts by Sparrowhawk |
#5 |
Stormtroopers get laid ...
I cant see why they couldnt still have those heatpipes as close, but fill in the gaps with the metal fins that are already there, so that they create a plate type surface, maybe it just added to much to the cost.
This is one heatsink i wont be considering as mentioned it was only really good when at full speed, and thats just too much noise for my taste, i dont like it when my front fans have to be turned up to 1300rpm.
__________________
Rig - |Q6600 G0 @ 3.55Ghz - Water| |P5B Deluxe| |4x1GB Geil DDR2| |HD3870XT| |Dell Perc/5i SAS PCI-E w/ 3x WD RE2 500GB RAID 5| |Dell 2007WFP| Samsung 24"| HTPC - |A64 X2 5400+| |4GB| |HD3450 + 3200CF| |Antec NSK2400| |Samsung LE40R74BDX| Web Smoothie - |Epia 5000M| |Smoothwall 3.0| |
| Cruelinios |
| Find More Posts by Cruelinios |
#6 |
Modder
I am still not seeing the temps for the stock HSF. How can you do an experiment without a control? Even if you already know what the temps are with the stock cooler, it would be really nice to have them there for comparison.
| SinxarKnights |
| Find More Posts by SinxarKnights |
#7 |
Wetsander
QFT, though is it just me, or does every outfit that makes a stock fan makes some change to it after a few months? Sounds like it'd be hard to keep up.
| Sparrowhawk |
| Thread Tools | |
