Thread Tools |
#1 |
Richard Swinburne
bit-tech Staff
Adding more storage to your Asus Eee PC
http://www.bit-tech.net/modding/2007..._asus_eee_pc/1
The Asus EeePC is an inexpensive phenomenon - but here at bit-tech we're never happy with just leaving things alone. We increase the capacity of the tiny notebook eight fold to over 32GB, with this elegant and very simple mod anyone can do. ![]() Digg if you love it! (or just if you love us )
__________________
#2 |
I pwn all your storage
Awesome guide! I'm liking this a lot more now since 4GB wasn't a lot and 32GB is a lot more
#3 |
Multimodder
Great Guide, it is an easy way to increase the storage in this thing, the 4gb was the only thing that was really putting me off.
#4 |
Multimodder
Is there anyway to trick it in to thinking it's a real hard drive?
#5 | |
6 screens / 1 card
![]() ![]() ![]() (j/k) But seriously: This is a great, simple, mod and a great guide (almost makes me want an Eee) . Thanks
__________________
It's not about how life treats you, it's about how you treat life. |
#6 |
One thing, is there enough space inside to break down a tiny two port USB hub (like one you get from Maplin) so you can still use the USB port?
#7 | |
Mod Master
I think there is.
Some have had success mounting USB hubs in the screen enclosure, above and below the speakers at either side of the screen. There's also a little space either sidde of the trackpad under the heatspreader IIRC that will fit a very thin PCB no problem. Some of the mods also use the USB lead going to the integrated USB webcam and solder on a usb hub to that wire, which makes things quite easy. ![]() I can't wait to mod my eee...
__________________
Laptop:C2D P8600 2.4GHz, 4GB, 9800GTS, 120GB SSD, 15" 1680x1050, Vista64 Projects: 1.2TB Fileserver housed in a cardboard box!|Retro HTPC for my GF. Quote:
#8 |
Voice of Reason
Excellent idea, but it leaves me with two questions.
First, I've heard that on the lesser models without a webcam, there's an internal USB header which would otherwise have been used for the camera. Is this active and just not connected to anything, or are the traces to it cut? Because if it's still wired up, that would make a very easy place to solder to without killing an external USB port. Second, you said the operating system takes 2.6 GB. How does this work on the 2GB model? Is it missing software as compared to the others? |
#9 |
Ultramodder
It looks like there would be enough space for two of those 32gb drives where you mounted the drive in the guide and possibly another two if you ditched the plug and did some more soldering. then you could mount the USB hub somewhere and have 128gb's of space haha. Would be awesome if you could do it in a 4x4 striped array as well. Quadruple the speed and those flash drives a pretty damn dependable so you really wouldn't have to worry about failure. If I had one of those things I'd just fiberglass a terrabyte HDD into the top of the screen or just fiberglass some USB ports and a hub to plug those drives directly into the top so they were flush but removable. The CF wrap the whole dam thing.....I think I have a new project.
#10 |
Supermodder
Your USB cable colors are accurate regardless of cable manufacturer. The front panel leads for integrated USB ports in any non-OEM case uses the same colors. Those colors are a defined standard, just like with CAT5.
Techno-jargon aside, this mod has me considering an Eee, which I was previously turned off from because of the lack of storage.
__________________
if it ain't broke, you're just not trying |
| instant rice |
| View Public Profile |
| Find More Posts by instant rice |
#11 | |
I'm not a modder.
I like the look of that
if they release anything with a 1024*768 screen or above, I would buy it like a shot.
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker ![]() Samsung Q45. |
#12 |
Controlled by Eyebrow Powers™
Great article!
![]() This mod is simpler than the ones featured at eeeuser.com but, with this mod you loose one USB port, whereas with the eeeuser.com mods you add two USB ports from the mini-PCIe connectors. However, it requires some crazy soldering skills....
#13 |
Freed on Probation
looks like a nice mod but wouldnt it have been easier to pop an sd card in
__________________
I may be fat but at least I am not Ginger "The President is no longer a cross-eyed Texan warmonger, unelected, inarticulate, who epitomises the arrogance of American foreign policy" - Boris Johnson |
#14 |
Banned
This is a very cool mod, but personally it's not something I'd do.
For starters, 32GB Class 6 SDHC cards are supposed to be with us in January of 08, and assuming they cost the same as the USB stick, why endanger your machine like that if you dont have to? Obviously, you could go for 64GB of extra memory in total, but then you've spent ~£400 on upgrading the memory of a £200 machine, and you're getting relatively close to higher end sub-notebook machines anyway which often have larger HDDs or SSDs in them anyway. Will I try something like this in a year or two when my warrenty is done and I dont mind too much about the thing maybe dying though, and 32GB USB sticks cost under £80? You bet! |
| specofdust |
| Find More Posts by specofdust |
#15 |
Minimodder
#16 | ||||
What's a Spode?
I chose this route, because then anyone can do it. Personally I think 2 USB ports is plenty. You're not really [i]losing[i] a port - you're just having something permantly plugged in! I'm not sure how it works on the 2GB model. I would imagine the OS would have to be different. Quote:
Yeah, there are some really neatly done mods out there. But not everyone is that great at soldering and wants to risk screwing up their new device. This mod is a LOT simpler with a much smaller chance of screwing up! On a final note, I thought to myself yesterday that instead of blocking off the USB port - a male to male USB lead, means that if used when the machine is off, would essentially turn it into an external hard drive. Useful if you need to access something and the battery is dead and a few other scenarios I can think of. I haven't tested this however, as you would be putting voltage in, where it is used to giving it out. I don't want to end up frying the USB chips onboard! Anyone got any ideas on this?
__________________
http://www.thinkbikes.com |
#17 | |
Banned
| specofdust |
#18 | |
Heathen
__________________
Lo there do I see my Father. Lo there do I see my Mother, and my Sisters and my Brothers. Lo there do I see the line of my people, back to the beginning. Lo they do call to me. They bid me take my place among them, in the halls of Valhalla where the brave may live forever. |
| Almightyrastus |
| Find More Posts by Almightyrastus |
#19 |
Mod Master
Just wondering, why can't we plug anything into the USB port after soldering the drive to it? I want do to this same mod except connect a USB hub instead of just one drive. If a USB hub can run several usb drives on just one port, then shouldn't that external port still work fine? Or does the hub have some sort of power management that lets it run a bunch of stuff at the same time without causing any problems.
__________________
Latest Work: Boombox Build Project PCB- Complete Digital Picture Frame 2.0- Complete RumbleMouse - Complete Latest Project: TestPC- Complete Lian-Li PC7: C2D E6600, XFX 8800GTS 640MB, Corsair 2GB PC6400, 320GB Seagate Barracuda, EVGA 680i SLi, OCZ 850W |
| mattthegamer463 |
| Find More Posts by mattthegamer463 |
#20 |
What's a Dremel?
Brilliant!!! I didn't even know that was possible. The only down side is you loose one usb port, but who cares a usb hub would do. Guess this solves the problem for xp users. Great guide.
| Ownzyouall |
| Find More Posts by Ownzyouall |
| Thread Tools | |
