Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 30th Dec 2007, 12:16   #1
profqwerty
Ultramodder
profqwerty's Avatar
profqwerty - it's over 9000!!!!!!!!1!1!1!!!profqwerty - it's over 9000!!!!!!!!1!1!1!!!profqwerty - it's over 9000!!!!!!!!1!1!1!!!profqwerty - it's over 9000!!!!!!!!1!1!1!!!profqwerty - it's over 9000!!!!!!!!1!1!1!!!profqwerty - it's over 9000!!!!!!!!1!1!1!!!profqwerty - it's over 9000!!!!!!!!1!1!1!!!profqwerty - it's over 9000!!!!!!!!1!1!1!!!profqwerty - it's over 9000!!!!!!!!1!1!1!!!profqwerty - it's over 9000!!!!!!!!1!1!1!!!profqwerty - it's over 9000!!!!!!!!1!1!1!!!
My Ghetto Defender Repair Mod
With all this free time I decided to finally change all the blown bulbs on the Defender. All but 1 were easy enough:
The main beam floodlight had blown so I sat for hours trying to get it out. Turned out the screws were totally rusted and couldn't be un screwed, so I had to drill them out. Thsi meant the light wouldn't go back together, so the Ghetto Mod:
I was also amazed Halfords stocked the exact bulb needed too!
__________________
Q6600 | ASUS P5Q Pro | 4GB RAM | 4870 | 19" AOC + 19" SyncMaster | 2x 250GB + 1TB Samsungs | BT Wireless card | BEOMASTER 4000 + Celestion 33 |
My old acrylic one
profqwerty is offline   Reply With Quote
Old 31st Dec 2007, 08:00   #2
profqwerty
Ultramodder
profqwerty's Avatar
ch424: there's no flange left where the screw head was on; the holes are clean though.
AH: I know what you mean - I will probably replace it with the black stuff when it gives up. Other than buying a new pair of headlights
padre: I don't think that may have worked - these were self tapping screws into plastic, with the heads a pile of rust.
toad: I didn't realise (the petrol station only has grey!). When this comes off I will put some blakc on
__________________
My old acrylic one
Reply
Tags
motors
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
