Go Back   bit-tech.net Forums > Recreation > Gaming
Closed Thread
Thread Tools
Old 1st Jan 2008, 01:23   #1
Asulc
Supermodder
Asulc's Avatar
Asulc has yet to learn the way of the Dremel
Lost CD, can I still play (Medieval 2: Total War)
I was just looking for the CD for Medieval 2: Total War, and I am led to believe that I have lost it. The game is on my computer and is updated to v1.3, and I was wondering if there is any way that I can still play it. If there are any downloads, please post them. Thanks in advance!
__________________
~Asulc~
Mac G5 Case Mod
Asulc is offline
Old 1st Jan 2008, 01:35   #2
chrisb2e9
Dont do that...
chrisb2e9's Avatar
chrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysis
no one will post a cd crack here because they aren't exactly legal. unless its made and put out by the developer which does happen time to time. Gothic 3 for example, the developer gave the community permission to remove the cd check when the last community patch was issued. So i suggest you check the support page for the game to see if they have put out a patch to remove the cd check. if they haven't, you are out of luck.
chrisb2e9 is offline
Old 1st Jan 2008, 23:33   #3
eeevan
Dremel Master
eeevan's Avatar
eeevan has yet to learn the way of the Dremel
Cracks - Use Them.
__________________
E6850 @ 3.85Ghz - 4GB PC6400 - 500GB WD + 250GB Seagate + 1TB Spinpoint - X-Fi Xtreme Audio - Asus P5K-E WiFi/AP - XFX 8800 Ultra @ 650/1100 - Antec Twelve Hundred
eeevan is offline
Old 1st Jan 2008, 23:35   #4
Poisonous
Incestuious
Poisonous's Avatar
Poisonous has yet to learn the way of the Dremel
game burn world.
__________________
Introducing Jesus-Juice.com!
Poisonous is offline
Old 1st Jan 2008, 23:36   #5
Sparrowhawk
Wetsander
Sparrowhawk's Avatar
Sparrowhawk has yet to learn the way of the Dremel
Have someone you know who has the CD to send you an ISO image of it. Mount it as a virtual drive with Daemon tools. Since you actually BOUGHT the game, it should be legal.
Sparrowhawk is offline
Old 1st Jan 2008, 23:45   #6
Poisonous
Incestuious
Poisonous's Avatar
You'd be wrong.
__________________
Old 1st Jan 2008, 23:58   #7
Sparrowhawk
Wetsander
Originally Posted by Poisonous View Post
You'd be wrong.
In reference to me? See, my thinking is, he bought a license to play the game on his box. A damaged/missing CD doesn't change the fact that he paid to play the game.
Old 2nd Jan 2008, 07:34   #8
Fod
what is the cheesecake?
Fod's Avatar
Fod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run Crysis
convoluted, lame and still illegal - use gameburnworld/gamecopyworld for cracktastic convenience. (and don't forget to dump your instal to DVD so you can still play it another time)
__________________
"This face is left intentionally blank."
XBL/PSN/Steam ID: FodT
Fod is offline
Old 2nd Jan 2008, 09:11   #9
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
Lost CD AND lost case? Phone up the help with your key? Otherwise - the suggestions above or buy another but take good care this time.
You lose things, you don't expect to be entitled to a replacement, right? Why should software be any different (unless you use Steam, I suppose).
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline
Closed Thread
Tags
pc, pc gaming
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
