RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Jan 2008, 08:12   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Shuttle SN68PTG5 XPC
http://www.bit-tech.net/hardware/200...tle_sn68ptg5/1
Possibly the perfect Home Theatre PC barebones - the SN68PTG5 looks fantastic, has integrated graphics with HDMI out and is attractively priced. Has Shuttle made something we all want under our TVs?
Tim S is offline   Reply With Quote
Old 3rd Jan 2008, 11:33   #2
Xir
Supermodder
Xir's Avatar
Xir will become famous soon enough
For a HTPC-Test im missing some info:
How's the picture quality, the TV-out, and the loads (and noise) at DVD and HD playback? (Best in your preferred setup...BE processor and IGP)
Is there a TV-in? How about fitting a TV-capture card, DVB-S or DVB-T card? How are the loads when Timeshifting or playback while recording?
Are there any new Shuttles with an external (fanless) powersource? (Like the old SD11G5)
For the non AMD'ers...would the SG33G5 be the Intel based equivalent to this one?
Cheers,
Xir
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C
Xir is offline   Reply With Quote
Old 3rd Jan 2008, 11:47   #3
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
There's no TV in - but it's upgradable via the PCI, PCI-Express or USB. Loads are dependent on what TV card, software you use and what you record. Loads with HD and DVD playback can be seen here: http://www.bit-tech.net/hardware/200...r_tf7050-m2/15 - noise is entirely dependent on load, heat output and optical drive used (mostly the latter).
Picture quality - I haven't got round to testing this yet, but it does support Nvidia PureVideo and it has HDMI digital interface so it should be pretty good.
The SG33G5 is the Intel alternative, yes. There's nothing like the (fantastic but super niche and expensive) SD11G5 planned that I know of, unfortunately.
Bindibadgi is offline   Reply With Quote
Old 3rd Jan 2008, 14:43   #4
Tomm
I also ride trials :¬)
Tomm's Avatar
Tomm is on a distinguished road
Yeah I'd be interested to know how it performs both in 1080 and 720 HD playback. I think that should be part of the bench suite, at least for computers that can be potentially used as HTPCs.
__________________
Carrot cake cheesecake
Shuttle SN85G4V2 | A64 3200+ / Apple PowerBook 12
Tomm is offline   Reply With Quote
Old 3rd Jan 2008, 17:44   #5
Tyinsar
6 screens / 1 card
Tyinsar's Avatar
Tyinsar is on a distinguished road
It looks like a fairly decent rig but I really don't like the look of that HDMI->DVI adapter. Wouldn't one with a short chunk of cable in between be less prone to breaking? (I'd happily give up the gold plating for that.) Also it would make more sense to me if they replaced the VGA port with a DVI-I port and included a DVI->VGA adapter.
__________________
It's not about how life treats you, it's about how you treat life.
Tyinsar is offline   Reply With Quote
Old 3rd Jan 2008, 18:36   #6
pumpman
Ultramodder
pumpman's Avatar
pumpman is on a distinguished road
Finally a positive review of something with amd in the content Nice price too
waits for the c2d pwnzrrr brigade to come along
__________________
Hexus
pumpman is offline   Reply With Quote
Old 3rd Jan 2008, 23:08   #7
Almightyrastus
Heathen
Almightyrastus's Avatar
Almightyrastus is on a distinguished road
Would it be possible for this to work as a blu-ray player with the addition of an appropriate drive? If this is possible then i think i might have found my ideal htpc (so called as my fiancee has already said "ooo purdy" to the looks of it)
__________________
Lo there do I see my Father. Lo there do I see my Mother, and my Sisters and my Brothers. Lo there do I see the line of my people, back to the beginning. Lo they do call to me. They bid me take my place among them, in the halls of Valhalla where the brave may live forever.
Almightyrastus is offline   Reply With Quote
Old 4th Jan 2008, 07:21   #8
Xir
Supermodder
Xir's Avatar
Thanks for your quick response.
I somehow miss the days when signal quality was part of the standart testsuite for GPU's ;-)
this one uses the NVIDIA GeForce 7050PV IGP and nForce 630a chipset.
from your test before http://www.bit-tech.net/hardware/200...r_tf7050-m2/15 I read:
Nvidia doesn’t state that the chipset is capable of full 1080p HD DVD or Blu-ray playback.
But you did get it to run...somhow right?
Mind you, not that I'm planning on Full-HD until my old TV breaks (and Bluray/HD-DVD player prices go down), but it'll be coming sooner or later.
__________________
SN25P
Old 4th Jan 2008, 08:56   #9
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
The IGP doesn't, but if you run it with CPU decoding it does.
Old 29th Jan 2008, 22:00   #10
Negative_Sun
What's a Dremel?
Negative_Sun is on a distinguished road
Quick question:
I'm quite interested in using this case as my main PC as I love the look and feel of SFFs.
You said you dropped a BE-2350 in there with the onboard Graphics and the power comsumption was next to nothing, then the next is the 6000+ with no dedicated GPU and a 6000+ with a HD3850 uses way more because the 6000+ guzzles up too much Watts.
What I'm interested is this: how would it fare with a BE-2350 or BE-2400 (maybe OC to what you had it) and add either a 256Mb 3850 or 256Mb 8800GT?
Do you think it would hang or run, even at full load?
Cheers if you could answer this.
Negative_Sun is offline   Reply With Quote
Old 6th May 2008, 20:34   #11
xander12345
What's a Dremel?
xander12345 is on a distinguished road
Hi everyone, I bought this system after reading this review but I just cant get a decent picture from it. I using;
AMD Athlon 64 X2 Dual Core processor 5000+
and a Samsung 2032mw monitor
I've tried using a HDMI cable but the picture is too intense and blurry giving serious eye strain. While using the D-sub (VGA) port and cable the picture is just seriously poor quality, any ideas?
xander12345 is offline   Reply With Quote
Old 6th May 2008, 22:33   #12
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Is it upscaling the picture? Have you got the drivers installed correctly? Any interference?
HDMI should not be blurry - it's digital.
Is your monitor working properly?
Old 8th May 2008, 20:46   #13
xander12345
What's a Dremel?
Yes my monitor is working fine its a brand new "Samsung SyncMaster 2032mw" i've tried using every different setting it offers. I have reinstalled the drivers many times, however how would you know if they were not installed correctly?
Im going to buy a DVI-VGA cable and try using the HDMI adapter but if that doesnt work i dont know what else to try really, any ideas?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
