RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 4th Jan 2008, 08:09   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Thermalright vs Zerotherm: Cooler Faceoff
http://www.bit-tech.net/hardware/200...otherm_nv120/1
We test two 120mm heatsinks designed for the hardcore enthusiast to determine which one dons the crown in this cooler faceoff. How will the widely praised Thermalright Ultra 120 eXtreme compare to the Zerotherm Nirvana NV120 on the bit-tech grill? Let's find out...
Tim S is offline   Reply With Quote
Old 4th Jan 2008, 08:22   #2
Tyinsar
6 screens / 1 card
Tyinsar's Avatar
Tyinsar is on a distinguished road
Several months ago I purchased a Tuniq Tower 120 because it was "almost as good" as the Thermalright cooler, but at half the price (on sale). I'm about to change the fan but now I just wish I'd bought the Thermalright.
__________________
It's not about how life treats you, it's about how you treat life.
Tyinsar is offline   Reply With Quote
Old 4th Jan 2008, 10:53   #3
impar
2n-1
impar's Avatar
impar will become famous soon enough
Greetings!
And with that you hit the nail in the head.
The price of air cooling is still low when compared to other cooling solutions (and easier to install and maintain), there is no point in geting the second best cooler.
The TRUE120 is the king of air coolers and has been for a while now, the longer it continues in the throne the happier I am with it.
__________________
The recruitment of Militia is illegal.
Militia-recruiters will be prosecuted to the fullest extent of the applicable laws.
impar is offline   Reply With Quote
Old 4th Jan 2008, 13:18   #4
cooper13
What's a Dremel?
cooper13 is on a distinguished road
But the PWM cooling doesn't look too good. Which would be better, the Ultra-120 Extreme, or the Thermaltake MaxOrb? How important is the extra heatpipe cooling? I'm trying to decide what to put on an EVGA 780i board, once they come off of back-order!
(Total n00b post/longtime-lurker/first-time-poster -- LOVE the site: I've learned tons in the past few months!)
cooper13 is offline   Reply With Quote
Old 4th Jan 2008, 14:26   #5
[USRF]Obiwan
Ultramodder
[USRF]Obiwan is on a distinguished road
did I see a 10/10 score? Or did I just imagine it.
I could have said: "I told you so" but i did not.
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..."
The answer is 42, so... whats the question again?
If you know what 'Peek' and 'Poke' represents, then you are probably as old as me.
[USRF]Obiwan is offline   Reply With Quote
Old 4th Jan 2008, 14:28   #6
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
it probably would have got a 10 overall if the support for AMD users had been better.
Old 4th Jan 2008, 14:50   #7
drakanious
Minimodder
drakanious is on a distinguished road
From the second page: "Next the fan clips are hooked around the ends of the heatpipes and pushed taught into the corners of the fan to keep it there..."
Couldn't have meant "taut" by any chance?
drakanious is offline   Reply With Quote
Old 4th Jan 2008, 14:56   #8
M1CUZ
Modder
M1CUZ is on a distinguished road
I can honestly say the Thermalright is an excellent piece of kit, have one on my Asus Striker Extreme and Q6600, though I must say its a very tight fit on this mobo, the heatpipes actually touch some of the mobo heatsinks. Nice slow 120mm fan, can barely hear it and it keep the chip as cold as the British weather at the moment (read cool) even running at full tilt. Only concern I have with it at the moment is the lack of air directed towards any of the chipset/power heatsinks on the motherboard, as a result the system temp is a little high.... Looking at ways to redirect a little air over them at the moment.
I found installation to be a breeze, just make sure you have a nice flat surface and plenty of space.
Also of note, you might find the fan clips easier to use if you clip them in the right place, they are designed to clip in between the fins of the heatsink and not onto the heatpipes themselves. As shown right at the bottom of the installation guide here -> http://www.thermalright.com/new_a_pa...er_u120ex.html
Top notch piece of cooling hardware.
__________________
If its not broken... Mod it till it is!!
M1CUZ is offline   Reply With Quote
Old 4th Jan 2008, 15:25   #9
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Cool, thanks for the link but where ever you put the fan clips I always found I had one too tight and one too lax or one would ping off as I was putting the other on - there is just better solutions out there.
Bindibadgi is offline   Reply With Quote
Old 4th Jan 2008, 15:47   #10
M1CUZ
Modder
Oh yeah, no doubt there friendlier systems out there, don't know how may of these I would class as "better" though :P, have owned many different thermalright heatsinks over the years and they have always been a fan of the wire clips.
I think the important thing with the ones with the U-120 EX is that they go in between the fins (hooking into the notches down the middle of each of the fins and then onto the bottom of the fan (not right over the top). Made the mistake of trying to get them right over the top of the fan myself and bent one of the clips out of shape (nothing a pair of pliers couldn't fix though)
Either way, nice to finally see a Bit-Tech review of the Ultra-120 Extreme, and nicely done as always.
__________________
Old 4th Jan 2008, 16:11   #11
Yggdrasill
What's a Dremel?
Yggdrasill is on a distinguished road
Richard, cant see why you think thats hard to mount the fan. If you read the faninstallation you see that theres two holes that you need to use with the fanwires. http://www.thermalright.com/new_a_pa...120ex.html#fan
Nice review.
Yggdrasill is offline   Reply With Quote
Old 4th Jan 2008, 18:12   #12
seanap
Modder
seanap is on a distinguished road
I personally like the ZeroTherm, but that's just my oh-so-not-important-opinion.
Does any one know which HSF is the quietest? I'm looking to build a near silent computer for a disabled person who needs to interact with the computer through voice, so background / fan noise must be minimal, but water cooling is not within budget. I was looking at getting the Zero Therm, but I'm open for other suggestions.
seanap is offline   Reply With Quote
Old 4th Jan 2008, 18:25   #13
capnPedro
Deaf forever to the battle's din
capnPedro's Avatar
capnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to beholdcapnPedro is a splendid one to behold
A Scythe Ninja should passively cool most (non overclocked/super high end) CPUs.
__________________
ASUS M4A785TD-M Evo | AMD Phenom II x4 955 BE | D-Tek FuZion
4GB Corsair XMMS3-10666 | Corsair TX650
Point Of View 8800GTX | EK FC-8800
capnPedro is offline   Reply With Quote
Old 4th Jan 2008, 18:36   #14
chrisb2e9
Dont do that...
chrisb2e9's Avatar
chrisb2e9 has a spectacular aura aboutchrisb2e9 has a spectacular aura about
depends on if you are overclocking the northbridge and southbridge. the maxorb installs easily if that matters to you. no force is required to get the pushpins into the board. kind of a pain to clean the maxorb though, if you hit it with compressed air the dust blows onto the motherboard and then you have to clean it off. not that big of a deal though, since i would do that anyway.
chrisb2e9 is offline   Reply With Quote
Old 4th Jan 2008, 19:01   #15
wuyanxu
quad fuelled, GTX200 powered
wuyanxu's Avatar
wuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura about
finally! TRUE120 reviewed.
i love mine 120 eXtreme, it's the best topping almost every single heatsink tests with a good fan on low speed. it even beats those cheap under 100 pounds water cooling solutions :P it's so good at taking heat away from processors, going from 1.5v to 1.6v didn't change load temperature much at all, was just under 70 for 1.5v, now just over 70 for 1.6v. (no, i didn't leave it for a long time)
only thing is, when you are installing TRUE120, get someone else to hold the cooler, otherwise it may slide about when you try to screw it in.
for a better PWM temperature, you can stick a piece of paper to the fines, to direct air into the PWM. i didn't do that yet my Abit iP35 Pro (rather famous for hot PWMs and bad thermal past on those) is idling at 42c.
__________________
Death to consolification !!!
Core i7 860 @ 4Ghz Cooled by Corsair H50 // Asus P7P55D Deluxe // 8GB of Corsair Dominators @ 1528Mhz 8-8-8-24 //
BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240
wuyanxu is offline   Reply With Quote
Old 4th Jan 2008, 20:00   #16
Dev25
Multimodder
Dev25 is on a distinguished road
was gonna buy a 120 extreme ]
this just make me wanna buy it quicker
Dev25 is offline   Reply With Quote
Old 4th Jan 2008, 20:29   #17
SinxarKnights
Modder
SinxarKnights is on a distinguished road
LoL! Thank you for putting at least one stock temp in there. Those temps are much better than my Arctic Freezer 64Pro cooler. With a 3800+ I get 28C idle and 40C load. With it overclocked to 2.5GHz I get 30C idle and 50C load. I could really use a better cooler or maybe a new system since Phemom don't work with my MB >
SinxarKnights is offline   Reply With Quote
Old 5th Jan 2008, 01:12   #18
cpemma
Ecky thump
Moderator
cpemma's Avatar
cpemma is a glorious beacon of lightcpemma is a glorious beacon of lightcpemma is a glorious beacon of lightcpemma is a glorious beacon of lightcpemma is a glorious beacon of light
I love English. So logical.
teach/taught
tight/taut
tit/teat
/spam
http://www.silentpcreview.com/article30-page1.html
__________________
Nobody's perfect.
But being a Yorkshireman is as close as you can get.
cpemma is offline   Reply With Quote
Old 5th Jan 2008, 01:52   #19
sheninat0r
What's a Dremel?
sheninat0r will become famous soon enough
Hey, I noticed an error about the fans - Noctua doesn't make a 1400RPM model, only 800, 1200, and 1300RPM-ers. The 1300 is also a drastically different design than the 800 and 1200RPM fans, so it would be nice if the model number was listed as well.
__________________
...with a crowbar.
sheninat0r is offline   Reply With Quote
Old 5th Jan 2008, 07:14   #20
hdfreedom
What's a Dremel?
hdfreedom is on a distinguished road
A bit of information. I have the Nirvana 120, and the fan is removable, making it easier to install those 2 mounting screws. I would assume that those sold in the UK are of the same design as those sold in the US. Simply remove the fan before installation, and replace after installation. All you have to do is pinch the 2 ears on the mounting tab at the bottom of the fan stand.
As for the member above that asked about routing air to the other heatsinks, I did that by simply using a 2 rulers and bending the bottom fins on the back downward to direct air at it. Works great and looks stock when done right. I forget what heatsink that had this little feature recently, but it came in handy for me. This again is with the Nirvana 120.
One other bit of info. If you look at the results, the Thermalright always has a lower ambient temp than the Nirvana. By guestimating (I'm not a rocket scientist), this would bring the 2 a little closer to each other after adjustment in temps I believe.
I got my Nirvana on sale for half the price of the Thermalright (not seen the thermalright on sale at all). For the little difference in temps, I think this heatsink does quite a good job in price/performance. Fits my needs well.
hdfreedom is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
