Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 5th Jan 2008, 09:18   #1
mm vr
The cheesecake is a lie
mm vr's Avatar
mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!
Is it good to have dedicated graphics drivers on Linux?
I recently got DSL (Damn Small Linux) installed on an old computer and swapped the graphics card to an Nvidia Riva TNT2 M64 PCI 32MB ETC ETC...
I installed the drivers on Windows already (works great) but I'm struggling with the Linux drivers install. The problem is that it starts the installation, but gives an error message about me not having the 'binutils' package installed. I actually installed the binutils thing right away after I got the error message but no luck.
So my main question is: "Is it worth it to install the dedicated drivers (on Linux) and what kinda differences does it make?". If it is worth it, I'd gladly hear how to install them succesfully.
Thanks in advance, mm_vr.
mm vr is offline   Reply With Quote
Old 5th Jan 2008, 13:59   #2
TomH
Bwahahahahaha
TomH's Avatar
TomH has yet to learn the way of the Dremel
If you want to do anything with 3D, yes it matters. Otherwise, probably not. I would have thought the open-source 2D stuff for the TNT2 was stable enough by now.
It begs the question; are you ever gonna want to do anything 3D on a TNT2? Probably not, these days!
Edit: Ignore the below, just realised 'DSL' doesn't stand for 'Digital Subscriber Line' in this case
As for the compile errors though - if you're running Ubuntu (?) then run 'sudo apt-get install build-essential' and try the driver install again. Though I'd only bother with it all if you've got performance/compatibility problems.
TomH is offline   Reply With Quote
Old 5th Jan 2008, 14:45   #3
Glider
/dev/null
Glider's Avatar
Glider has yet to learn the way of the DremelGlider has yet to learn the way of the DremelGlider has yet to learn the way of the Dremel
DSL == Damn Small Linux... So I doubt he's using Ubuntu...
__________________
There Are 10 Types Of People, Those Who Know Binary and Those Who Don't
Glider is offline   Reply With Quote
Old 5th Jan 2008, 15:07   #4
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the Dremel
DSL is pants unless you have NO other option.
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 5th Jan 2008, 15:09   #5
steveo_mcg
STILL ALIVE
steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.steveo_mcg is a hoopy frood who really knows where their towel is.
DSL is great in the right situation, for a full desktop, perhaps not. For a p1 laptop with a few megs of ram its a god send!
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 6th Jan 2008, 08:37   #6
mm vr
mm vr's Avatar
Thanks for the replies.
I am propably going to run some light games (like LieroX etc...) so I'm now going to install the drivers.
IMO the computer we're talking about isn't a 'full desktop', as it has an AMD K6-2 @ 500MHz, 128MB of RAM, a 3GB HDD and the Riva TNT2 I mentioned earlier. It hardly runs WinXP.
Old 6th Jan 2008, 09:57   #7
mm vr
mm vr's Avatar
AAHH sh*t...
Noticed that I've only downloaded (and unpacked) the binutils package. Tried to install it the way the readme file says, but it doesn't work! It gives an error message like this:
Code:
Configuring for a i586-pc-linux-gnuoldld host.
Created  "Makefile" in /binutils-2.9.1
./configure: line 7: gcc: command not found
**** The command 'gcc -o conftest -g   conftest.c' failed.
**** You must set the enviroment variable CC to a working compiler.
What to try? I've already tried to install it with the sudo command but no luck.
Do you guys have any suggestions?
Old 6th Jan 2008, 10:04   #8
Glider
/dev/null
Glider's Avatar
You need to install GCC too...
But, is this worth it? I'd look into a distro that's a bit more adaptable if I were you...
__________________
Old 6th Jan 2008, 10:08   #9
mm vr
mm vr's Avatar
Yea, about the distro: Tried installing Xubuntu first but the install failed (and corrupted the MBR) and I were really out disk space. (3GB just isn't enough.)
That's how I went to DSL. Anyways, it's good enough for me as I'm dual-booting between DSL and WinXP.
Thanks for the help anyway.
Old 14th Jan 2008, 15:39   #10
Fophillips
Hypermodder
Fophillips's Avatar
Fophillips has yet to learn the way of the Dremel
Read man ipkg (I think DSL uses ipkg) and find out how to install GCC.
Fophillips is offline   Reply With Quote
Reply
Tags
linux
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
