RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Jan 2008, 02:44   #1
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
RiData makes 128GB SSDs
http://www.bit-tech.net/news/2008/01...ta_128gb_ssd/1
CES 2008 - RiData, the oldest company in SSDs, has released a 128GB version that will be finding its way to OEM builders soon. Oh, and did we mention that this one loads up Crysis levels in 16.8 seconds?
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 10th Jan 2008, 03:07   #2
sotu1
Mini Love
sotu1's Avatar
sotu1 is on a distinguished road
woo baby! I'd like them to concentrate on making the 128GB version cheaper, and also concentrate on higher capacitities. it looks like speed has reached a high point, and although I'm sure they can do better given time, i'd rather they get these babies out in high numbers so we can get our grubby mitts on em!
__________________
Death to consolification !!!
[size=1]Give me my Windforce! I'm coming back!
sotu1 is offline   Reply With Quote
Old 10th Jan 2008, 08:20   #3
outlawaol
▲Operational Hazard Sticker▲
outlawaol's Avatar
outlawaol will become famous soon enoughoutlawaol will become famous soon enough
This looks like stuff that will make computers truly boot in seconds. Even my raid'ed HD's take about a minute (oh noes) for vista to load. Data fetching, data handleing, data period becomes more fluid. Becoming what the CPU's, and RAM have started to become already.
Really this stuff is just begging to be used by current computer technology. Only thing now is the cost, once its down to a more reasonable price, it'll spell the end of the normal typical HD tech.
__________________
40D| 350D | 24-105 f/4L | 24-70 f/2.8 Sigma | 50mm f/1.8 | 75-300 f/4-5.6 Sigma | 420ex Speedlight
365 Daily Photograph | Smugmug
outlawaol is offline   Reply With Quote
Old 10th Jan 2008, 08:37   #4
metarinka
I *am* a Dremel
metarinka's Avatar
metarinka is on a distinguished road
have they ever got over the hump of the lower read/write cycles of solid state memory? I know they have algorithms and such to evenly disperse data across all sectors on the drives. (as there's no penalty, in terms of seek time) However If I remember correctly the read/right cycles for modern SSD's are still quite lower than the extremely high cycles of a modern HDD. such that after a year or so of use as an OS drive things like swap files and such would eventually kill the drive
metarinka is offline   Reply With Quote
Old 10th Jan 2008, 10:29   #5
chicorasia
Multimodder
chicorasia is on a distinguished road
I've read it somewhere that, under normal usage, a SSD drive would last about 10 years. Naturally, the bigger the capacity, the more gates you have to go around (each gate being good for about 1.000.000 cycles), the longer it would take for the drive to degrade.
128gb is an important milestone - it is enough to convince me to swap my macbook's 60gb hd for a SSD drive.
How about some "internally redundant" SSDs? Since there are no longer the physical limitations of platters and arms and heads, why not assemble two flash drives in the same casing and have them on RAID 0 or 1? Something the end-user can choose by means of a jumper, BIOS, firmware or whatever...
chicorasia is offline   Reply With Quote
Old 10th Jan 2008, 13:59   #6
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
i give it 2 years until everyone around here has at least one of these SSDs.
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is offline   Reply With Quote
Old 10th Jan 2008, 14:24   #7
Redbeaver
Hypermodder
Redbeaver's Avatar
Redbeaver will become famous soon enough
fudge... $3,000?????
if thats a typo and its actually $300 ill buy one in a heartbeat lol
ah, one can only dream...
__________________
Monita DFI NF4 Expert - X2 3800+ 2.925Ghz - 2x1Gb OCZ Gold XTC DDR500 - 2x eVGA 7900GT SLI - 2x80Gb Seagate 7200.9 [RAID-0 4k] - Enermax Liberty 500 - Vista Ultimate x86 - Silverstone Kublai [Modded]
Keisha DFI BloodIron P35 - Q6600 3.6Ghz - 4x1Gb OCZ Gold XTC2 DDR2-800 - eVGA 8800GTS 640MB - 2x80Gb Seagate 7200.9 [RAID-0 4k] - OCZ GameXstream 700 - Vista Ultimate x86 - Silverstone TJ-06 [Modded]
www.pecelayam.com
Redbeaver is offline   Reply With Quote
Old 10th Jan 2008, 14:31   #8
Xtrafresh
Blame it on the Boogie
Xtrafresh's Avatar
Xtrafresh is a jewel in the roughXtrafresh is a jewel in the roughXtrafresh is a jewel in the rough
wow, this is sweet! I never really looked into SDD, since it didn't seem usable...
How big are these drives, physically speaking? same size as normal HDDs?
Xtrafresh is offline   Reply With Quote
Old 10th Jan 2008, 21:35   #9
DXR_13KE
DXR_13KE's Avatar
they are designed to replace hard drives, you remove the old one and insert the new one.
__________________
Old 11th Jan 2008, 09:55   #10
[USRF]Obiwan
Ultramodder
[USRF]Obiwan is on a distinguished road
Its all plusses really:
+ no moving parts
+ less power needs
+ less heat
+ no noise
+ faster seek times
+ faster acces times
+ longer lifetime
+ less/not sensitive to shocks
+ Fast and in the future faster still
- price
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..."
The answer is 42, so... whats the question again?
If you know what 'Peek' and 'Poke' represents, then you are probably as old as me.
[USRF]Obiwan is offline   Reply With Quote
Old 11th Jan 2008, 19:40   #11
metarinka
I *am* a Dremel
metarinka's Avatar
http://en.wikipedia.org/wiki/Solid-s...#Disadvantages I'm not sure about this particular drive, but the average is still around 500,000 writes, firmware and file systems can mitigate this. but still some files and such can go over this. Not to mention the price.
still though this is the future and we'll probably be seeing these slowly take over the market over the next few years.
Old 11th Jan 2008, 19:47   #12
Woodstock
So Say We All
Woodstock's Avatar
Woodstock is on a distinguished road
i want two of them now thou
__________________
Hell hath no fury like a hippo with a machine gun.
Woodstock is offline   Reply With Quote
Old 11th Jan 2008, 19:49   #13
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
I'd love one if I could afford it.
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 12th Jan 2008, 04:57   #14
r4tch3t
hmmmm....
r4tch3t's Avatar
r4tch3t will become famous soon enoughr4tch3t will become famous soon enough
The problem with the limited write cycles is due to how the technology works, essentially its forces electrons through an insulator into a cell, or pulling them back through, this in effect causes physical damage to the device where as a magnetic Hard drive rotates particles which has little to no effect on the durability of the HDD platters. When reading, the drive "senses" whether there are electrons in each cell and then reports either a 1 for electrons present or 0 for no electrons. SSDs therefore have a practically infinite read life.
Or something like that anyways.
Good going for continuing to improve on the tech.
__________________
Fight my Brute
The quantum limit of reality might be scaled up because we're all holograms.
Obviously. Once more we see that sufficiently advanced physics is indistinguishable from getting really stoned. From here
r4tch3t is offline   Reply With Quote
Old 14th Jan 2008, 01:36   #15
ou7blaze
sensational.
ou7blaze's Avatar
ou7blaze is on a distinguished road
This makes me think how big are the SSD's in ipod's and how much would they cost standalone? If this technology is already present in iPod I'm sure in a few years time or less it will be available to the mass ..
__________________
Originally Posted by Greeneyedguy
advice to all u masturbators...
its a good idea to keep a pringles can with the bottom cut out next to u so u can put it over ur wang when ur parents come and tell em u were enjoyong some delicious low-fat potato chips...
ou7blaze is offline   Reply With Quote
Old 14th Jan 2008, 03:05   #16
Da Dego
Brett Thomas
Da Dego's Avatar
The lifecycle for Ridata drives (due to the controller mechanism and ECC) is about 10 years according to the engineer So, longer than an equally used hard drive
__________________
Old 14th Jan 2008, 08:32   #17
completemadness
Hypermodder
completemadness is on a distinguished road
How did they calculate that?
Because normal HDD's wear over time, whereas SSD's have a finite number of writes - therefore, they must have assumed that you only use the SSD so much per day/whatever
completemadness is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
