Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 15th Jan 2008, 16:38   #1
DXR_13KE
BananaModder
DXR_13KE's Avatar
DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.
How can i know what program is using my hard drive?
How can i know what program is using my hard drive at a the present time (when the hard drive light is blinking)? what software should i use to find out?
I know it is a noob question but someone has to make it......
__________________
Renegade X - Release Date Unveiled
Check it out!!
DXR_13KE is online now   Reply With Quote
Old 15th Jan 2008, 17:40   #2
ryanjleng
ryanjleng has yet to learn the way of the Dremel
You'll love File Monitor.
I used it as part of my security and programming work. Sysinternals (bought by MS in 07) has huge amount of extremely handy tools.
Autoruns
Access Enumerate
Page Defragment
Process Explorer
Process Monitor
Registry Monitor
TCPview
and lots more... all FREEEEeeeeeeeee
ryanjleng is offline   Reply With Quote
Old 16th Jan 2008, 01:00   #3
DXR_13KE
BananaModder
DXR_13KE's Avatar
Many thanks
__________________
Check it out!!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
