Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 23rd Aug 2002, 16:49   #1
MajestiX
Multimodder
MajestiX has yet to learn the way of the Dremel
quick question
is it ok to tap power from a line will it change the performance of a drive???
Code:
                    5v to LEDs     ground to LEDs
--------------/---------------/------------> ground to hard drive
------------/------------------------------> 5v (red) to hard drive
Cheers,
MajestiX.
MajestiX is offline   Reply With Quote
Old 23rd Aug 2002, 16:55   #2
Holst
Multimodder
Holst has yet to learn the way of the Dremel
As long as you are connecting in paralell with the drive (onto +12 and +0) then you are fine.
Holst is offline   Reply With Quote
Old 24th Aug 2002, 12:17   #3
MajestiX
Multimodder
so i guess that means nothing happens...
thanks
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
