Thread Tools |
#1 |
Player Character
bit-tech Staff
Power-Over-eSATA announced
http://www.bit-tech.net/news/2008/01...ta_announced/1
The SATA International Organization is working on an extension to the external SATA spec which allows devices to draw power directly from the host PC.
__________________
#2 |
Multimodder
I almost wont have a reason to keep my hard drives in my computer anymore!
#3 |
What you Looking at Fool!
The way I see it is that you will only need a small hard drive in your computer for the OS and have everything else stored on a esata drive so you can just unplug and plug into a laptop for example. No need to keep the drive fixed inside a desktop anymore.
__________________
| mikeuk2004 |
| View Public Profile |
| Find More Posts by mikeuk2004 |
#4 |
Multimodder
I agree, the most annoying thing about external hard drives are the amount of plugs and wires involved, this is something i would definitely invest in. With 3 externals but only 2 power leads due to one going kaput, it's a pain to keep swapping them over!
__________________
PC: Intel C2D E8400 @ 3.0Ghz, 2GB Corsair TwinX Dominator DDR2-8500 (1066), Asus P5K-SE, BFG Nvidia 8800GTS 512MB, Corsair HX 520W, Samsung 750GB Spinpoint F1 running Vista MacBook: 2Ghz, 2GB, 80gig running Vista, Leopard, Ubuntu Servers: 3 other PC's in cardboard boxes |
#5 |
I Mod, Therefore I Own
thats awesome
but i wonder how much power is it going to be able to supply? enough to run a 3.5" drive? |
#6 |
ITS OVER 8000!
Thats good news!
#7 |
mmm, yep
Agreed, should be interesting to see how much it can actually run. If it can handle a full sized 3.5" high capacity drive, then I'm very excited!
__________________
Finished:~~~~~~~~~~~~~~~~~In Progress: Project Phoenix (Lian Li PC-101B Orange Case Mod)
The "Secret of the Ooze" Modded Tt MatrixVX Modded Cooler Master Cavalier 3 My First Case Mod |
#8 |
Multimodder
I'm looking forward to this development. With a bit of luck my next laptop will have this capability. One question about esata though. I've read on wikipedia that "With passive-adapters, the maximum cable length is reduced to 1 meter, due to the absence of compliant eSATA signal levels" so my question is which chipsets have the compliant signal levels and for those that do do they retain the 2m max cable length? Anybody know?
#9 |
What's a Dremel?
Cool, I don't have any e-Sata yet, but i have a few USB drives that need other power, either pulling a second usb lead or brick. they're a pain
it'll be nice to be able to power things over one cable (I know some of the USB things are suppose to do it using usb power, but i've not seen it working well yet with bigger disks).
#10 |
Multimodder
This is really how it should have been in the first place!
Although having a server setup for any major storage needs kind of cancels the need for this with me anyway ![]() Certainly would make backing up data easier though without the need to fumble around looking for a power cable. [Edit] As I see it, it would also make it easier for average-joe to increase the storage in their PC too? [/Edit]
__________________
Intel Pentium 2180 @ 3Ghz, MSI X38 Diamond, OCZ Platinum DDR3 2Gb, Geforce 8800GT 512 OC, Creative X-Fi PCIe, Maxtor 200Gb SATA, Optiarc DVD-RW SATA. ViewSonic VX924, Creative 4.1, Logitech LX700, Windows Vista Ultimate. The Cake Is A Lie |
#11 |
*_*
First things first there are no speeds on this new SATA-IO, and i been hearing talk about this one cable with power over a year now.
About USB-3.0 now theres something to talk about system I/O will get dramatically upgrade when USB 3.0 makes its debut in the later half of 2008. Details on the updated spec are sketchy, but Intel (the creator of USB) says it and its partners plan to get the ubiquitous standard up to 5Gb/s. Intel says the new spec will be backward-compatible with previous generations of USB but will have the added benefit of being able to run over either copper or optical cabling using the same connector. USB-3.0 will be finalized in the first half of 2008 and have a rollout similar to the high speed USB-2.0 launch: controllers will initially be available via PCI-Express add-in cards, with motherboard integration slated for 2009. Now with that off my head STOP!! and think your 4Gb USB-3.0 drive plug it in, the full 4Gb USB-3.0 drives data can transfer all that in 1s. So SATA-IO if it had optical and at 5Gb/s then there is some to talk about, so i hope to see optical on eSATA SATA in the up coming years. PhoneyVirus |
#12 | |
#13 |
Why are you reading this?
This is very cool, but I've had the thermaltake External enclosure that comes with a molex to enclosure power adapter in an Expansion slot. Though it has "no power block", it is still technically two cables, but that doesn't bother me.
-Indybird |
#14 | |
pretty fing wonderful
yep, now i keep all my drives fixed inside my fileserver
. esata is an enthusiast technology. i don't really see a market for esata-only drives. there is no point in me buying a disk that i can only plug into my computer. i want to be able to bring it over to my friends place and plug it into his computer too.Quote:
__________________
the old: gigabyte P35, e4300@2.8GHz, 4GB DDR3-1333, 8800gts 512, win7
the new: DFI M3H5 Jr, phenom 810, 4GB DDR-1600, OCZ Vertex, debian notatoad.net fdo eff Last edited by notatoad; 19th Jan 2008 at 02:59. |
#15 | |
![]() i already have a USB + eSATA external caddy, use eSATA on my machine but can hook up USB to connect to others |
#16 | |
Mod Master
![]() (Original pics courtesy of Bjorn 2D)All the devices are connected to/powered by a single, 180w PSU... such that the PSU itself, is the only device in the 'stack' which requires plugging into the mains ![]() The only drawback I can see with it, is that you can only use Ultra's own products in the 'stack'
__________________
Beauty is in the eye of the beer-holder
#17 |
Minimodder
I hope it can power the Western Digital GP Series 3.5" Drive
| Thread Tools | |
