Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 19th Jan 2008, 03:49   #1
CandyMan
Minimodder
CandyMan has yet to learn the way of the Dremel
Best Pre-Built Pc?
Sup guys where would be the best place in your opions as to where i could pick up a great pre-built gaming pc. Im asking for a friend that doesnt want to build his own pc. Hes got money to burn and says he is way to busy to build his own any opions as to what he should get and what company to go with? Thanks
CandyMan is offline   Reply With Quote
Old 19th Jan 2008, 04:37   #2
Asulc
Supermodder
Asulc's Avatar
Asulc has yet to learn the way of the Dremel
I really like the look of the murder box. Check it out, and write them. I am pretty sure that they are all hand built, so they could take color scheme and other requests (maybe)
http://murderbox.com/
__________________
~Asulc~
Mac G5 Case Mod
Asulc is offline   Reply With Quote
Old 19th Jan 2008, 05:23   #3
jkeyser14
Multimodder
jkeyser14 has yet to learn the way of the Dremel
I hear Alienware is good.
jkeyser14 is offline   Reply With Quote
Old 19th Jan 2008, 05:31   #4
tranc3
ADHD Modder
tranc3's Avatar
tranc3 has yet to learn the way of the Dremeltranc3 has yet to learn the way of the Dremel
ibuypower.com (or something like it) my friend has a comp from them, from a few years ago, still runs great. they just put parts in a case basically, not to expensive ether.
__________________
[AMD Kuma 7750 2.77 |Asus M3N78-EM|Mushkin 4x1GB DDR800 |WD Caviar 500GB|GeForce EVGA GTS 250 512MB|OCZ StealthXStream 600]
tranc3 is offline   Reply With Quote
Old 19th Jan 2008, 05:50   #5
Brett89
Ultramodder
Brett89's Avatar
Brett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run Crysis
They're good, but you're paying for a name mostly. keep that in mind.
__________________
Delidded i7-3770K @ 4.0Ghz, Intel DZ77, eVGA GTX 970 FTW SLi, 32GB Corsair Vengeance, , Xonar D2, Samsung 850 PRO 512GB, 2TB and 1TB WD Seasonic X-750, Model M 1391401, Razer Diamondback,and a Chenbro RM-F41300
NETWORK: Meraki MX-64, MS220-8P AC68U
SERVER: i7-3770S, DH77EB, 32GB of RAM, 2TB SSD RAID (raw)
Brett89 is offline   Reply With Quote
Old 19th Jan 2008, 06:39   #6
Spaceraver
Ultralurker
Spaceraver's Avatar
Spaceraver has yet to learn the way of the Dremel
If he has the cash, why not spec him a machine and get the shop to make it run or you do it and pocket the difference..
__________________
"Faith: not *wanting* to know what is true." - Friedrich Nietzsche. "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." - Seneca
Curiosity *may* have killed Schrödinger's cat.
Spaceraver is offline   Reply With Quote
Old 19th Jan 2008, 06:46   #7
notatoad
pretty fing wonderful
notatoad's Avatar
notatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremel
build a machine for him. pre-build is a rip-off.
if he's dead-set on blowing his cash on a pre-build, voodoo/hp or alienware/dell are both good.
__________________
13" macbook air and a boxee box. minimalism ftw.
notatoad is offline   Reply With Quote
Old 19th Jan 2008, 07:44   #8
CandyMan
Minimodder
Did i forget anything to get it going???
Old 19th Jan 2008, 08:50   #9
Hazardous
Mod Master
Hazardous's Avatar
Hazardous has yet to learn the way of the Dremel
Nope. You've included everything which is important
4GB RAM wouldn't go amiss though?
Even though XP can't use it all... RAM is so cheap just now, it would be a sin not to spec 4GB (2x 2GB)
And it needn't cost any more than the RAM you've chosen!
You can order this 4GB (2x 2GB) Patriot Extreme Performance PC2 6400 for just $75 (mail-in rebate price)... the same price as the 2GB (2x 1GB) Crucial Ballistix you've selected
__________________
Beauty is in the eye of the beer-holder
Hazardous is offline   Reply With Quote
Old 19th Jan 2008, 09:59   #10
mm vr
The cheesecake is a lie
mm vr's Avatar
mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!
I'd personally not go for OCZ PSUs.
mm vr is offline   Reply With Quote
Old 19th Jan 2008, 10:25   #11
Silver Shamrock
Banned
Silver Shamrock has yet to learn the way of the Dremel
Silver Shamrock is offline   Reply With Quote
Old 19th Jan 2008, 10:38   #12
mm vr
mm vr's Avatar
Oh, sorry for that. OCZ PSUs are good and expensive, but Corsairs are (at least) equally good but cheaper.
Old 19th Jan 2008, 11:31   #13
Bbq.of.DooM
Custom User Title
Bbq.of.DooM's Avatar
Bbq.of.DooM has yet to learn the way of the Dremel
1. Never, EVER, build a pc for anyone you know. EVER. It ends up having free unlimited lifetime support - from you. Save yourself headaches and time, and "serious problems" that become "no big deal" when there is a price attached to support.
2. OCZ gamexstream has out of spec ripple at high loads. Don't waste your time.
3. If he doesnt need 2 video cards or raid, the IP35-E is a much, much cheaper alternative that is almost as good.
4. iBuypower, along with cyberpowerinc, are pretty low on the rankings of good manufacturers. Think of them as the Kia and Hyundai of prebuilts, with AVAdirect being closer to mercedes, and alienware being a Lincoln (fancy outsides, fancy name, same old crap).
5. Good luck. you will need it.
__________________
Wowomg!!
Bbq.of.DooM is offline   Reply With Quote
Old 19th Jan 2008, 11:34   #14
Silver Shamrock
Banned
Old 19th Jan 2008, 11:57   #15
mm vr
mm vr's Avatar
Originally Posted by Silver Shamrock View Post
Where are they cheaper?
Actually, looking at the prices, they are actually cheaper than Corsairs. But their price range is really big (like the lower wattage model is $100 and the high wattage model is $250). Why is that?
Proof? I've seen nothing but praise for them.
Proof.
Old 19th Jan 2008, 12:12   #16
Silver Shamrock
Banned
Old 19th Jan 2008, 12:43   #17
mm vr
mm vr's Avatar
I think these sites don't stress the PSUs as much as they do at JonnyGuru. Not sure however.
Old 19th Jan 2008, 16:29   #18
CandyMan
Minimodder
I totally forgot about ava direct lol brain fart. BBq does have a very good point about never build a pc for a good friend or of anything for that matter you have the risk of losing a good friend when something goes wrong with the pc or anything for that matter. I think ill just steer him towards ava direct. There prices arnt really that terrible, yes i could build a system cheaper but this is a great alternative. Can you give me some advice on a power supply i just went with ozs because of all the hype but if there is a better one for less ill go that route. And can you recommend a good cpu cooler or did i pick out a good choice?
Old 19th Jan 2008, 17:44   #19
zr_ox
Whooolapoook
zr_ox's Avatar
zr_ox has yet to learn the way of the Dremel
Suprised nobody has mentioned Voodoo PC's yet
__________________
0ptimizm
:PC under review
zr_ox is offline   Reply With Quote
Old 19th Jan 2008, 17:47   #20
DaveVader
Fast Action Response Team
DaveVader's Avatar
DaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run Crysis
they have
Originally Posted by supertoad View Post
if he's dead-set on blowing his cash on a pre-build, voodoo/hp are good.
__________________
Current Rig: Gigabyte EP45 DS3L | E8400 | 4*1GB PC6400 | GTX 560Ti | 80GB Seagate/2*1TB Samsung F1/1TB WD Element
Origin name: Schizomida
DaveVader is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
