RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 22nd Jan 2008, 07:59   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Nvidia Hybrid SLI follow up
http://www.bit-tech.net/hardware/200...eview_part_2/1
After spending most of Friday afternoon talking with several Nvidia representatives about its Hybrid SLI technology, we're back again today to add some more insight into it. We've got more information on display support, the mGPU and some future considerations.
Tim S is offline   Reply With Quote
Old 22nd Jan 2008, 09:26   #2
naokaji
whatever
naokaji's Avatar
naokaji will become famous soon enough
could it be that there is only one display supported because sli doesnt support more than one either? just a thought.
anyway, good article on a technology that sure looks promising (even though it needs some refining).
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S
Opportunity is like delivery by DHL, it does not come to you, you have to track it down and chase it
naokaji is offline   Reply With Quote
Old 22nd Jan 2008, 09:31   #3
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Nope, there is support for two displays... but only one can be digital at the moment because of the hardware limitations.
Nvidia is also working on multi-monitors for SLI too (Hybrid SLI will get that from the outset)
Old 22nd Jan 2008, 10:29   #4
Darkedge
Supermodder
Darkedge is on a distinguished road
so still basically for first iteration avoid. I mean don't touch with 50ft bargepole.
I think all this could be done on graphics card and Nvidia as usual have gone for the expensive for customers, easy for them route which means buy new hardware for dubious results. Willing to give it time but even telling people now about what seems a fundamentally broken system seems pointless
Darkedge is offline   Reply With Quote
Old 22nd Jan 2008, 11:34   #5
naokaji
whatever
naokaji's Avatar
the way they are doing it you need both, a nvidia graphicscard and a nvidia mainboard for it to work, if they would have included a secondary weak gpu on the graphicscard for it you would only need to buy a graphicscard for it.
__________________
Old 22nd Jan 2008, 13:26   #6
zoom314
Multimodder
zoom314's Avatar
zoom314 is on a distinguished road
I'll have to remember that barge pole as I travel along the ole Erie Canal one day. But yeah, It needs development still in the 2560x1600 and display port res department.
zoom314 is offline   Reply With Quote
Old 22nd Jan 2008, 17:54   #7
completemadness
Hypermodder
completemadness is on a distinguished road
Well personally, i'm not at all enthused by this, However, it is early days, and there are many bugs to work out
Also, i note nvidia have been quiet on the XP front - again
completemadness is offline   Reply With Quote
Old 22nd Jan 2008, 18:33   #8
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
I think it's limited to Vista because of the way it handles video memory in scenarios like this. It's definitely not limited to SP1 though - that's one thing I asked.
Old 22nd Jan 2008, 19:28   #9
dmak
Minimodder
dmak is on a distinguished road
when they impliment displayport, doesnt that meet multi display will be easier? I thought displayport supported daisy chaining of monitors... or maybe that wa a future project. oh well
dmak is offline   Reply With Quote
Old 22nd Jan 2008, 20:03   #10
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Yep, that's definitely within DisplayPort's remit, although I would imagine that you'll again be bandwidth limited when it comes to the resolution/number of monitors you can daisy chain.
Old 23rd Jan 2008, 05:32   #11
Sark.inc
Multimodder
Sark.inc's Avatar
Sark.inc is on a distinguished road
How does daisy chaining the monitors work?
p.m me to keep thread clean
Sark.inc is offline   Reply With Quote
Old 23rd Jan 2008, 22:28   #12
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Best thing to do would be to read here: http://www.bit-tech.net/bits/2007/10..._look_inside/1
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
