RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 27th Jan 2008, 08:15   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Apevia X-Telstar Junior
http://www.bit-tech.net/hardware/200...lstar_junior/1
The Apevia X-Telstar Junior is a budget-option ATX chassis with a fan controller, temperature display, side-window and internal thermometer - but is it any good? We find out in our stress test and review!
Tim S is offline   Reply With Quote
Old 27th Jan 2008, 08:36   #2
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn is on a distinguished road
the two tone versions of this case visually dont look that bad but ya overall this is a poorly designed case but I guess if you were to modify the inner workings just a bit it could become decent but ya this would be a case I would pass on...
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding •
Retired Rig: Project F.E.A.R.
• TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory •
HourBeforeDawn is offline   Reply With Quote
Old 27th Jan 2008, 09:35   #3
Naberius
Multimodder
Naberius is on a distinguished road
That is pretty damn ugly, it screams tackiness, but quite good cooling performance somehow.
Naberius is offline   Reply With Quote
Old 27th Jan 2008, 09:38   #4
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin will become famous soon enough
erm, unless the cage is rivited, you can just remove 4 screws, and out it comes... just like EVERY other one on this chassis
__________________
Desky
E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690
Tulatin is offline   Reply With Quote
Old 27th Jan 2008, 11:10   #5
[USRF]Obiwan
Ultramodder
[USRF]Obiwan is on a distinguished road
And it got a damn door. as you know i hate doors. Doors are so 1999...
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..."
The answer is 42, so... whats the question again?
If you know what 'Peek' and 'Poke' represents, then you are probably as old as me.
[USRF]Obiwan is offline   Reply With Quote
Old 27th Jan 2008, 12:42   #6
LeMaltor
>^_^<
LeMaltor's Avatar
LeMaltor will become famous soon enough
I think it looks good in the first screen, the later ones where its all lit up like traffic lights make it look bad, it would do my head in at night too >_<
__________________
Welcoming the riff-raff since February 2009.
LeMaltor is offline   Reply With Quote
Old 27th Jan 2008, 15:47   #7
HandMadeAndroid
Multimodder
HandMadeAndroid is on a distinguished road
The black plastic combined with faux-chrome trimming really illustrates why this type of design is enjoying such a renaissance. Combine this with the rather ingenious front temperature monitor, the tastefully placed clear plastic side window and the beautifully crafted semi translucent fan and you’ve found a winner. Any components placed within this housing will scream cutting edge, echoing the sensibilities in taste so enjoyed by its owner.
__________________
Give them cake
HandMadeAndroid is offline   Reply With Quote
Old 27th Jan 2008, 16:11   #8
tranc3
It's a series of tubes!!
tranc3's Avatar
tranc3 will become famous soon enoughtranc3 will become famous soon enough
I've seen better looking tissue boxes.
But thats not to say Apevia Hasn't made good cases, i might be using one for hidden sun mod with a fairly similar design.
__________________
[AMD Kuma 7750 2.77 |Asus M3N78-EM|mushkin 4x1GB DDR800 |WD Caviar 500GB|GeForce EVGA GTS 250 512MB|OCZ StealthXStream 600]
tranc3 is offline   Reply With Quote
Old 27th Jan 2008, 16:20   #9
sheninat0r
What's a Dremel?
sheninat0r will become famous soon enough
Man, you went crazy there on the first page...
__________________
...with a crowbar.
sheninat0r is offline   Reply With Quote
Old 27th Jan 2008, 16:55   #10
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
That was the "toned down" version.
Old 27th Jan 2008, 17:30   #11
MonkeyNutZ
Crysis Fiend
MonkeyNutZ's Avatar
MonkeyNutZ is on a distinguished road
I find it amazing that people spend $40 on something that's supposed to protect your $1000+ PC hardware.
Lian-Li cheesecake (Lion = Rawrr!)
__________________
inCrysis.com - The largest Crysis fan site on the internets. (We're also #1 on Google for "Crysis")
Project: http://forums.bit-tech.net/showthread.php?t=147127
MonkeyNutZ is offline   Reply With Quote
Old 27th Jan 2008, 17:44   #12
samkiller42
KEEP IT CLEAN!
samkiller42's Avatar
samkiller42 is a jewel in the roughsamkiller42 is a jewel in the roughsamkiller42 is a jewel in the roughsamkiller42 is a jewel in the rough
That was shocking, It looks shocking also. Overall score of 4, have you reviewd anything lower that in the history of Bit? haha
Sam
__________________
The Rig: i7 920 D0, Gigabyte EX58-UD5, 12GB DDR3 1600mhz, BFG GTX295, Samsung 64gb SSD, WD 640gb Black, Samsung F2 Eco 1TB, Dell 3007WFP, Windows 7 RC.
The Netbook: Samsung NC10 Black, Intel Atom, 2gb DDR2
Xbox Live: samkiller42¦PSN: samkiller42¦Bungie: samkiller42
samkiller42 is offline   Reply With Quote
Old 27th Jan 2008, 18:35   #13
[WP@]WOLVERINE
Supermodder
[WP@]WOLVERINE's Avatar
[WP@]WOLVERINE is on a distinguished road
This is absolutely horrible i wouldnt buy a case like this even if it was £5. THeres way to many crappy cases on the market, do we need another one?....NO WE DONT. Theres more quality in a single Lian Li drivecage than in the entire Apevia range. And it seems that the design department are run by three blind mice
__________________
Intel i7 965 EE | 3gb Corsair DDR3 1600mhz | Asus P6T Deluxe OC Palm ed | Dual Asus ENGTX280 1gb Top ed@Sli | Corsair HX1000 | SB X-Fi Fatality | 5.1tb storage+300Gb Velociraptor | Lian Li pc201 | Samsung T240+931BF | Ms Natural 4000 | Logitech G5 | Logitech Z-5450.
[WP@]WOLVERINE is offline   Reply With Quote
Old 28th Jan 2008, 17:00   #14
Faunus
Modder
Faunus's Avatar
Faunus is on a distinguished road
What a poor case. But this leads me to a query:
I understand that bit-tech has to provide unbiased, fair reviews of various hardware for various uses and what-not, but what I don't understand is why we have to be subjected to reviews of hardware that only a Daily Mail reader would buy. Do you feel obliged to review these items because you are sent them by the manufacturer for review, or what? Surely, you must have much better cases sent in for review, that would be deemed worthy of our attention, instead of letting us know how crap something is?
Again, I understand that all is fair in love and war, but wouldn't it be a great idea if we had a couple of pages every month, filled with a run-down of the crap that you get sent, that you deemed not worthy to review because it was so poor, but you thought you would tell us about it, so we don't buy it (type-thing!)?
Don't get me wrong, I love Bit-tech and have been a reader for years now, but I just feel that sometimes I waste time reading a 4 page review, just to find out that something is a bit pile of steaming, soiled pants.
__________________
My hardware changes so frequently, there is almost no point in posting my specs. Instead, know that I own too many computers, that are nearly always turned on, and nearly never under any load.
$ chown -R nobody:nobody /
Faunus is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
