#1 |
Pewlius Caesar
bit-tech Staff
Zalman HD160XT Plus
http://www.bit-tech.net/hardware/200...zm160xt_plus/1
Are you looking for the ultimate home theatre case? Well, look no further because Zalman has sent it to us - we have a look at the HD160XT Plus, a 100 percent aluminium design with looks to die for. It even has a 7" touch screen to tie it all off. Excessive? Awesome? Costly? We find out.
__________________
#2 |
ITS OVER 8000!
Do I spy one of those awesome looking little Asus mATX gaming boards? Are you going to be reviewing it?
They are nice cases, but if I think the price needs to come down by £100 to make people even start considering them. |
#3 | |
Richard Swinburne
bit-tech Staff
#4 |
Freed on Probation
i dont get the point of the screen being that small...
if youre going to pay that much for a case you may as well go the whole hog and get the origenAE case with the 12" 1080p screen
__________________
I may be fat but at least I am not Ginger "The President is no longer a cross-eyed Texan warmonger, unelected, inarticulate, who epitomises the arrogance of American foreign policy" - Boris Johnson |
#5 |
Multimodder
Overkill, 90's hi-fi look, very much like a Yamaha AV amp or the like from back in the day. Touch screen totally pointless, and @ £400 far to expensive. Mutton dressed as lamb lol
__________________
Give them cake |
| HandMadeAndroid |
| View Public Profile |
| Find More Posts by HandMadeAndroid |
#6 |
a.k.a KazeModz
I think it looks great and the fact that the inside is also painted is a nice touch, I want to get my hands on this case or the Silverstone CW03 HTPC Case for my next HTPC build.
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding • Retired Rig: Project F.E.A.R. • TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory • |
#7 |
Richard Swinburne
bit-tech Staff
It's not painted, it's anodised - engrained colour into the metal oxide layer.
#8 |
I pwn all your storage
The LCD should be placed in an external enclosure with a battery back and wireless VGA...
#9 |
Licenced idiot.
Oh this is so confusing... I reviewed the original HD160, but it seems it has nothing to do with this case except the name. The side panels are from HD135 and the internal layout is KINDA 160-ish, but then again not. I like how they've paid attention to the HDD-cooling, and I love the fact that there's an actual cage like in HD135, but then again they've removed the nice wire-fanguards and replaced them with the cheapest cut-out versions. What's that all about?
The screen seems like a nice toy, and allthough there's no way I'd pay the premium to get a screen on my HTPC-case, I kinda see where that's coming from. If the HTPC is hooked up to a proper setup with a projector and a ton of amps then I understand it's sometimes nice to tweak some settings on the small screen and save the lamp of the projector... And if you can pay all the other equipments then hell, one 7" screen shouldn't blow the budget
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01 |
#10 |
ITS OVER 8000!
Sort of, an extra layer than can be coloured, added outside the original oxide layer of the Aluminium!
#11 | |
So Say We All
__________________
Hell hath no fury like a hippo with a machine gun.
#12 |
Licenced idiot.
Yeah first stick the movie to the drive and then run back to the office to make the settings and... It's just handy sometimes, ok?
__________________
#13 |
Richard Swinburne
bit-tech Staff
That's just being pedantic. :P I'm technically not wrong.
#14 |
ITS OVER 8000!
Yes, but at the same time, your not 100% right! I win!
Mwaah!
#15 |
So Say We All
or just use the remote
__________________
#16 |
Minimodder
Check out this insane HTPC case that fathazza mentioned (I thought the Zalman was $$$)
http://www.engadget.com/2006/01/25/o...me-theater-pc/ (12 HDDs?) |
#17 |
Multimodder
Yeash.. that seems like a right pain. 6/10 for usability.. the screen and remote are next to useless due to the software and the untoward cables make installing stuff a complete headache. Too many points there.
Plus that thing looks like a dust nightmare. Too bad the 10/10 features don't include some easy removable filters to go over those fans/holes. You'd have to wear the screw threads down when you open it for cleaning out. |
#18 |
Richard Swinburne
bit-tech Staff
Well technically nor are you, but I wasn't arsey enough to point it out muhahaha
![]() ![]() Joey - if you spend a lot of time getting it right, it has all the feature potential right there. You can use the remote or the screen or the buttons etc. Yes, no fan filters but not everyone wants them - the case should dissipate quite a bit of heat and should sit with very little airflow to be quiet. Filters just reduce the flow making it noisier. Personally I would like to have seen them, but I accept why people don't need them.
__________________
#19 |
Multimodder
i'd rather have one of those zalman TNN systems.
| Bionic-Blob |
| Find More Posts by Bionic-Blob |
#20 |
Ultramodder
I rather have a network 'play everything' player with a very good HD decoder chip, all sorts of outputs like dvi/hdmi/optical/digital outputs, usb in the front so i can stick a 8gb stick/ or external drive into to player and it plays the content. And a nice onscreen menu to browse te network for content and internet for content from youtube, shoutcast whatever from yout lazy chair
For example the snazio media players, or what about the Alienware bluray mediaserver ?
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
| Thread Tools | |
