Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 3rd Feb 2008, 08:42   #1
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Res Design #2
Been thunking about my new Res design for watery, so without delay...:
(the only thing thats accutate exactly is the outer size of the res and the thickness) Allthough you can't tell by the res, the holes at the top with the plugs, will actually be 11.8mm holes with a G1/4" tap at the top..
Last but not least, they aren't on the res, but there will be 8 holes in the outer side of the res, so that I can connect it directly to the case...
The res...:
Any ideas?
Mankz is offline   Reply With Quote
Old 3rd Feb 2008, 22:08   #2
r4tch3t
hmmmm....
r4tch3t's Avatar
r4tch3t is a hoopy frood who really knows where their towel is.r4tch3t is a hoopy frood who really knows where their towel is.r4tch3t is a hoopy frood who really knows where their towel is.r4tch3t is a hoopy frood who really knows where their towel is.r4tch3t is a hoopy frood who really knows where their towel is.r4tch3t is a hoopy frood who really knows where their towel is.r4tch3t is a hoopy frood who really knows where their towel is.r4tch3t is a hoopy frood who really knows where their towel is.r4tch3t is a hoopy frood who really knows where their towel is.r4tch3t is a hoopy frood who really knows where their towel is.r4tch3t is a hoopy frood who really knows where their towel is.
Looks good. Is it going to be made from a thick sheet of acrylic with the pattern cut out and then thinner acrylic in front and behind to seal it?
__________________
France just seems small, because it's so easy to conquer
r4tch3t is online now   Reply With Quote
Old 3rd Feb 2008, 22:25   #3
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
^^if you read the second pic it says what it is^^
Looks pretty sweet
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 3rd Feb 2008, 22:27   #4
r4tch3t
hmmmm....
r4tch3t's Avatar
Ah so it does, my bad.
__________________
Old 3rd Feb 2008, 22:32   #5
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
most of us miss stuff like that
no biggy
__________________
Old 4th Feb 2008, 19:57   #6
Mankz
dat steak
Mankz's Avatar
Final design.. Ying and Yang (ish) with smooth and jagged...
The Green loop is quite restrictive so that the DDC doesn't make too much noise..
Old 4th Feb 2008, 20:18   #7
Scirocco
Boobs, I have them, you lose.
Scirocco's Avatar
Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!
I'm not yet very knowledgeable as far as water cooling is concerned. Just been doing research, etc. for setting up my first loop. One thing that occurred to me when looking over your designs: will what you've laid out assist or hinder removal of air bubbles that form in the system? Really liking your ideas very much.
Scirocco is offline   Reply With Quote
Old 4th Feb 2008, 20:29   #8
Mankz
dat steak
Mankz's Avatar
I don't know really. I've tried to use flat surfaces on the res's so that no bubbles can collect, but I'ts going to be trial and error I think. Having the two port on each loop will allow easy top-ups (they aren't on the second res due to laziness)..
Old 4th Feb 2008, 20:36   #9
Mankz
dat steak
Mankz's Avatar
Right, res included and hose#d up. No more cos i'm bored stupid by this now
Old 4th Feb 2008, 22:24   #10
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
OMG '91 you just made my day
That is my water block you're using
__________________
Old 5th Feb 2008, 06:45   #11
Mankz
dat steak
Mankz's Avatar
I know... It was the only 775 block that I could find!
(its also rather nice
Old 5th Feb 2008, 22:10   #12
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
thanks, it really means alot to me to see if models is being used or not
__________________
Old 6th Feb 2008, 09:22   #13
Jamie
ex-Bit-Tech code junkie
Jamie's Avatar
Jamie has yet to learn the way of the DremelJamie has yet to learn the way of the DremelJamie has yet to learn the way of the DremelJamie has yet to learn the way of the DremelJamie has yet to learn the way of the DremelJamie has yet to learn the way of the DremelJamie has yet to learn the way of the Dremel
Personally think it would be cool to mount the DDC up against the res.
__________________
Discover books together at anobii
bit-tech hosted by Tsohost
Truly unlimited mobile data on GiffGaff
Use Quidco when shopping and get cashback
Jamie is offline   Reply With Quote
Old 6th Feb 2008, 13:25   #14
Thacrudd
Where's the any key?!?
Thacrudd's Avatar
Thacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run Crysis
I actually liked the first on better. Not to say the final isn't cool, but the first looked not as "hectic". is it supposed to say anything?
__________________
Just as you touch the lives of every life form you meet, so, too, will their energy strengthen you. Fail to live up to your potential, and you will never win... - Gaspar, The Guru of Time
Project: Andromeda
CurseMyStuff.com
Thacrudd is offline   Reply With Quote
Old 6th Feb 2008, 17:25   #15
Jackypoos
Will it blend?
Jackypoos has yet to learn the way of the Dremel
You gonna use the blue res for a gpu loop? Looking Ace =D
Jackypoos is offline   Reply With Quote
Reply
Tags
cooling
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
