Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Zotac GeForce 8800 GT 512MB AMP! Edition
http://www.bit-tech.net/hardware/200..._amp_edition/1
We take Zotac's factory-overclocked GeForce 8800 GT 512MB AMP! Edition for a spin to find out if an overclocked 8800 GT 512MB is better than a standard-clocked 8800 GTS 512MB. Read on to find out how it gets on...
__________________
#2 |
I feel your presents.
I agree with your review - for those that require a single slot solution - this is the cats whiskers. Otherwise, look elsewhere for your screen-filling polygon-prodding wundermachine.
__________________
MSI X58M - i7 920 4Ghz - 6GB Corsair - GTX260 648/2520 ::: Vote for bit-tech T - theevilelephant - "it sounded like bouncing around on a pogo stick, screaming in chinese while occasionally throwing a cat at a door." |
#3 | |
Neuken in de Keuken
Wow - I thought my Asus EN8800GT (Glaciator Cooler model) temps were high at 47 Idle 65 Load! This only goes up by 5 degrees when overclocked to 700/1750/2000 as well!
Looks like I have some room to play compared to the reference model then! Nice review though, I do agree with your conclusion though. My card was £179 when I bought it at the end of December. Most 8800GT's at stock speeds are now £30-40 less. But that's the way the cookie crumbles I guess!
__________________
#4 |
Fo' Rizzle Bizzle
Great review and it looks like a nice 8800GT OC'd to it's limits, but I really don't see the point in this card when an 8800GTS costs about the same and can OC'd higher...
Oh and you refer to the "Dinosaur Theme" on the card and box, it looks more like a dragon to me as I don't remember any fire-breathing dinosaurs from my last visit to the Natural History Museum
__________________
Intel Q6600 @ 3.2 GHz - eVGA nForce 680i MoBo - BFG GTX280 OC - 4GB XMS2 800 MHz DDR2, Enermax Infinity 720w PSU - Antec P182 |
| Whalemeister |
| View Public Profile |
| Find More Posts by Whalemeister |
#5 | |
Pewlius Caesar
bit-tech Staff
__________________
#6 |
Sir Bongaminge
Could it not be a fire breathing dinosaur? That's about as steeped in reality as a dragon is.
__________________
Pentium 4 CPU 3.4 Ghz | 1Gb + 2x512Mb Corsair DDR2 667 Mhz Sapphire Radeon HD 4770 512Mb| WD Raptor 36Gb, Seagate 300Gb | Asus P5LD2 SE Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups |
#7 | ||
Neuken in de Keuken
I fire-breathing dinosaur? Come off it!
__________________
#8 |
Sir Bongaminge
So a mythical winged lizard is ok, but a real life animal who just happens to gozz liquid napalm is crazy? Foul play I cry! Why do you think the dinosaurs died out if it wasn't for them accidentally setting everything on fire? The evidence is undisputable.
__________________
#9 |
sweet sweet hangin joben
nice mem...wish i could get there..
__________________
I love me some me e8400 @ 4.45 ghz..ac freezer 7..2 gigs patriot extreme 1150 mhz..abit ip35-pro..xfx 4770 with asus top bios @ 926 core/1077 memory..antec p182b..corsair hx620..seagate 500 gb 32mb cache THE best site ever...1600 signatures under the same avatar...time for a new one
#10 |
Multimodder
By playing with my own 8800GT, I've come to think that OC in terms of video isn't necessarily as interesting as it seems. Idealisticly, assuming that the graphics card was the only component in the machine, a %10 overclock would lead to a 10% increase in performance, ie. framerate. Seeing that I am struggling to get Crysis playable at my desired settings, benching around 25fps average. A 10% overclock would only yield a boost of 2.5fps. While every little bit does count, it's not really enough to push me into the smooth/playable realm. Hardly a big boost or anything.
At higher performance levels (eg 60fps) an OC like that leads bigger results, but then at that point you don't really need the extra performance anyhow. I'm guessing that performance games in the neighborhood of %30 or so would become meaningful, but from an overclock (on the 8800GT at least) thats not very realistic. So personally I'm not sure it's worth all the extra bother, as the impact vs investment (either in buyingi a PRE-OC'd card, or going through the trial/testing required to do it yourself) doesn't really justify itself. |
#11 |
What's a Dremel?
8800gt are quite cheap now...i mite get the overcloed evga
| Thread Tools | |
