Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 13th Feb 2008, 11:15   #1
Boxcarhobo
Multimodder
Boxcarhobo has yet to learn the way of the Dremel
Drivers for logitech X 530 5.1
I treid to put the plugs in all possible ways but still cant make all my 5 speakers work at same time.I can switch them so the back ones work or the front ones but not together.I have creative xtreme music sound card ,do you know how i can make them all work?
thanks
Boxcarhobo is offline   Reply With Quote
Old 13th Feb 2008, 16:59   #2
Golygus
Hypermodder
Golygus has yet to learn the way of the DremelGolygus has yet to learn the way of the Dremel
load the creative audio console. Move to the speaker tab and make sure its set to 5.1.
Update your creative drivers from Creative's website. Speakers don't have drivers.
__________________
Intel Core i7 920 @ 3.0GHz | Akasa Nero S | 3x2GB Corsair XMS3 | Gigabyte GA-x58A-UD3R r2 | Sapphire Radeon HD5850 Toxic | SB X-Fi Extreme Gamer | OCZ 120GB RevoDrive, 2 x 1TB WD 1002FAEX | 2 x Samsung SH-S223B DVD+RW | Corsair HX620W PSU | Windows 7 Pro 64bit
Canon EOS 7D | Canon EFS 17-55 f2.8 IS USM | Canon EF 70-200 f2.8 L IS USM | 2 x Canon Speedlight 550EX
Golygus is offline   Reply With Quote
Old 13th Feb 2008, 17:14   #3
Brett89
Ultramodder
Brett89's Avatar
Brett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run CrysisBrett89 can run Crysis
also, once you've install that Creative Audio Console, enable CSSM.
__________________
C2Q Q9550 @3.6 Asus P5Q Pro Turbo, 8GB Corsair, Xonar D2, 500 and 160 GB Seagate, eVGA 8800 GTX and an Antec P182.
Dell M4600 i7-2860QM, 32GB DDR3, Quadro 1000M, 256GB SSD, 1920x1080
Dell Mini 9, 1.6GHz Atom, 2GB DDR2 @533, 32GB SSD, OSX 10.6.7 Laser cut Apple logo
Brett89 is offline   Reply With Quote
Old 13th Feb 2008, 19:13   #4
Hazardous
Mod Master
Hazardous's Avatar
Hazardous has yet to learn the way of the Dremel
Ignore me
__________________
Beauty is in the eye of the beer-holder
Hazardous is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
