Old 19th Feb 2008, 03:42   #1
Ryu_ookami
Mod Master
Ryu_ookami's Avatar
Ryu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for presidentRyu_ookami should be considered for president
my networks screwed !
I have two Pc's that both connect to the internet one is connects directly though a wired connected to a wireless speedtouch router/modem. the other connects via a usb linksys adaptor wirelessly about 3 hours ago the second pc lost its internet connection no matter what I try it refused to connect. I've tried several things the main information I keep getting is:
"The network did not assign a network address to the computer."
The signal strength is showing as excellent.
I'm also getting this msg;
"You are associated with the access point but the internet could not be found."
Both computers have been fully virus scanned and no threats were found also both machine have been restarted with no change and the router has been switched off for 2 minutes then restarted and also the pc and the router have been switched off at the same time and restarted I'm running out of ideas any help would be appreciated. I know this thread is kinda jumbled but so is my brain at this point.
Ryu_ookami is offline   Reply With Quote
Old 19th Feb 2008, 04:54   #2
outlawaol
Geeked since 1982
outlawaol's Avatar
outlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysis
i had a similar issue. try turning off the pc, and flick the main on the back as well. hope that helps.
__________________
40D| 350D | 24-105 f/4L | 24-70 f/2.8 Sigma | 50mm f/1.8 | 75-300 f/4-5.6 Sigma | 420ex Speedlight
365 Daily Photograph | Smugmug
outlawaol is offline   Reply With Quote
Old 19th Feb 2008, 06:04   #3
johnmalc
That shouldn't happen....
johnmalc has yet to learn the way of the Dremel
1st rule of wireless networking: reboot the router. Usually sorts most things out..
EDIT ...Oops, just re-read the post, you've done it already.... not enough tea yet this morning!
johnmalc is offline   Reply With Quote
Old 19th Feb 2008, 06:11   #4
culley
Hypermodder
culley's Avatar
culley has yet to learn the way of the Dremel
Try turning off the WPA, ( I assume you are using WPA) and settting it to no security and see if it work's then. It could be todo with the security, happens at my work sometimes.
__________________
[Intel Core i5-2500k | Gigabyte P67A-UD4 | Corsair XMS3 4GB | 1GB Sapphire HD 6850 | 3TB HDD | Hiper 540W PSU]
[Ubuntu Home File Server]
[CompTIA A+ Certified][Cisco CCNA Certified]
culley is offline   Reply With Quote
Old 21st Feb 2008, 09:16   #5
Brooxy
Like a boss (but not a boss)
Brooxy's Avatar
Brooxy is the Cheesecake. Relix smiles down upon them.Brooxy is the Cheesecake. Relix smiles down upon them.Brooxy is the Cheesecake. Relix smiles down upon them.Brooxy is the Cheesecake. Relix smiles down upon them.Brooxy is the Cheesecake. Relix smiles down upon them.Brooxy is the Cheesecake. Relix smiles down upon them.Brooxy is the Cheesecake. Relix smiles down upon them.Brooxy is the Cheesecake. Relix smiles down upon them.Brooxy is the Cheesecake. Relix smiles down upon them.Brooxy is the Cheesecake. Relix smiles down upon them.Brooxy is the Cheesecake. Relix smiles down upon them.
Try going into dos prompts, and typing "ipconfig /release" and then flick off the wireless and resart it. If it's not working at this point, try ipconfig /renew.
Works for some of the systems at work, so might be worth a shot.
Brooxy is offline   Reply With Quote
Old 21st Feb 2008, 09:33   #6
badders
Neuken in de Keuken
badders's Avatar
badders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremelbadders has yet to learn the way of the Dremel
It may also be worth reserving the two IP's for the two PC's you use, and then setting them manually.
You don't say which OS you're using - try running the Windows network setup wizard on the Wireless PC.
__________________
Originally Posted by Silver51 View Post
John Hanlon standing on an oil pipeline during a blizzard, punching an angry polar bear in the balls. I heard he really did that once.
badders is offline   Reply With Quote
Old 21st Feb 2008, 10:25   #7
Tomm
I also ride trials :¬)
Tomm's Avatar
Tomm has yet to learn the way of the Dremel
Sounds like your DHCP on the router is malfunctioning for whatever reason. Assigning a static IP address is probably the work-around but it doesn't really tackle the problem.
As daft as it sounds, try giving the router a rest. My router is a cheap no-name thing and it seems to require being switched off for 20-30 minutes every day, otherwise it won't connect to the internet.
__________________
Carrot cake cheesecake
Shuttle SN85G4V2 | A64 3200+ / Apple PowerBook 12
Tomm is offline   Reply With Quote
Reply
Tags
network
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
