Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Cooler Master Cosmos S
http://www.bit-tech.net/hardware/200...ter_cosmos_s/1
Cooler Master has gone over the original Cosmos design, tweaked it and come up with this. It's got a new aluminium chassis, a revised cooling system and a funky touch-sensitive button. But can it stand up to our critical eye? There's only one way to find out...
__________________
#2 |
Supermodder
Brilliant case, much better than the original in my opinion (while the original was great to start with). Did you know the initial name was Cosmos Sport? I expect to see this baby in real life when I visit CeBIT on march 5 and 9. My own Cosmos 1000 mod (Protoss) will be on display there too.
When will Bit-Tech be visiting CeBIT ? |
#3 |
Banned
Deleted
#4 |
Supermodder
I have 4 harddisks in my Cosmos, and no problems with heat whatsoever. The key is having enough outtake fans so air will be pulled from the bottom, past the harddisks.
#5 |
Ultramodder
it looks like a BSG Cylon. This will probably my next case in follow up on my current dual wc Lian-li 70 case.
But I have just one question. Can it have a window in the door?
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#6 | |
Ultramodder
| Cheap Mod Wannabe |
| View Public Profile |
| Find More Posts by Cheap Mod Wannabe |
#7 |
Sir Bongaminge
Slight wording problem in the article
Last page: "Either way, the temperatures for the Cosmos S are less than we could have hoped for " Do you mean "Either way, the gains in temperature reduction for the Cosmos S are less than we could have hoped for", as what you wrote is actually that the temperatures in the Cosmos S are lower than you could have hoped for, implying it has amazing cooling. Good review though, v. pretty case, if crazy packaging.
__________________
Pentium 4 CPU 3.4 Ghz | 1Gb + 2x512Mb Corsair DDR2 667 Mhz Sapphire Radeon HD 4770 512Mb| WD Raptor 36Gb, Seagate 300Gb | Asus P5LD2 SE Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups |
#8 |
Player Character
bit-tech Staff
"Either way, the temperatures for the Cosmos S are less impressive than we could have hoped for "
Fixed for clarity.
__________________
#9 | |
whatever
isnt that the case that you had some news some time ago that it would fit a rad in the top? if my memroy serves me correct please test out if that actually works, if not ignore, anyway, good review, the case looks like it has some potential, just too much plastic on it.
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S Quote:
#10 |
Ultramodder
Also, what are the case outer dimensions?
__________________
#11 |
Player Character
bit-tech Staff
(W) 266 x (H) 598 x (D)628 mm
__________________
#12 |
Banned
Deleted
#13 |
Player Character
bit-tech Staff
Not entirely true actually. Over cooled drives fail more often than over heated drives.
http://www.engadget.com/2007/02/18/m...resting-thing/
__________________
#14 |
Multimodder
for me there is nothing really new or gripping about the case,that said the packaging looks cool...
#15 | |
Acrylic Heretic
__________________
Latest Builds: "Movie Sign!" CheckMate - MotM May '09 |
| E.E.L. Ambiense |
| Find More Posts by E.E.L. Ambiense |
#16 |
Acrylic Heretic
My next case. Hands-down. Thanks, CM. And thanks BT for the review!
__________________
| E.E.L. Ambiense |
#17 |
Licenced idiot.
Maybe I just didn't read the review carefully enough, but to me it seems just like the original stacker with some shapes slapped on the outside of the case. I don't like it at all.
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01 |
#18 |
Austerity - It's the only way
#19 |
Aquatuning UK
What about test to see if the 120.3 radiator actually fits in the top?
#20 | |
Acrylic Heretic
Edit: Well, at least without cutting on it, they won't.
__________________
Latest Builds: "Movie Sign!" CheckMate - MotM May '09 Last edited by E.E.L. Ambiense; 22nd Feb 2008 at 18:32. |
| E.E.L. Ambiense |
| Thread Tools | |
