#1 |
Supermodder
TF2 Framerate issues?
Let me preface this by saying I normally(up until today) get at least 40fps, usually its above 60. Today I came home and updated the game and now I am getting almost unplayable frame rates. I get 20-30 when no action is happening and about 10-20 when something is. This doesn't seem right because I was getting perfect buttery smooth fps from the time the game launched until now. The only other thing that has changed with my PC is I installed Audiosurf via steam. Anyone else had this problem or have a fix?
#2 |
Ultramodder
Specs?
Also check my old thread, that update apparently fixed problems my friend was having. Try portal and EP2 to see if things happen in there too.
__________________
Q6600 | HD5870xxxUBERversion | 6gb of RAM | Several TBs of hdd now my server|Athlon 64 3700(2.64ghz)|7800gs|2gb XMS 2-3-3-6|2tb+ total HD space... In raid|I have a problem. Laptop: HP EliteBook, its fast! |
#3 |
Supermodder
Steam forums addressed the issue. Apparently the server software this patch increased the load on the CPU a great deal. This seems to be what is going on because lowering/raising settings did absolutely nothing for frame rate. Full AA/AF was no different than no AA/AF. Even reducing the resolution from 1280 x 1024 to 800 x 640 did change the frame rate and when I alt tabbed out it was using much more CPU and ram than it normally does. Guess I will just have to wait for them to fix it.
| Tags |
| pc, pc gaming |
| Thread Tools | |
