Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 24th Feb 2008, 22:35   #1
keef247
That'd Get Ruined
keef247's Avatar
keef247 has yet to learn the way of the Dremel
boost wifi for house to summerhouse signal
basically... we have a summerhouse at the bottom of our garden... around a quarter of an acre i guess?
it'd be nice to use my wifi seeing as i now have a laptop with wifi...
i don't really want to change routers seeing as it's not mine and its provided by sky and we're not whiling to risk getting banned by using a hacked firmware/user details trick on another router.
so basically what I'm asking is what usb adapter could i get that will boost my wifi connectivity like some kinda mini satalite dish or something? i saw some on youtube - that'd be ideal if so.
any ideas? links please to uk sites if i have to purchase anything.
cheers people.
keef247 is offline   Reply With Quote
Old 24th Feb 2008, 22:38   #2
tranc3
ADHD Modder
tranc3's Avatar
tranc3 has yet to learn the way of the Dremeltranc3 has yet to learn the way of the Dremel
There's this thing. like a "wifi can" or something like that. idk how far it'll actually go. or any thing actually. just remember seeing it.
*Edit: Googleing "wifi can" has allot of home made results. so check that out see if you find any thing i didn't really look just glanced.
__________________
[AMD Kuma 7750 2.77 |Asus M3N78-EM|Mushkin 4x1GB DDR800 |WD Caviar 500GB|GeForce EVGA GTS 250 512MB|OCZ StealthXStream 600]
tranc3 is offline   Reply With Quote
Old 24th Feb 2008, 23:24   #3
keef247
That'd Get Ruined
keef247's Avatar
cool that sounds interesting but what about my built in wifi on my pcb on the lappy... i'm screen or can i get some kinda of usb antenna or a new wifi card with a insane aerial?
Old 25th Feb 2008, 01:33   #4
eeevan
Dremel Master
eeevan's Avatar
eeevan has yet to learn the way of the Dremel
Whoah Whoah Whaoh! Before buying a new router or antenna, try this.
I'm usually a cynic of such homebrew solutions (as they don't usually work), but jesus, this one does. I managed to boost my signal strength by a good 30% in the direction the antenna was pointed.
Just don't rush putting it all together.
__________________
E6850 @ 3.85Ghz - 4GB PC6400 - 500GB WD + 250GB Seagate + 1TB Spinpoint - X-Fi Xtreme Audio - Asus P5K-E WiFi/AP - XFX 8800 Ultra @ 650/1100 - Antec Twelve Hundred
eeevan is offline   Reply With Quote
Old 25th Feb 2008, 02:39   #5
Oreon_237
CHEA BRO!
Oreon_237 has yet to learn the way of the Dremel
Yes but wouldnt that mean that if you wanted to get wifi in an area thats aimed away from the parabolic refletor youd have to move/remove the reflector.
Try using a usb wifi dongle attached to a deep fry thing found at asian stores making a wok fi like this http://www.usbwifi.orcon.net.nz/.
Oreon_237 is offline   Reply With Quote
Old 25th Feb 2008, 06:20   #6
Fod
what is the cheesecake?
Fod's Avatar
Fod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run Crysis
.... run a length of cat-5 along your garden fence?
ghetto is often best!
__________________
"This face is left intentionally blank."
XBL/PSN/Steam ID: FodT
Fod is offline   Reply With Quote
Old 25th Feb 2008, 16:02   #7
notatoad
pretty fing wonderful
notatoad's Avatar
notatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremel
if the cantenna isn't enough, get another router running dd-wrt and put it in repeater mode
__________________
13" macbook air and a boxee box. minimalism ftw.
notatoad is offline   Reply With Quote
Old 25th Feb 2008, 16:07   #8
MrWillyWonka
Chocolate computers galore!
Moderator
MrWillyWonka's Avatar
MrWillyWonka has yet to learn the way of the DremelMrWillyWonka has yet to learn the way of the DremelMrWillyWonka has yet to learn the way of the Dremel
I've done that Windsurfer one before (there is a thread on the forum somewhere about it) and indeed it works! Just point it in the direction you want and hey presto. Although the easiest thing to do is to get a wireless repeater and stick it by a window somewhere, if there is nothing in between the repeating and summerhouse there shouldn't be a problem at all.
MrWillyWonka is offline   Reply With Quote
Old 25th Feb 2008, 16:09   #9
johnmalc
That shouldn't happen....
johnmalc has yet to learn the way of the Dremel
For what its worth, here's how I did it over 2.5km...
http://www.deviantforums.com/long-di...+distance+wifi
The recipient can stream movies from our database over it!!!
johnmalc is offline   Reply With Quote
Reply
Tags
network
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
