RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 26th Feb 2008, 12:09   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Thermaltake Toughpower QFan 650W
http://www.bit-tech.net/hardware/200...er_qfan_650w/1
Thermaltake introduces a new QFan to its Toughpower range, adding this new 14cm "silent" performer to modular connectivity and a five year warranty. Is it enough to tempt you away from everyone else in the busy mainstream market?
Tim S is offline   Reply With Quote
Old 26th Feb 2008, 15:10   #2
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has a spectacular aura aboutCupboard has a spectacular aura about
Is there any particular reason why so many manufacturers (I know they are from the same OEM) are choosing to put the silly piece of plastic there? They much have done some research into it, because otherwise they wouldn't have changed from the norm. This must surely mean that there is some benefit to it?
Great review though as always
Why did you test it at 800W though? Its a 650W power supply isn't it?
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker
Samsung Q45.
Cupboard is online now   Reply With Quote
Old 26th Feb 2008, 15:14   #3
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Good spot thanks, user error - the bottom portion of the template wasn't removed...
Old 26th Feb 2008, 21:53   #4
dmak
Minimodder
dmak is on a distinguished road
agreed on the mutirail thing... When they first advertised this as a feature to look for a was a bit unsure, cause really, there are some single rail ones out their with like 60 amps... oh well I guess this is what the market wants
dmak is offline   Reply With Quote
Old 27th Feb 2008, 01:24   #5
Amon
inch-perfect
Amon's Avatar
Amon is on a distinguished road
Originally Posted by bit-tech
Your workplace looks like it needs quite a bit of dressing up...
__________________
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP::Fanatec 911 Wheel+Pedals
Amon is offline   Reply With Quote
Old 27th Feb 2008, 07:33   #6
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
lol, that's not our offices - that's in Enermax's UK offices (where we borrow their equipment to test the PSUs ourselves).
Old 27th Feb 2008, 19:24   #7
Woodstock
So Say We All
Woodstock's Avatar
Woodstock is on a distinguished road
and they dont care that your testing other company's psus, which may be cheaper/better then there own?
__________________
Hell hath no fury like a hippo with a machine gun.
Woodstock is offline   Reply With Quote
Old 27th Feb 2008, 20:20   #8
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Nope, they trained us to use the machine and then they just leave us to it. The power supply manufacturers (collectively) actually want their units tested properly (i.e. with a load machine), so they're more than happy to support us where they can with allowing us to use the machinery.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
