#1 | |
likes to touch your special places
Winlogon.exe causes BSOD (0xc0000005)
I've started receiving a lovely BSOD right after the Windows XP Welcome Screen. It reads:
Anybody remember a fix?
__________________
The wickedness of women is greater than all the other wickedness of the world! God's sentence hangs over all your sex. |
#2 |
How many wifi's does it have?
I vote for Windows re-install... that is the work of a virus or malware. If your anti-virus is unable to scan it, then probably you should uninstall it, and try a different one. You can even try trial version of anti-viruses, just for a moment (NOTE: don't have several anti-virus installed, conflict will occur, and render one or them or both to mal-function, or not scan properly). Remember, as you just want the virus out of your system and know were it comes from (If possible).
If you get that after installing a fresh windows install, then it could be your HDD that has a bad area on it.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB |
#4 |
I got the "Session manager" one too, this morning. Hm. It looks like it's either going to be the hard drive failing (which makes sense, as this is the spill victim of yesterday...) and just generally throwing up error messages; or indeed some malware came with some stuff I found online.
My fairly fresh (last night) install of XP doesn't boot anymore at all now, though, so I'm back on the ol' LiveCD. I'm going to give Ubuntu a try later tonight, and if that starts failing too, I'll save up my pennies for some new hardware. Thanks for the replies
__________________
| Tags |
| windows |
| Thread Tools | |
