Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Gigabyte - better cases, mobos and crazy coolers
http://www.bit-tech.net/news/2008/03...razy_coolers/1
CeBIT 2008: Gigabyte has some cases that are really stylish, but balance is restored in the universe because it also has a silly cooler.
__________________
#2 | |
whatever
rofl.... self contained wc kit for the ram... this isnt madness, this isnt sparta, this is plain silly.
any idea on launch date of the p45 boards?
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S Quote:
#3 |
Ultramodder
Ok, is it me or is this getting out of hand. First we have to deal with this ridiculously huge thing. And now a self contained watercoolingkit for your memory?
I dont even want to guess whats next...
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#4 |
Spoon? What spoon?
Just tell me when the iRAM 2 that takes DDR2 up to 32GB is released, then I'll beat their door down for one.
| Bluephoenix |
| View Public Profile |
| Find More Posts by Bluephoenix |
#5 |
DUR HUR
Wow I thought you couldn't get more pointless and OTT that Scythes new cooler but gigabyte have topped them in the stupid olympics. Surely heatspreaders on RAM is way more than adequate?
#6 | |
Why not? I own a domain to match.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#7 |
Spoon? What spoon?
I'm using an iRAM with 4GB DDR for pagefile right now, only thing that stops me from using one as a primary run drive is the size.
with 32GB DDR2 that would be enough for a full Vista Ultimate install and shadow copy/restore and pagefile space. |
| Bluephoenix |
#8 |
Hypermodder
Wow, nothing better than unnecessary cooling that blocks airflow, increasing other part's temps, and blocking other memory slots.
__________________
Intel Core 2 Duo E4300 @ 3.04GHz | OCZ Platinum Rev 2 @ 760MHz (4-4-4-12) | Asus P5K-E/WIFI-AP | Asus EAX1950 Pro | Coolermaster CM690
Corsair VX450 | Samsung 932B | Logitech G5/Media Elite/Z-3 |
#9 |
Ultramodder
I really like the power button on the Solo 228 or whatever it's name is. I like the P45 board design too.
__________________
C2D e6700 @ 3.25 Asus P5n-e SLi, 4GB of OCZ Platinum, Xonar D2, 320 and 160 GB Seagate, eVGA 8800 GTX and an Antec P182. C2D T7500 2.2ghz, 2GB DDR2, Quadro NVS 135M 14.1in screen
#10 | |
whatever
you can even run the ram naked, the heatspreaders dont do much anyway, no airflow through them, crappy tim inbetween, only marginally bigger surface than the modules themself, sure, if you oc your ram like crazy you are going to need some cooling, but even then a simple fan blowing over them is enough.
__________________
#11 |
Richard Swinburne
bit-tech Staff
I actually looked and there's still only the iRAM and 8GB DDR1. I got the impression they aren't making them anymore, they are concentrating on the chassis/thermal division, mobos and MIDs/notebooks now.
#12 |
Multimodder
Richard/Tim/Bit-tech people; is there any chance you could try to get hold of Gigabyte and ask them of any news on a new version of the i-RAM supporting DDR2?
And I have to join in here: A self-contained watercooling kit for the RAM!? That is simply.. crazy and sad.
__________________
- Rexxie Sanity is a full time job. |
#13 |
Pie Eater
quick question(s):
1) anyone know how to find out the temps of ram through software, rather than using a thermal sensor on the sink itself in the case? 2)Having found the temp, what is 'safe', and what might mean cooling attention should be required? 3)if ram cooling isnt an issue, why do companies bring out crazy things like the ocz sink with additional wc'ing on their ram or like gigabyte have above? is it purely for dip sticks who like pimpin their shiate to the max for what i might be mistaken in calling their e-peen? Just thought it might be nice to know, not in standard cases but in the most crazy, out of this world high spec system on which someone has oc'd the nuts off of it, answers on a postcard, please peace fatman
__________________
Core 2 Quad Q6600 @ 3600Mhz ¦ Asus Maximus II Formula ¦ ATI Radeon 4890 (1000Mhz Core + 1200Mhz Mem OC) ¦ 2x2G Corsair Dom. PC 8500 @ 1080Mhz ¦ Aquacomputer WC ¦ Creative X-Fi Fatal1ty ¦ 150G Raptor, 2x1500 + 1x750 + 2x500 Seagate (SATA2) ¦ Pioneer DVD burner ¦ Lian Li - PC 73SL Aluminium Silent Server Case ¦ Dell 2007WFP 20" Widescreen ¦ Logitech Z-5500 5.1 Speakers ¦ Sennheiser HD270
#14 | ||
whatever
2. safe? hmm, well, i'd say ~50C, sure ic's wont get damaged instantly even with temps at ~100C, but i woudnt risk more than ~70C after several hours full load. i'd add a fan based on voltage rahter than temp, 2,3+ = fan recommended. 3. marketing and standing out of the crowd (they dont make the actual chips themself, so they have to find a way to separate themself from other brands) and same reason as why thermaltake is showing off a 2kw psu at cebit, epeen.
__________________
#15 | |
Richard Swinburne
bit-tech Staff
#16 |
Hypermodder
Just how hard do you have to spank your RAM to justify those coolers? Now that they exist I'm guessing its only a matter of time before somebody decides to try to see how far you can you before they melt their RAM chips.
| johnnyboy700 |
| Find More Posts by johnnyboy700 |
#17 |
Spoon? What spoon?
| Bluephoenix |
#18 | |
I *am* a Dremel
__________________
Q6600@3GHz / AC Freezer 7 Pro / Gigabyte EP35-DS3R / 8GB OCZ Platinum PC6400 / EVGA GTX260 SSC / LG DVDR / 9TB HDD /
OCZ Modstream 780W / CoolerMaster 590 case / Dell E248WFP / Saitek Eclipse II / Logitech G9 / Ubuntu 9.10-64 |
#19 |
a.k.a KazeModz
water cooled memory in that form, huh make it so it can cool 4 sticks and it might be worth or if anything at least it looks neat lol
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding • Retired Rig: Project F.E.A.R. • TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory • |
| Thread Tools | |
