Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Intel talks P45, G45 and X48
http://www.bit-tech.net/news/2008/03..._g45_and_x48/1
CeBIT 2008: Intel talks to bit-tech and details its next generation 4-series, Eagle Lake chipsets which should arrive in May.
__________________
#2 | |
whatever
I don't see a release date for p45? did i miss it or is it not there? other than that, looking good.
release date in TimS's post... it says may... i'm a bit well, stupid today.
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S Quote:
#3 |
Ultramodder
As long as DDR3 cost 6 times as much as DDR2 and at the same performance level, you are a thief of your own wallet...
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..." The answer is 42, so... whats the question again? If you know what 'Peek' and 'Poke' represents, then you are probably as old as me. |
#4 |
quad fuelled, GTX200 powered
can't wait for the 8-phrase Abit iP45 Pro
__________________
of Corsair Dominators @ 1528Mhz 8-8-8-24 // BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240 |
#5 | |
Richard Swinburne
bit-tech Staff
Obivously, there's still P45 for those wanting a decent oc and DDR2 etc and X38 still in the marketplace. Everyone has said by Q3 DDR3 prices will drop largely - it'll still be expensive until AMD launches its DDR3 products next year but there will be a significant shift starting in Q3-Q4. X48 should be released more this month into next and P45 is May-June. |
#6 |
Madeira's banana is the best!!!
i wonder were is larabee..... or whatever its name is......
__________________
Renegade X - 0.40 Release! <---- CLICK! |
#7 |
Richard Swinburne
bit-tech Staff
I asked, no comment was given.
#8 |
Minimodder
Love the miniITX board. Imagine what you can do with it. Ultra small HTPCs.
#9 |
what is the cheesecake?
mini-ITX g45?
new HTPC, kthxbai.
__________________
"Sesame Street is brought to you by the letters P, W, N, the number 3, and the letter D." I'm a pretentious git with a camera. ISPs want to spy on you. Join the fight against phorm XBL/PSN/Steam ID: FodT |
#10 |
hmmmm....
I have 2 miniITX cases sitting at home not being used, if these are cheap enough for a student I will be getting one.
__________________
Fight my Brute
The quantum limit of reality might be scaled up because we're all holograms. Obviously. Once more we see that sufficiently advanced physics is indistinguishable from getting really stoned. From here |
#11 |
complete spanner
The current announcements were hardly unexpected. The big revelations are being saved for IDF (Nehelam family and Larabee), which is less than a month away, so that the announcements aren't competing as much with other companies press releases for attention.
__________________
My sweetest downfall |
| genesisofthesith |
| View Public Profile |
| Find More Posts by genesisofthesith |
#12 |
Minimodder
Does the 'Intel Extreme Tuning Utility' allow you to clock each core individually on a quad core? Same question for NVIDIA's ntune if anybody knows.
#13 |
hmmmm....
Short answer no,, long answer no, all the cores run at the same speed regardless. It is an overall clock speed. Even when some cores are not used the power saving kicks in and powers them down but they stay at the same clock speed as the other cores.
As for nVidia probably not, should be possible due to being essentially two cards slapped together.
__________________
Fight my Brute
#14 |
Minimodder
Thanks r4tch3t, I knew that the Intel '2 Core 2 Duo dies in one package' quad cores couldn't adjust the clock speed of each core independently but I thought I'd ask anyway; maybe you can force a core to run at a different speed even if the processor can't do so automatically. After all each core in a Core 2 Duo die can adjust its speed independently so why can't a quad core?
About ntune I meant can it clock the cores of an Intel quad core processor independently. Talking of NVIDIA, with Intel opening up fast transfer paths in the P45 and NVIDIA chipsets going integrated exclusive does this mean a NVIDIA graphic card could perform better on an Intel chipset than an NVIDIA one .
| Thread Tools | |
