RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 11th Mar 2008, 16:45   #1
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Sapphire updates graphics card cooling
http://www.bit-tech.net/news/2008/03...card_cooling/1
CeBIT 2008: Always keen to add variety and value to its product range, Sapphire showed bit-tech how it has updated its HD 3870 range to include single slot and passive cooling.
Bindibadgi is offline   Reply With Quote
Old 11th Mar 2008, 16:49   #2
cjoyce1980
Supermodder
cjoyce1980 is on a distinguished road
wouldn't mind the toxic card, but only if the pricing was right
cjoyce1980 is offline   Reply With Quote
Old 11th Mar 2008, 17:05   #3
genesisofthesith
complete spanner
genesisofthesith's Avatar
genesisofthesith is on a distinguished road
I do like the vapor x design, and understand why a single slot design was chosen for the 3870xt, but can't help but hope a dual slot version is made that exhausts the heat out the back, allowing even greater cooling performance, and lower noise.
Is the VCT tech exclusive to sapphire, or are they just the first to licence the design?
__________________
My sweetest downfall
genesisofthesith is offline   Reply With Quote
Old 11th Mar 2008, 17:09   #4
Naberius
Multimodder
Naberius is on a distinguished road
Love the appearance of that board, shame its for AM2.
Naberius is offline   Reply With Quote
Old 12th Mar 2008, 03:41   #5
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn is on a distinguished road
so as far as Sapphires motherboards are concerned is it DFI that makes it for them? as you can find the exact same boards from DFI and if thats the situation whats the real difference typically between the two or is there any?
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding •
Retired Rig: Project F.E.A.R.
• TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory •
HourBeforeDawn is offline   Reply With Quote
Old 12th Mar 2008, 07:55   #6
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Only the 790FX. I don't know who makes the 770X.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
