Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 12th Mar 2008, 16:41   #1
Anobis
Multimodder
Anobis has yet to learn the way of the Dremel
Corsair padlock easy to hack
The Corsair padlock seems to be a real easy to hack pies of protection.
Just by soldering a 10K to the battery and pin seen on pic. You can read the Corsair padlock without ever knowing the code.
After witch you have a normal usb stick
So if you ever verged your code. Now you know how to get your data
Link to a page. This is in dutch do.
http://veerboot.tweakblogs.net/blog/...k-hacking.html
__________________
Sorry four my bad English. If you feel offended by it then to bad four you!
Powerd by:
AMD 4800+ X2, 4x 500GB Sata2 Raid0, 2GB DDR, Asus Sli Premium, Asus 8800GT TOP SLI
Anobis is offline   Reply With Quote
Old 12th Mar 2008, 16:43   #2
E.E.L. Ambiense
Acrylic Heretic
E.E.L. Ambiense's Avatar
E.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run Crysis
LOL. Sweet.
__________________
Latest Builds:
LilyPC V.2 • BIO-A10 - MotM Jul. '12 Nominee Loser! • "Movie Sign!" - in progress • CheckMate - MotM May '09 Nominee Loser! • BluBawx I - MotY '09 Nominee Loser! • Lumi่re Noire - MotM Apr. '08 Nominee Loser! • NOTalis w/ MNPCTech • "Building Better Worlds" - MotM Feb. '08 Nominee Loser!
E.E.L. Ambiense is offline   Reply With Quote
Old 12th Mar 2008, 17:31   #3
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has yet to learn the way of the DremelFirehed has yet to learn the way of the DremelFirehed has yet to learn the way of the Dremel
Whoops.
This is why I only trust open source software encryption with a long passphrase. Given the cross-platform nature of the device (if Bit's ads are anything to go by) it seemed that the 'key' side of things would just be a little power flipping thing that doesn't let the drive turn on until you've put in the code, but that seems WAY too easy to bypass.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 12th Mar 2008, 18:21   #4
ryanjleng
ryanjleng has yet to learn the way of the Dremel
What a hoot!
ryanjleng is offline   Reply With Quote
Old 12th Mar 2008, 19:48   #5
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the DremelCupboard has yet to learn the way of the Dremel
If this flash drive relies on a battery to work, what happened when it runs out?
__________________
i7 920, 5870, 6GB Corsair all in an Intel DX58SO; 60GB Vertex, 1.5TB F2; Fractal Design R2
ThinkPad Edge 13.
Cupboard is offline   Reply With Quote
Old 12th Mar 2008, 20:07   #6
freedom810
Supermodder
freedom810's Avatar
freedom810 has yet to learn the way of the Dremelfreedom810 has yet to learn the way of the Dremel
Or, keep your laptop next to you everytime its on?
freedom810 is offline   Reply With Quote
Old 13th Mar 2008, 14:14   #7
OtakuHawk
The Post of The Beast
OtakuHawk has yet to learn the way of the Dremel
any 'secure' usb dongle.... isn't.
use a regular one and TrueCrypt instead.
__________________
Ultra-Lurker
OtakuHawk is offline   Reply With Quote
Old 13th Mar 2008, 15:41   #8
Anobis
Multimodder
Originally Posted by Firehed View Post
Whoops.
Just cool down the memory in some ons laptop. Place the memory in an other laptop and let it boot on a disk that makes backups of memory. Lots of inscription software leaves your code in memory. Dis will keep it active four your session. By cooling the memory you slowdown the data los of the memory. And most times you find most parts of the code in the backup if not complete And if not complete its a lot easier to brake the code, Then without having parts of it. But you whil need to know what your looking four ore understand what your looking at
And yes. The only thing the numpad dos is after you give the code correctly it while gives power to the upper part. And no data. So its easily by past The only really protection it has is the glue. Wen you don't heat the thing up with a heat gun. You while brake off a 3point transistor. But this is easy soldered back on
__________________
Powerd by:
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
