RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Mar 2008, 11:39   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Firefox 3 to be faster than the competition
http://www.bit-tech.net/news/2008/03..._competition/1
Firefox 3.0 beta 4 simultaneously shows jumps in Java performance, while lowering its memory footprint.
Tim S is offline   Reply With Quote
Old 13th Mar 2008, 11:51   #2
cjoyce1980
Supermodder
cjoyce1980 is on a distinguished road
about time too! firefox 2 is a mess
cjoyce1980 is offline   Reply With Quote
Old 13th Mar 2008, 12:10   #3
The Chugnut
Minimodder
The Chugnut's Avatar
The Chugnut is on a distinguished road
Define "mess."
I think we're using two different programs here.
The Chugnut is offline   Reply With Quote
Old 13th Mar 2008, 12:52   #4
ChromeX
Ultramodder
ChromeX's Avatar
ChromeX will become famous soon enoughChromeX will become famous soon enough
Originally Posted by The Chugnut View Post
Define "mess."
Yeah i've had no problems at all with FF2
__________________
3Ghz P4E, asus P4C800E-deluxe, 2GB OCZ (2x1024), Sapphire HD 3850, SB audigy 2 zs
ChromeX is offline   Reply With Quote
Old 13th Mar 2008, 12:54   #5
The Chugnut
Minimodder
Unless that was clever use of sarcasm that somehow went straight over my head. I would feel ashamed. :O
Old 13th Mar 2008, 13:05   #6
Firehed
Why not? I own a domain to match.
Firehed's Avatar
Firehed has a spectacular aura aboutFirehed has a spectacular aura aboutFirehed has a spectacular aura about
Define "mess."
Everyone's had really mixed experiences with it. Sometimes it would crash all the time for me, and sometimes it ran perfectly for the longest time. For a beta, FF3 seems in very good shape other than my extensions being incompatible.
I never pay attention to memory use though - there are so many factors that go into it, not least of which being how much RAM the system has. All of the systems I use day-to-day now have 4GB, so 150-250MB out of there is not only a fairly small percent, but it wouldn't be used in any other way so if it can speed up the browser then so much the better.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net
40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8
MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD
Firehed is offline   Reply With Quote
Old 13th Mar 2008, 13:10   #7
Kode
Multimodder
Kode's Avatar
Kode is on a distinguished road
firefox 2 isnt great for memory usage, thats probably what he meant.
Im a PHP Web Developer, and use firefox to develop, as well as any other websites i have open at any one time, before a couple of weeks ago this machine only had 512mb in it, and would frequently freeze as the system was using 600-800mb (plenty of paging going on) with firefox taking up between 300-500mb, its now got 1.2GB in it and is much happier, but firefox is still almost always the number 1 user of memory, at the moment i only have 2 instances open, one with 2 tabs, and one with 6 tabs and its using 146mb, only program beating it is photoshop which is consuming 170mb
Kode is offline   Reply With Quote
Old 13th Mar 2008, 14:10   #8
TreeDude
Multimodder
TreeDude is on a distinguished road
I have not had a memory issue with FF since version 1.5. FF2 has been great for me. It does use a bit more memory that I would like, but it has been rock solid for me since it came out. I am now using FF3 b4 though. The first 2 betas crashed pretty often, but beta 3 and 4 have been very solid. I am however getting the Vista styled buttons in XP, not sure if that is a bug though.
TreeDude is offline   Reply With Quote
Old 13th Mar 2008, 14:33   #9
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn is on a distinguished road
Personally I prefer FF2 to FF3 but Im sure it will get better also why did they drop the back and forward nav buttons, granted you can just use your keyboard to do this but still wondering or am I over looking it completely?
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding •
Retired Rig: Project F.E.A.R.
• TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory •
HourBeforeDawn is offline   Reply With Quote
Old 13th Mar 2008, 14:44   #10
Brett89
Ultramodder
Brett89's Avatar
Brett89 is on a distinguished road
I love firefox 3, i'm using it on all my computers, fast. The redesigned UI is different, but now I'm used to it.
__________________
C2D e6700 @ 3.25 Asus P5n-e SLi, 4GB of OCZ Platinum, Xonar D2, 320 and 160 GB Seagate, eVGA 8800 GTX and an Antec P182.
C2D T7500 2.2ghz, 2GB DDR2, Quadro NVS 135M 14.1in screen
Brett89 is offline   Reply With Quote
Old 13th Mar 2008, 15:09   #11
UncertainGod
Still Alive
UncertainGod's Avatar
UncertainGod has a spectacular aura aboutUncertainGod has a spectacular aura aboutUncertainGod has a spectacular aura about
If you think FF2 or 3 uses to much memory just set the memory capacity for your machine;
http://kb.mozillazine.org/Browser.cache.memory.capacity
__________________
Twitter Tumblr Blog Last.fm
"What role do you want to play, I'm just a click away night or day"
UncertainGod is offline   Reply With Quote
Old 13th Mar 2008, 15:19   #12
wuyanxu
quad fuelled, GTX200 powered
wuyanxu's Avatar
wuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura about
yeah, with 4GB, even if Firefox takes up 1GB of space, and Vista takes up 2GB, i've still got 1GB free for even the most demanding game. (Crysis use typically at 1GB, at most, is Dx9 mode, uses 1.5GB)
how's reliability of Beta 3?? shall i upgrade or wait until it's released?
__________________
Death to consolification !!!
Core i7 860 @ 4Ghz Cooled by Corsair H50 // Asus P7P55D Deluxe // 8GB of Corsair Dominators @ 1528Mhz 8-8-8-24 //
BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240
wuyanxu is offline   Reply With Quote
Old 13th Mar 2008, 15:34   #13
Nexxo
...like a geek!
Moderator
Nexxo's Avatar
Nexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud ofNexxo has much to be proud of
I have always used IE as it is good enough (if it ain't broke, don't fix it), but FF3 Beta 4 is admirably fast when dealing with Java-based page-apps like Gmail. I may be tempted to convert.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"There is no Real Life, only Away From Keyboard" --gpw111
"...my wife says I can't have any trolls, cause they argue with the dog and eat the fish" --KayinBlack
Nexxo is offline   Reply With Quote
Old 13th Mar 2008, 15:40   #14
naokaji
whatever
naokaji's Avatar
naokaji will become famous soon enough
Come to the dark side and give opera a try, we have a cookies.
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S
Opportunity is like delivery by DHL, it does not come to you, you have to track it down and chase it
naokaji is offline   Reply With Quote
Old 13th Mar 2008, 15:43   #15
Solidus
Superhuman
Solidus's Avatar
Solidus will become famous soon enoughSolidus will become famous soon enough
I do prefer firefox over internet explorer definately but it has issues. It has crashed numerous times on websites and wont respond - The nvidia website is one i can recall from the top of my head and restarting the explorer or computer didnt fix it either.
I have both explorers - Internet and firefox installed and i use internet explorer only when firefox screws up a page which happens often enough for me to warrant to keep it.
Im looking forward to FF3 however and hope these issues dissappear!
__________________
I'm a n00b in need of constant h3lp!
Xbox Live GT: Mephestic
PSN Tag: M3phestic
Twitter: Mephestic
Solidus is offline   Reply With Quote
Old 13th Mar 2008, 17:49   #16
phuzz
Hypermodder
phuzz's Avatar
phuzz is on a distinguished road
Been running FF3 since B1 (mind you, I started using Phoenix at 0.6 as my daily browser so...) an loving it, the only downside for me has been the lack of plug in support (Google Browser Sync I'm looking at you!). The speed is there, it's stable (for me at least on XP and Vista), and the new Places features are nice.
Wish they hadn't stuck those bloody vista buttons on it in B4 though
phuzz is offline   Reply With Quote
Old 13th Mar 2008, 18:51   #17
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has a spectacular aura aboutCupboard has a spectacular aura about
I have a strange problem with Firefox that causes music from Foobar to sometimes jutter. A quick restart of FF sorts it out and it only occurs when I have had lots of tabs open for ages (like around 20). It is still a bit worrying though. It never uses more than 300MB of RAM though.
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker
Samsung Q45.
Cupboard is offline   Reply With Quote
Old 13th Mar 2008, 19:05   #18
Hamish
I Mod, Therefore I Own
Hamish is on a distinguished road
FF2 never crashes on me but it does do some weird **** sometimes
sometimes it likes to think i've got a US keyboard layout all of a sudden, which isquite annoying
however decided to try ff3 b4 and see if enough of my extensions work on it yet, turns out they do
and woah, it really is a lot faster
its actually noticeable, maybe my ff2 was just really bogged down or something but do want!
Hamish is offline   Reply With Quote
Old 13th Mar 2008, 19:14   #19
UncertainGod
Still Alive
The new rss Icons are awful to look at, I wonder if there is a 'classic' theme available yet...
__________________
Old 13th Mar 2008, 19:49   #20
Anakha
Supermodder
Anakha's Avatar
Anakha is on a distinguished road
I'm sitting here using the FF nightlies (Updated each night with the very bleedingest version). It's just getting better and better, IMHO.
__________________
Robert "Anakha" Johnston
Going to Canada on Nov 28th! I'm going home!
Anakha is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
