RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 14th Mar 2008, 08:10   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
A modder's guide to acrylic
http://www.bit-tech.net/modding/2008...e_to_acrylic/1
No matter how much you love it, working with acrylic (in its many forms) can be a difficult task to the new modder. We're here to clear up a bit of the confusion when it comes to bending, cutting, joining and enjoying one of modding's most versatile materials.
Tim S is offline   Reply With Quote
Old 14th Mar 2008, 08:32   #2
Tile
Banned
Tile is on a distinguished road
Deleted
Tile is offline   Reply With Quote
Old 14th Mar 2008, 09:26   #3
[USRF]Obiwan
Ultramodder
[USRF]Obiwan is on a distinguished road
After all those years, the Orac3 is still one of the best looking mods around. And a very nice article.
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..."
The answer is 42, so... whats the question again?
If you know what 'Peek' and 'Poke' represents, then you are probably as old as me.
[USRF]Obiwan is offline   Reply With Quote
Old 14th Mar 2008, 09:42   #4
Tile
Banned
Deleted
Old 14th Mar 2008, 09:53   #5
undertheradar
What's a Dremel?
undertheradar is on a distinguished road
This article has a bunch of problems with it. I dont use acrylic for computer mods, but I have years of experience with acrylic for reef aquariums, building reactors, flanges, aquariums, fixtures, etc. There are several things in that article which are just plain wrong, or not the best way to do it. For instance, that type of saw blade pictured/suggested in the article is one of the worst blades you can use for acrylic.
undertheradar is offline   Reply With Quote
Old 14th Mar 2008, 10:00   #6
undertheradar
What's a Dremel?
One thing of importance: much of the 'cast' acrylic in the US isnt cell cast. Its something called 'continuous cast'. Its poured like cell cast, but on a constantly moving conveyor belt (like a 1/2 mile long) a bit like how plate glass it made when you think about it. Its a bit different than cell cast as far as strengths and problems though.
90% of the acrylic work I do is done by a laser CNC or CNC router... thats the way to go, and usually pretty easy to find someone you know who can do this for you. Most people who work in factories, engineers, etc tend to have access to one... one computer store local to me actually has a laser CNC in their back room...lol.
There is a multitude of articles on sites like reefs.org and reefcentral.com (mostly in the DIY sections, sort of like the aquarium version of the modding community) about working with acrylic. You can ask there as there are several professional fabricators there who are more than willing to help.
Old 14th Mar 2008, 10:57   #7
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
Undertheradar, would you mind elaborating?
I've worked with acrylic in modding since 2001, and I've found a fine-toothed plywood-panel blade to be a great way to cut it without marring the edge beyond recognition.
I don't attest that these ways are the ONLY way to do it, so if you have some actually constructive tips, then by all means - fire away. But if you're just going to say "Oh this is so wrong," that's not exactly helpful. Particularly when you can look on the net at large or in the forums to find that we as modders have been doing some of these things for years to great success.
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 14th Mar 2008, 11:34   #8
theevilelephant
Bit-tech's Heffalump
theevilelephant's Avatar
theevilelephant is on a distinguished road
great article, as someone who works as DT Tech (the guy that cleans and maintains workshop machinery) i might get some of the students to look at this too see what you can do with acrylic. Also please dont use band saws for acrylic unless its yours and you have the right blade, it makes a huge mess, clogs blade and machine and stinks.
theevilelephant is offline   Reply With Quote
Old 14th Mar 2008, 11:34   #9
vaderag
I know what a Dremel is...
vaderag is on a distinguished road
I've done a bit of acrylic work in the past, but mostly forgotten all the techniques - this article has re-awakened my idea of building an acrylic case - thanks
vaderag is offline   Reply With Quote
Old 14th Mar 2008, 15:38   #10
speedfreek
Ultramodder
speedfreek's Avatar
speedfreek is on a distinguished road
If I ever went to watercooling I told myself I would make my own reservoir, now I have a good idea how to.
__________________
New Rig, Quad Core and 8800 baby! Now with 6gb of RAM and a nice even 2tb
now my server|Athlon 64 3700(2.64ghz)|7800gs|2gb XMS 2-3-3-6|2tb+ total HD space... In raid|I have a problem.
New Laptop: HP EliteBook, its fast!
speedfreek is offline   Reply With Quote
Old 14th Mar 2008, 16:04   #11
Thacrudd
Where's the any key?!?
Thacrudd's Avatar
Thacrudd is a jewel in the roughThacrudd is a jewel in the roughThacrudd is a jewel in the roughThacrudd is a jewel in the rough
I really appreciate the good read! Flame polishing makes a bit more sense now lol. Orac3 is the case that I happened across a few years ago and it is what got me into PC case modding (I did a bunch of xbox's before) A few comments :
1. the sawblade pictured is what I've used and have had wonderful results from in the past.
2. I do alot of my cutting now on my bandsaw, 80" blade, 15TPI, and it works great.
3. Superglue is a very bad bonding agent for clear acrylic. It creates a foggy residue around where you used it, not just the exact spot you put it on. I would reccomend it for anything except transparent materials. (just my experience)
If you were making a seamless bond, would you flame polish the 2 edges before you put them together?
__________________
Just as you touch the lives of every life form you meet, so, too, will their energy strengthen you. Fail to live up to your potential, and you will never win... - Gaspar, The Guru of Time
Project: Andromeda
Like game/Anime music?
My Sale Thread - HERE Bit-Tech Wallpapers! - HERE
Thacrudd is offline   Reply With Quote
Old 14th Mar 2008, 17:03   #12
Yemerich
What's a rebimboca da parafuseta?
Yemerich's Avatar
Yemerich has a spectacular aura aboutYemerich has a spectacular aura about
Well, using a blow torch for polishing the edges is good. biut if you have a sandwitched acrilic the results arent that good. So, a blow torch is only good for single pieces.
My last four mods are all acrylic. And i have one going on here in bit tech. It's the Odinn project.
In MY experience, polished edges doesn't bond together well. So i don't think a really seamless weld is possible. The glue used to weld acrylic is cloroform based and is fairly easy to find - at least where i live.
Another good thing to save u some work is to "scrape" the edges. This way you can save more than 50% work on sanding.
If you need to bond 2 polished faces together, sand them with 400 or 600 grit sandpaper to have a more resistant weld.
For drilling the acrylic, you need blunted HSS drill bits. This prevents the acrylic to cause splinters.
The high quality acrylic (the ones that are not recycled) doesn't melt when u saw it, have no odor and is much harder to get foggy when the glue hit its face.
Still the best way to get polished edges still is by sanding it by hand, and polishing with sheep pelt.
I don't have a table saw, but the people who cut it for me use "wydea" blades to cut it.
Cheers people!
__________________
Bit Tech is more than games and hardware - check out the mods too. Don't let modding die in Bit-Tech.net.
Yemerich is offline   Reply With Quote
Old 14th Mar 2008, 17:12   #13
MJudg
ProModder
MJudg is on a distinguished road
Wow! Nice article!
I also love acrylic and LUMINA is the best example of beauty and functionality of this material!
MJudg is offline   Reply With Quote
Old 14th Mar 2008, 18:21   #14
talladega
Don't Ban Me Bro!!!
talladega's Avatar
talladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant futuretalladega has a brilliant future
WARNING!!! Watch out for the IPS Weld-On containers! They may explode in your face like it did mine!!!
seriously. lol. I finally unscrewed the lid and then there was a metal tab i needed to get out so I was prying it open when BOOOOOM! The metal tab hits my eye and I get the solvent all over my face and in my eyes.
Maybe im the only one this has happened to?
Nice tip about flame polishing. I'll test that out I think. Does it keep the edges very staright and flat too?
__________________
THIS IS NOT PATRICK
How to Create Watercooling Tubing in Sketchup
Originally Posted by Krikkit View Post
Big cannons like that make me wet
talladega is offline   Reply With Quote
Old 14th Mar 2008, 18:40   #15
Cheapskate
know-it-all b*stard...
Cheapskate's Avatar
Cheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud of
I have to disagree with some of what has been said. (This is for the noobs who have never heard my constant preaching.)
You missed the biggest reason why you should avoid extruded plexi: It melts if you try to cut it with a powersaw.
If you are doing a lot of straight cuts on plexi, invest in a $100 table top wetsaw/tilesaw. They can cut through any thickness or type of plexi with great results. They work on polyprophelene or cast and extruded acrylic. On my tile saw I have cut 1 1/4" thick cell cast plexi successfully.
Flame polishing will never look as good as sanding and polishing. -and why would you want to take a torch to something you put a lot of work and money into?
Like Yemerich said, I sand the edges I plan to fuse together with 150 grit sandpaper. Faces I just leave polished.
@Talledega - Sounds like you should have put it in the fridge for a while.
I'ts good practice to puncture those kinds of caps before removing them. Treat them like a shook up Dr. Pepper can.
Cheapskate is offline   Reply With Quote
Old 14th Mar 2008, 21:28   #16
The_Beast
I *am* The Stig
The_Beast's Avatar
The_Beast is a jewel in the roughThe_Beast is a jewel in the roughThe_Beast is a jewel in the rough
There are some good tips for the new be moders
__________________
Rendering Machine - Gigabyte DS3L P35 - C2Q Q6600 - Antec New Solution Series NSK4480B - Corsair XMS2 2Gb - Sapphire 2600 XT 256mb - Seagate 'Cuda 320 GB - Antec Earthwatt 430 watt - Windows XP Pro -
The_Beast is offline   Reply With Quote
Old 14th Mar 2008, 22:19   #17
Teknokid
Supermodder
Teknokid is on a distinguished road
Yeah, i found it good, although the UK company mentioned is a bit dear
personally im gonna start getting myn from ebay, excelent deals from there im finding.
Nice article
__________________
Phenom II.... hmmm
Teknokid is offline   Reply With Quote
Old 15th Mar 2008, 00:30   #18
Matticus
Do me a favour, plug me into a Sega
Matticus's Avatar
Matticus is just really niceMatticus is just really niceMatticus is just really niceMatticus is just really niceMatticus is just really nice
Nice article.
Though on page one "perpex" has a closing tag before it, so no Italics.
This has sort of reminded me to actually bother to make something from acrylic, so thanks
__________________
|||E8200@3.4ghz|||GA-P35-DS3L|||4GB OCZ/Corsair DDR2 800|||8800GT 512mb|||VX450w|||Under Water|||
Matticus is offline   Reply With Quote
Old 15th Mar 2008, 00:36   #19
Project_Nightmare
Minimodder
Project_Nightmare is on a distinguished road
Good thing this article came out before I started the case mod I'm planning! I wish there were more articles on using acrylic like this one.
Project_Nightmare is offline   Reply With Quote
Old 15th Mar 2008, 01:34   #20
cc3d
It's a mod mod world
cc3d's Avatar
cc3d is on a distinguished road
There is a technique for mixing acetone with scraps of the plexi you are joining to make a goo (glue) that will bond plexi fantastically. I can't recall the details, but I am sure it is 'findable'
__________________
_________________________
my karma ran over your dogma
see Phase III at www.tccook.com
cc3d is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
