RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 16th Mar 2008, 08:24   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Arctic Cooling Silentium T2 Eco 80
http://www.bit-tech.net/hardware/200...um_t2_eco_80/1
We've all heard of green PCs - but what about a green case? Claiming excellent noise reduction and an innovative thermal management system, the Silentium T2 Eco 80 is a case which seems to have it all - but appearances can be deceiving...
Tim S is offline   Reply With Quote
Old 16th Mar 2008, 08:43   #2
The_Pope
Geoff Richards
Moderator
The_Pope's Avatar
The_Pope is on a distinguished road
Oh, boy
The_Pope is offline   Reply With Quote
Old 16th Mar 2008, 09:31   #3
badders
Neuken in de Keuken
badders's Avatar
badders is just really nicebadders is just really nicebadders is just really nicebadders is just really nicebadders is just really nice
Riff-Dribble didn't work under vista?
Hmmm, seems to work okay here.
As soon as I saw the picture with the door opened, I cowered in Horror.
It also sounds like Arctic cooling are going back to the Ghetto with their Hard drive mounting ideas. What's wrong with a normal HDD cage suspended on rubber nipples or similar?
Even Krikkit didn't take to velcro-ing his hard drive in.
__________________
Have You been Drinking?!?!?
Why, yes I have! Thankyou!
badders is offline   Reply With Quote
Old 16th Mar 2008, 10:09   #4
Jipa
Licenced idiot.
Jipa's Avatar
Jipa has a spectacular aura aboutJipa has a spectacular aura aboutJipa has a spectacular aura about
Even though I sense deep hatred towards the case, I'd still like to know how powerful the powersupply is. I don't know if the amount of drive bays tells anything about a computer being ultra super fast or not, either, but I guess that's just me. I wouldn't mind seeing a picture of the insides with hardware installed, just to see how crowded it actually gets in there.
Shame it turned out so bad, I actually like the outlooks.
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper
Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01
Jipa is offline   Reply With Quote
Old 16th Mar 2008, 10:15   #5
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Sorry, I thought Joe had mentioned the power rating in the article - it's 500W, but curiously called the 550F...
Old 16th Mar 2008, 10:32   #6
Primoz
Minimodder
Primoz is on a distinguished road
I actually like this case very much. It could be very good - with some modding ofcourse. I see it as a great LAN case, with the PSU in it's normal position, two 80 mil fans by the mobo (instead of that duct), a 240 rad in the bottom with the plastic stand modded to have intakes in the ribbed section and a different HDD mounting.
Primoz is offline   Reply With Quote
Old 16th Mar 2008, 10:32   #7
CardJoe
Player Character
bit-tech Staff
CardJoe's Avatar
CardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to behold
It works for me at home too, but for some reason all I was getting was a "Generic Application Error", which wasn't very helpful for diagnosing the problem. I check that the GPU was actually working and that the drivers were correct, but still no luck. In the end, upgrading the GPU test needed to be done anyway. I think it's probably just a small error in the registry or something.
I'm not sure if that's all possible - it seems very cramped in there and you'd have to move the expansion slots etc. Also, bear in mind that the PSU and it's plastic housing seem to be secured in place.
__________________
CardJoe is online now   Reply With Quote
Old 16th Mar 2008, 10:40   #8
Primoz
Minimodder
I still think it's nothing a little dremel work and some new metal plates (if really neccessary) can't fix
Old 16th Mar 2008, 11:14   #9
karx11erx
Multimodder
karx11erx is on a distinguished road
First of all the reviewer has by no means understood who this case has been designed for. It's not for the enthusiast who wants to put a ton of highest end hardware in it. It is for the office worker or casual gamer who just needs standard equipment.
Second, placing the PSU at the front bottom of the case has something to do with the overall thermal design. The plastic stand of the case has openings through which cold air is sucked into the case by the PSU and the other case fans (I don't know why Card Joe would want to mod them into the stand - the stand's entire purpose is to allow air to be sucked in the case through its ribs).
Third, if you want the case to be near to silent, you will have to use the proper coolers for the CPU and GPU as well. I am having the previous of this case both at home and at work, 64 bit CPUs and Radeon X800/850s inside. The CPUs are cooled with an Arctic Cooling heatpipe cooler (many people don't seem to like them, but I never had any problems with them). Actually the loudest component is the Arctic Cooling VGA silencer in one of the systems. My workplace system just cannot be heard - I have to look under my desk to see whether its working.
My cases also don't have that awkward fastening system for harddrives, but a solid aluminium casing where you drop the harddrive in. There's only space for one harddrive, but given who the case is intended for, and looking at the prices of 500 GB HDs, that shouldn't be a problem. The fixing system for addon cards is screwless and works nicely.
The case costs less than 100 Euros including a decent PSU and low noise case cooling. For that price I can live with a little black plastic. Personally I like the look of the case. I am preferring very sleek, elegant cases anyway over all that prebuilt modding fuzz (like the Lian Li Armor). My favorite case would be the Antec P182 with chrome finish. Apart from the probably justified criticism of the reviewed case's harddrive attachment system I have to say that the review apparently has been made with a strong elitist attitide that far and wide misses the point and the qualities of this case.
__________________
Descent Site, Fine Arts.
karx11erx is offline   Reply With Quote
Old 16th Mar 2008, 11:55   #10
m4r71n
What's a Dremel?
m4r71n is on a distinguished road
i was really hoping that was gonna be a good case, as its a nice low price too.. not realy worth it if you have to modify it to make it any good
m4r71n is offline   Reply With Quote
Old 16th Mar 2008, 12:34   #11
Jonagon
What's a Dremel?
Jonagon is on a distinguished road
What's the problem with the case temp being a few degrees above ambient at idle? Surely that's fairly normal.. certinaly my case behaves like that.
I mean.. heat is being produced in the case and unless your cooling system for extracting it is 100% efficent, it's always gonna be a little bit hotter inside isn't it?
..Or am I missing something obvious? :P
Jonagon is offline   Reply With Quote
Old 16th Mar 2008, 12:35   #12
Bluephoenix
Spoon? What spoon?
Bluephoenix's Avatar
Bluephoenix is on a distinguished road
trash is trash is trash, unless a dremel is applied.
I expected that result, as you can only lower the price so much without some parts of the case having issues.
for cheap cases best one I ever used that had an enviro-freindly rating on it was the cooler-master elite 330. cost me $40, yet has good build quality.
Bluephoenix is offline   Reply With Quote
Old 16th Mar 2008, 12:49   #13
Slink
B7
Slink's Avatar
Slink is on a distinguished road
Cant pollish a turd.
I had one of the older models and i was proper disapointed with it, everything would overheat, the "Cool" drive cage was placed right next to the PSU which didnt help, and it was a bit out of the way for wires. No matter how much tidying you got done inside the case it was still so tight in there for such a big case.
The no screws drive rails were a pain the in the arse as well.
The plastic on the bottom that held the case up turned brittle and broke to bits.
Loops now has the case. She can probably vouch for the build quality.
Although saying that, this new one looks ok to look at, but i can just sense the internals and build will be just as bad.
__________________
lul
Slink is offline   Reply With Quote
Old 16th Mar 2008, 12:53   #14
Slink
B7
Slink's Avatar
to be fair now i come to think of it. out of all the cases i've had and worked with, the antec lanboy 1st gen) has got to be the best i've used.
__________________
lul
Old 16th Mar 2008, 12:58   #15
Nature
Supermodder
Nature's Avatar
Nature is on a distinguished road
Yeah no one likes those rotwillers. Funky peice of goose this case be.
Why don't you Bit-Tech-ians make a mid tower case that represents your company? I think it be an interesting think tank with all the brains contributing tword an image of your work and philosophies.
China has stoped youtube!!! HorrorS!!!!!!! The Madness!!
__________________
Peace, Love, Empathy, Respect, Generosity, Smiles, and Hugs
Nature is offline   Reply With Quote
Old 16th Mar 2008, 13:40   #16
DXR_13KE
Madeira's banana is the best!!!
DXR_13KE's Avatar
DXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to beholdDXR_13KE is a splendid one to behold
Nature, on that idea, i would very much like the bit-tech to design the ultimate computer case..... or computer case line, from small to big and from wide to large.....
__________________
Renegade X - 0.40 Release! <---- CLICK!
DXR_13KE is offline   Reply With Quote
Old 16th Mar 2008, 15:36   #17
CardJoe
Player Character
bit-tech Staff
CardJoe's Avatar
Temperature differences at idle aren't a huge thing - but a 5 degrees difference when NOTHING is going on is a bad sign. Your computer isn't doing anything, the fans are going full pelt, and it's still 5 degrees about the ambient. That's only going to get worse when load builds. Compare it to some other cases in the price range to see what sort of cooling performance you can get with a more standard set-up. The 690, though it comes without a PSU, is about the same price and a good example of this:
http://www.bit-tech.net/hardware/200...aster_cm_690/4
__________________
Old 16th Mar 2008, 16:21   #18
sub routine
Archie Gemel
sub routine's Avatar
sub routine is on a distinguished road
hehe the name? What on earth is silentium something has to be done about that before anything else.
sub routine is offline   Reply With Quote
Old 16th Mar 2008, 17:11   #19
Jipa
Licenced idiot.
Jipa's Avatar
Very impressive indeed, it actually cools the ambient air .5 degrees Just nit picking, isn't it lovely when it's 2008 and they still can't make accurate sensors for reasonable price. Personally I've been owned by the instruments as I claimed a case to be lighter with a PSU or something
__________________
Old 16th Mar 2008, 17:32   #20
tranc3
It's a series of tubes!!
tranc3's Avatar
tranc3 will become famous soon enoughtranc3 will become famous soon enough
So if they made hybrids that looked that good, more ppl would be driving them.
__________________
[AMD Kuma 7750 2.77 |Asus M3N78-EM|mushkin 4x1GB DDR800 |WD Caviar 500GB|GeForce EVGA GTS 250 512MB|OCZ StealthXStream 600]
tranc3 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
