Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
First Look: Nvidia nForce 790i Ultra SLI
http://www.bit-tech.net/hardware/200...0i_ultra_sli/1
Nvidia has launched its ultra powerful, ultra expensive "enthusiast" DDR3 chipset - nForce 790i Ultra SLI is here! We dive into the technology behind it in this first look to see what all the fuss is about.
__________________
#2 |
Blame it on the Boogie
hmmmz
I'm really curious wat it was that was crashing the OCs. Not that i'll be able to afford stuff like this in the coming 10 years, but it seems like there's something tiny in the way of getting some really epic overclocks... |
#3 |
Richard Swinburne
bit-tech Staff
We did get a new BIOS sometime late yesterday but the board wouldn't take it so I gave up - it was just a first look after all. I'm going to have another splash with the Asus Striker II Extreme in a few weeks once the BIOS' have settled down a bit. I'll source some Corsair EPP-een 2.0 too, see if that makes a difference
#4 |
The Right man in the Wrong place
Page One: "Most of will be looking at DDR3 in Q4 this year and into 2009 when prices are expected to drop, Nehalems will arrive on DDR3 only and DDR3-based AMD CPUs will be just around the corner"
Are you missing the word "us" or "The people on the modern edge of enthusiast computing and the technology behind it" in between "of" and "will" Otherwise, great First Look. Shame the OC's did not meet par. And that is a strange place for a sata port... |
#5 | |
whatever
oc's worse than intel boards, will be very expensive, ddr 3 only, no ground breaking new features, someone must be really desperate for sli if he buys one of those...
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S Quote:
#6 | |
Pewlius Caesar
bit-tech Staff
__________________
#7 |
VGChartz PR Manager
ok looking at the 790i ultra boards i have a question. I was looking on newegg.com and it says that the motherboards support DDR3 1066/1333 but can support up to DDR3 2000, so does that mean i can install a DDR3 1866 stick without having to overclock the board or no?
__________________
http://thebladeclan.com |
#8 |
Richard Swinburne
bit-tech Staff
Yes, to some degree because the board supports memory dividers that keep the CPU FSB speed lower, although if it doesn't have EPP 2.0 you'll have to do the settings manually etc.
#9 |
Don't panic!
That's an awesome looking board, and should be a great 'clocker once they give 'em a new BIOS. Far too pricey though, £282 is a bit rich for my tastes...
__________________
|E8400 @ 4.4GHz|WC: 2*120.1 GT's, MCP350, Storm G5|4GB Dominators|DFI LT X48-T2R|8800GT|74GB Raptor|Chieftec BA01|OCZ ModXStream 600W|Dell 2208WFP|
The Good, The Bad, The Ugly, The LOL!!1!!1!, The Zlad!, The Kempness, The Braaaaaains... |
#10 | |
VGChartz PR Manager
__________________
http://thebladeclan.com Last edited by ssj12; 20th Mar 2008 at 03:48. |
#11 |
Do me a favour, plug me into a Sega
Looks like a physically nice board, and the bundled black cables really look nice, but unless the board/chipsets are going to perform atleast as well as the intel chipsets then I cant see how they are going to sell even to people with more money (and want for SLI +ddr3) than sense.
__________________
|||E8200@3.4ghz|||GA-P35-DS3L|||4GB OCZ/Corsair DDR2 800|||8800GT 512mb|||VX450w|||Under Water|||
#12 |
Supermodder
If the board is half what my 680i is, it's an amazing board. I don't think I would use the tri Sli thought, I'm just starting with 2 lol.
__________________
[Silverstone TJ-07][Evga 680i LT][Core2Quad Q6600@3.2][Zalman 9700 cpu cooler][Geil 4g 1000mhz 4-4-4-12 T2][Evga 8800 GTS 640/320 SLI @stock][WD Raptor 160g 10,000rpm Clear Window][4x 500gb Sata 16mb HDs][Sony Sata DvD-Rw/Ram][4x 120mm 2x 92mm][Xion 600w Modular PSU][All black cables][28"Hans-G w/Samsung 19"913v][Razer Lycos Keyboard][Logitech Revolution][3D Mark 06 score:10240] |
#13 | |
Richard Swinburne
bit-tech Staff
If you have a QX9770 I'm not sure if you can run 1866 - the only available "linked" options are 5:4 and 3:2 or Sync. Other than that I would recommend running the memory slower or overclocked rather than unlinked simply because it affects memory performance more negatively than running it slower. If I had a QX9770 in my own system I'd Sync the memory and CPU 1:1, overclocking the CPU (what a QX is designed for) - the jump from 1600 to 1866 isn't that much and Syncing yields the maximum performance. |
#14 |
Banned
the problem is that the design is all wrong instead of high speed ddr3 they shud focus bak on ddr2 im using an evga 680i sli based rig with a quad core (Q6600) stock clocks and 1 bfg 8800gts 320mb oc'ed and i can play crysis with high and very high settings with x2 aa and 1024x768 res. wich is just heaven. i will never buy another mobo just new gfx cards as mine becomes outdated in 2 years
| Thread Tools | |
