RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Mar 2008, 15:58   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Intel talks about Nehalem, Larrabee & 32nm
http://www.bit-tech.net/hardware/200...bee_and_32nm/1
Earlier in the week, we chatted to Intel ahead of next month's Intel Developer Forum to discuss some of its future products... Nehalem and Larrabee to be specific. It looks like 2009 and onwards will see all the major players fight on multiple fronts.
Tim S is offline   Reply With Quote
Old 19th Mar 2008, 16:04   #2
Slink
B7
Slink's Avatar
Slink is on a distinguished road
peta flops ey?
__________________
lul
Slink is offline   Reply With Quote
Old 19th Mar 2008, 16:23   #3
The_Beast
I *am* The Stig
The_Beast's Avatar
The_Beast is a jewel in the roughThe_Beast is a jewel in the roughThe_Beast is a jewel in the rough
Will AMD ever catch up???
__________________
Rendering Machine - Gigabyte DS3L P35 - C2Q Q6600 - Antec New Solution Series NSK4480B - Corsair XMS2 2Gb - Sapphire 2600 XT 256mb - Seagate 'Cuda 320 GB - Antec Earthwatt 430 watt - Windows XP Pro -
The_Beast is offline   Reply With Quote
Old 19th Mar 2008, 17:44   #4
kosch
Trango in the Mango
kosch's Avatar
kosch is on a distinguished road
Finally an integrated memory controller on the chip
__________________
[b]Really needs updating! - http://www.kosch.co.uk/
kosch is offline   Reply With Quote
Old 19th Mar 2008, 20:15   #5
DarkLord7854
Web Developer
DarkLord7854's Avatar
DarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to behold
Time's going AMD, tick, tock
__________________
Current Computer: eVGA 780i Motherboard | Q6600 Core2Quad | eVGA GTX260 896Mbs 216-core | 2x Seagate 500Gbs | 8Gbs OCZ Platinum DDR2 800 | Creative XtremeGamer X-Fi | Thermaltake Armor Case
Custom WordPress, ZenCart, Joomla, vBulletin, etc installs and skinning, PM/E-Mail for a quote
DarkLord7854 is online now   Reply With Quote
Old 19th Mar 2008, 22:42   #6
Kipman725
When did I get a custom title!?!
Kipman725's Avatar
Kipman725 is on a distinguished road
as somone who does alot of work on small microproccesors and some FPGA work these things are unbelivably insanly fast and high-tech. They must have run right upto the transitor budget for the cache to be cut as it's a big PR number (although I would rather have on die memory controllers and optimisations like they have done).
__________________
Sn45g game server mod My Electronics Site
Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT
Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit
Kipman725 is offline   Reply With Quote
Old 20th Mar 2008, 00:46   #7
dmak
Minimodder
dmak is on a distinguished road
just a question, AMD brought out phemon a while ago right? then why are we hearing about a release coming up? is it some sort of rerelease that will fix the problems with the current architecture? like being able to scale past 3 ghz?
dmak is offline   Reply With Quote
Old 20th Mar 2008, 11:09   #8
Jar of Almonds
Minimodder
Jar of Almonds is on a distinguished road
The release is for the B3 stepping which fixes the TLB errata in the hardware without causing performance degredation (unlike the BIOS patch). Any performance gains i.e. overclocking haven't been reviewed yet except for a 'first look' over at anandtech.
Oh yeah, it's also the release of the higher clocked models that were pulled from the original launch, 9750 and 9850.
__________________
Some days you're the fly. Other days you're the windshield.
Jar of Almonds is offline   Reply With Quote
Old 20th Mar 2008, 15:20   #9
Cupboard
I'm not a modder.
Cupboard's Avatar
Cupboard has a spectacular aura aboutCupboard has a spectacular aura about
Why a 3 channel DDR3 controller? Does that mean we will get motherboards with support for up to 6 memory slots?
http://www.bit-tech.net/content_imag...2nm/neh7-8.jpg
Larrabee sounds interesting though I can't see them killing Nvidia for some time (AMD/ATI may be a different matter though)
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker
Samsung Q45.
Cupboard is offline   Reply With Quote
Old 20th Mar 2008, 15:26   #10
dmak
Minimodder
cool thanks, the b3's are 3 cores though arent they? are there quads with this fix as well?
Old 20th Mar 2008, 16:37   #11
Jar of Almonds
Minimodder
For the first question, no. B3 is just the silicon stepping to help address problems from previous silicon designs and in some cases increase performance. The tri-cores will most likely launch with this stepping as they are just quads with a faulty core that didn't pass testing.
For the second question, yes there will be quads that are manufactured under the B3 stepping. To avoid confusion when buying one, the new quads will have the 9x50 numbering system instead of the 9x00 quads that originally launched using the B2 silicon stepping. These should start to be shipped out soon starting with the 9550 and 9650 phenoms soon followed by the 9750 and 9850. Tri-cores will have the number system 8x00 or 8x50, i'm not sure on which one. I assume the dual cores will be numbered under 7x00 or 7x50 respectively to the other CPU's.
Hope that's explains it well enough (...most of it should be correct-ish)
__________________
Old 24th Mar 2008, 15:26   #12
K20
Minimodder
K20's Avatar
K20 is on a distinguished road
Originally Posted by Nehalem page
By being inclusive this means there is automatically an amount of cache reserved in L3 to hold L2 and L1 data, so that none of the cores have to waste cycles sniffing another core’s cache for information – now it just has to simply dive into the shared L3 cache. Intel says that the first Nehalem-based product will be quad-core and will feature 8MB of L3 cache, which means that around 2,256KB of L3 cache will be reserved for a copy of the L1 and L2 caches on each core.
This does cut the available size for everything else to about 6MB and this is quite a drop from the current 2x6MB shared cache design on current quad-core 45nm parts.
2256 KiB / 4 = 564 KiB. . Should it not be [64 KiB L1 + 256 KiB L2]*4 = 1280 KiB. *It's easy being an editor*
Originally Posted by Slink View Post
peta flops ey?
*Can't. Resist. Urge. To. Correct* NO! TERAFLOPS! (1000th of a petaflop)
Your answer is located at the bottom of page 2. Intel thinks DDR2 = 2 channels, 2 DIMMS per channel; DDR3 = 3 channels, 3 DIMMS per channel. Anybody want to hazard a guess as to how many DIMMS a DDR4 IIMC will be able to access .
Curious that you would say that as there is a reasonable chance Larrabee will focus heavily on ray tracing. If that is the case R6xx is better equipped (I think, depends on dependency) to deal with that than G8x/G9x.
Now that my quoting is out of the way: Intel needs to work on their slides; the 'Enhanced Cache Subsystem' slide (#14) has me believing that part of the 'Enhanced Cache Subsystem' is gold. Pure functionless gold. While slide 12 has the "33% more parallelism" bubble covering the bar chart . Intel also decided to put RAS features, RDIMM and UDIMM support on one of their slides; could somebody tell me what these mean please.
Anyway enough about Nehalem, what about bulldozer?
K20 is offline   Reply With Quote
Old 8th Apr 2008, 12:38   #13
Toka
Multimodder
Toka is on a distinguished road
32 nanometer fabrication...
320 angstrom fabrication...
It boggles my mind a little bit each time I think about it. Just how much further can they push towards a diffraction limit? What sort of distances are they having to maintain between template and substrate to achieve this (think about it, maintaining somethting like a 5nm gap between 2 surfaces during fabrication) and what frequency of radiation / source are they using? Synchatron x-rays?
I guess they will keep using imersion lithography for the 22nm chips but where then, can it go all the way down to 16nm? (a covalently bound silicone atom is about 0.11nm across)
Just wow really, the speed of R & D in this industry is a little bit frightening.
Edit: google cheesecake, they dont have to use a synchotron source, yet, they use 193nm from an ArF excimer lazer. I guess that would be a bit future future gen still.
__________________
Toka is offline   Reply With Quote
Old 8th Apr 2008, 12:44   #14
Toka
Multimodder
this is worth a read
http://en.wikipedia.org/wiki/Double_patterning
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
