Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 20th Mar 2008, 12:47   #1
Farrukhmomin
What's a Dremel?
Farrukhmomin has yet to learn the way of the Dremel
Recommend Motherboard
hey all,
below is the list available in pakistan, i just purchased 8800gt all i need to know is i want a motherboard from the below list of motherboards that i can purchase.
Please recommond a motherboard which will not create any bottleneck for 8800gt.
Intel DG33FB (775PINS - SND+AGP+GIGALAN - 1333MHZ FSB) PCX SLOT
Intel DG965RYCK (775PINS - SND+AGP+GIGALAN - 1333MHZ FSB) PCX SLOT
Intel DQ35JOE (775PINS - SND+AGP+GIGALAN - 1333MHZ FSB) PCX SLOT
Intel DP35DPM (775PINS - SND+GIGA LAN -1333MHZ FSB) PCX SLOT
Intel S975XBX2 (775PINS - SND+GIGA LAN - 1066MHZ FSB) PCX SLOT
Intel D975XBX2 (775PINS - SND+GIGA LAN - 1066MHZ FSB) PCX SLOT
Intel DX38BT (775PINS - SND+GIGA LAN - 1333/1066/800 MHZ FSB) PCX SLOT EXTREME SERIES SUPPORT
Nforce 780i (775PINS - SND+Dual GIGA LAN) PCX SLOT Supports 3 Way SLi
Nforce 680iLT (775PINS - SND+Dual GIGA LAN) PCX SLOT Supports 2 Way SLi
Nforce 630i (775PINS - SND+GIGA LAN+VGA 7100 series) PCX SLOT
Farrukhmomin is offline   Reply With Quote
Old 20th Mar 2008, 13:32   #2
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpitwuyanxu is almost as Godly as yodasarmpit
does it HAVE to be a Intel motherboard?
and what CPU are you planning to use?
__________________
i7 2700k \ 16GB \ gtx580 \ D2X \ z68x-UD5 \ m4 128GB +2TB \ Ax850 \ FT02-RW \ G15+G5+G51 \ U2711 27"
5D mkII \ 24-105 L \ 17-40 L \ 85/1.8 \ 35/2 \ 70-300 Di \ 270ExII \ 430ExII \ 3LT Adrian \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 20th Mar 2008, 13:56   #3
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
Originally Posted by Farrukhmomin View Post
hey all,
nice to know budget and CPU to be used.
__________________
Project log Mocha70
Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2
Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 20th Mar 2008, 14:14   #4
oasked
Stuck in the Mud
oasked's Avatar
oasked has yet to learn the way of the Dremeloasked has yet to learn the way of the Dremeloasked has yet to learn the way of the Dremeloasked has yet to learn the way of the Dremeloasked has yet to learn the way of the Dremeloasked has yet to learn the way of the Dremeloasked has yet to learn the way of the Dremeloasked has yet to learn the way of the Dremel
Yes, what is the CPU that you plan to use? Out of those I would choose:
__________________
Intel i7 920 @ Stock | 6GB Corsair DDR3 | Gigabyte GA-EX58-UD5 | WD6401 AALS
Zotac GeForce 560Ti | Lian-Li PC65 | Enermax 600W SLI | Dell 2408WFP
oasked is offline   Reply With Quote
Old 21st Mar 2008, 12:30   #5
nigelleg
Multimodder
nigelleg's Avatar
nigelleg has yet to learn the way of the Dremel
I am using the DP35DPM board with a 8800gt its a nice board but no overclocking features
__________________
DP35DP-Q6600-Arctic Freezer Pro 7-4GB Crucial Ballistix Tracers DDR2 800-EVGA GTX 260 216-Seagate 7200.11 500GB 32MB-LG GSA H55L-Samsung 2232GW-Logitech X 540's-Coolermaster CM 690-Corsair HX620w
nigelleg is offline   Reply With Quote
Old 22nd Mar 2008, 15:21   #6
Farrukhmomin
What's a Dremel?
yes, Intel Only
i have to select intel as they are available easily.
what about
my budget would be around $150 to $200
and also keep in mind that my next investment is
INTEL (XEON QUAD CORE) 2.33 GHZ (12MB CACHE - 1333MHZ FSB )
Old 23rd Mar 2008, 20:00   #7
cpemma
Ecky thump
cpemma's Avatar
cpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysis
As I've no idea what $200 would buy in Pakistan, it might help if you gave a link or two to your favourite online suppliers and a price range in Rs so we can see what's available.
On your list in post#1, why list boards with onboard graphics when you have the 8800GT?
__________________
Nobody's perfect.
But being a Yorkshireman is as close as you can get.
cpemma is offline   Reply With Quote
Reply
Tags
graphics, graphics card
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
