Thread Tools |
#1 |
Player Character
bit-tech Staff
Will the 'netbook' save Windows XP?
http://www.bit-tech.net/news/2008/03...e_windows_xp/1
With the demand for low-cost, fully web capable machines set to soar massively this year, could Windows XP be given another reprieve?
__________________
#2 |
Mini Love
anyone thought that with the large number of 'netbooks' on linux coming our way, that viruses for linux might rise in number? a large number eeepc users i imagine will be using open/free networks at their local starbucks or where ever, probably making hacking and viruses a little easier. since linux is open source does that also mean coding for viruses is a little easier too?
sorry for my ignorance, i know nought about hacking and viruses. just a thought.
__________________
Death to consolification !!! [size=1]Give me my Windforce! I'm coming back! |
#3 |
obey the fist!!
You know, I've always thought that too.. but I think the idea is that since everything is open, holes get closed up a lot quicker as they are noticed by the almost unlimited number of programmers working on it. Then again, since it's always been quite nerdy to run linux most people will be totally up to date, with all the latest kernel and whatnot. With 'regular people' buying eeePCs and such, the less aware user may be more open to malware...
__________________
Big, half-finished, parts hanging out computer ATCS 210; MSI mATX; AMD 4000+; HD4770; 3GB DDR400; 2x120GB + 2x1TB; 19" HANNS-G |
#4 |
Why not? I own a domain to match.
It really doesn't work that way. The *nix systems have a thirty-year-strong background and thus security model in place - basically a much more user-friendly of Vista's UAC (which, annoying as it is, does seem to help - I haven't heard of any major security issues emerge, though I can't pretend to pay much attention). People can try all they want to make a virus, but there still has to be a vulnerability to exploit. Thanks to a pretty robust permission model, it's just not that big of a risk (provided you don't do something stupid like give root access to an unknown program, but no security system can stop users from being dumb).
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#5 |
Multimodder
It'll only happen if Microsoft wants it to happen. I wonder how long it will take them to figure out exactly the depth of everyone's discontent with Vista.
| Cadillac Ferd |
| View Public Profile |
| Find More Posts by Cadillac Ferd |
#6 |
CPC hang out zone (i Fix pcs i do )
vista UAC basicly is same thing as sudo/su (temp root access or admin for windows users) just more anoying on vista, virus on linux are posable just getting an virus to work would is an problem as KDE and gome are more around i guess asking for root should not be to hard all it takes is the user to alow root access
__________________
Qx6850 (OC 3.3Ghz) <> 120 extreme<> rampage forumla <> 9800GX2 <> 8gb 4x2gb (2x gell / 2x adata)<> SSD powered Corsair S128 / WD Black 1TB <> Crative X-fi FalTy FPS <> TK 1000w Toughpower <win7 x64> Click me for folding stats greenfrog.biz / 35947 |
#7 |
Hypermodder
The comments about Linux virus's have always been, If you get one, its basically sand boxed, OK, it can delete your data at the most, but it cant get at the OS (without sudo/su)
OK, so data is probably a bad thing to loose, but technically, you should have a backup anyway I also wonder though, if Linux moves from "Geeks" to the normal user, what will happen? i personally don't think (and I'm reasonably experienced in Linux) that i know how to secure, and check, a Linux machine (in terms of Virii/malware) |
| completemadness |
| Find More Posts by completemadness |
#8 |
I pwn all your storage
Most anti virus' on linux are there to stop Windows virus' being spread.
#9 |
Hypermodder
XP is horrible on the CPU's you usually find in these tiny laptops...
#10 |
6 screens / 1 card
I've seen too many people click [OK] on a pop-up just to make it go away then act surprised when they get infected.
There is no such thing as idiot proof - there is only idiot resistant but never underestimate the power of a determined idiot.Back on topic I'm suspecting MS is frantically working on a lighter version of Vista for these. I think one of their biggest fears is large numbers of people adopting an OS they don't control.
__________________
It's not about how life treats you, it's about how you treat life. |
#11 |
Licenced Fool
They'd have to cut a load of the bloat out of XP to run it smoothly on something running what could be considered low spec machines (probably better than at least one of my box's though), whereas a basic Linux install seems to be considerably lighter on resources. As for virus's and Linux, I'm by no means an ubergeek but my Linux box is up to date OS wise and only has basic protection for the net, iptables and clamav .. touch wood, not had one yet. It's used daily but nowhere as near as much as the XP pc is used.
#12 |
YEAH SWEET LEMONADE
^lol
iirc, isn't the OS partion on the Eee Read only to prevent this kind of thing from happening?
__________________
You just lost the game. |
| mr00Awesome |
| Find More Posts by mr00Awesome |
#13 | |
When did I get a custom title!?!
XP is a decent ish os for gaming and is the only OS where I can run Alteras FPGA software (they charge $$$$$$ for the linux versions). Wouldn't touch vista with a bargepole... WINE is faster in many cases than that bloated POS. As for the small laptops I would duel boot personaly as I need some windows software, I think a duel boot option would be very good.
__________________
Sn45g game server mod My Electronics Site![]() Hardware: 3400+ Sempr0n, 1GB RAM, 1.28TB local storage, x1950pro,Razer Viper,M$ comfort curve 2000,L70S + 17", Fujitsu 17" CRT Audio: HD-650's, PE congress amp, Sound Blaster AWE64, Soundblaster 24bit Last edited by Kipman725; 26th Mar 2008 at 22:07. |
#14 |
Madeira's banana is the best!!!
that is what people were saying when XP came out......
__________________
Renegade X - 0.40 Release! <---- CLICK! Last edited by DXR_13KE; 27th Mar 2008 at 01:10. |
#15 |
Supermodder
That is, at best, a matter of opinion. There aren't really that many competent software engineers working on the critical bits at any one time - very likely fewer real contributors than a commercial package. What you're saying is the ideal, and peer review is always a good idea, but I'm concerned that the practical benefits are being overstated here. The real problem, I think, is that the Linux security model is actually almost completely untried in the end-user desktop and laptop environments because until very very recently, it simply hasn't been used there, in more than the tiniest number of cases. We actually have no really objective idea how well or how poorly it's going to work. I suspect that the issues will come out of people simply not being able to drive Linux properly. I've been hammering keyboards since the ZX Spectrum was hot ****, and I find Linux daunting. Until recently, it's been difficult to find incompetent Linux users because you more or less had to be competent to even get the thing to install. The idea that Linux is in any way easier to use than Vista - or the idea that Linux is in any way easy to use full stop - betrays a misunderstanding of what most computer users are capable of, as well as not a small degree of complete and utter denial. P |
| Phil Rhodes |
| Find More Posts by Phil Rhodes |
#16 |
Supermodder
I would imagine that if there is enough demand for these "light" portable,s that linux is going to get a huge boost, and that MS will put a little more effort into making either making a light version of vista, or more probable, an entirely new os devoted at compact device compatible with vista. I seem to remember windows CE was being used quite a bit back in the day. Perhaps a Vista CE is not far away on the horizon.
__________________
"God loves stupid people, that is why he made so many of them." My best friend at M$ Tech support. |
#17 | |
What owl?
__________________
No boom today, boom tomorrow... there's always a boom tomorrow. |
| steveo_mcg |
| Find More Posts by steveo_mcg |
#18 | |
__________________
Renegade X - 0.40 Release! <---- CLICK! |
| Thread Tools | |
