RSS
Old 27th Mar 2008, 08:20   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Gigabyte iSolo 210
http://www.bit-tech.net/hardware/200...te_isolo_210/1
The Gigabyte iSolo 210 may look dinky and unassuming, but something tells us that there may be some minor miracles going on under the hood. It's time to go hands-on then and do a full review of this ATX chassis!
Tim S is offline   Reply With Quote
Old 27th Mar 2008, 11:32   #2
phuzz
Hypermodder
phuzz's Avatar
phuzz is on a distinguished road
The interior is identical to the Coolermaster Centurion, right down to the compleatly inadequate front ventilation though the front.
Still, it was cheap
phuzz is offline   Reply With Quote
Old 27th Mar 2008, 12:11   #3
Flibblebot
Free from artificial flavourings
Flibblebot's Avatar
Flibblebot has a spectacular aura aboutFlibblebot has a spectacular aura aboutFlibblebot has a spectacular aura about
Joe, sometimes I wonder about the state of your mind after reading some of your metaphors
Isn't the reason for having mesh over the window rather than acrylic so that it'll pass FCA EM emissions rules? With the mesh, the case is still a Faraday cage; without it, it isn't.
Or am I talking out of my nether regions?
Anyway, since my PC sits under my desk, I'd rather cases came with the option not to have a window at all.
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse
Flibblebot is offline   Reply With Quote
Old 27th Mar 2008, 13:15   #4
Tile
Banned
Tile is on a distinguished road
Deleted
Tile is offline   Reply With Quote
Old 27th Mar 2008, 16:18   #5
Jojii
hardware freak
Jojii's Avatar
Jojii is on a distinguished road
This was one of the more entertaining articles I've read recently.
As far as the Faraday cage goes, I thought that the plastic drive bay covers thwarted that. I don't know if there would be any benefit for operating a computer in such a cage anyways.
Jojii is offline   Reply With Quote
Old 27th Mar 2008, 16:38   #6
Mankz
ITS OVER 8000!
Mankz's Avatar
Mankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud ofMankz has much to be proud of
I'd rather have a Coolermaster 590 tbh.
__________________
Sponsored By...: HWLabs SpecialTech Feser 1
Originally Posted by DaveVader View Post
Sig'd!
Mankz is offline   Reply With Quote
Old 27th Mar 2008, 17:47   #7
Flibblebot
Flibblebot's Avatar
Yes, but unused drive bays usually have that bit of metal behind them that takes about half an hour to remove and results in shredded hands.
The whole thing of computers in a Faraday cage is to minimise EM emissions & interference, which I believe is part of FCC regulations (amongst others). But I might be wrong.
__________________
Old 27th Mar 2008, 18:04   #8
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
It is - it's why you also get an EMI shield with every motherboard.
Bindibadgi is offline   Reply With Quote
Old 27th Mar 2008, 21:51   #9
ChiperSoft
Minimodder
ChiperSoft is on a distinguished road
I used this case for two gaming rigs I built for my girlfriend and her mother. For the most part I love the case, but there were a few issues I had with it.
1) Both case fans run off the same power lead, so you can't have independent controls for both.
2) I would have like more openings on the motherboard tray for cable routing.
3) The front power light is bright. I mean, REALLY bright, and it takes it's power from a molex connector instead of the power LED pin-out on the motherboard. Not really a problem, but slightly annoying.
Otherwise, I loved the case. It's very sturdy (albeit, a little heavy), easy to work with, and I actually found the case to be quite silent.
ChiperSoft is offline   Reply With Quote
Old 28th Mar 2008, 02:53   #10
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin will become famous soon enough
Oh boy, another case on that chassis. I somehow think Gigabyte must have bought a farm of them, but really, they need to start slinging out some new products - after all, Coolermaster moved to either innovate, or purchase for the 690, and daaaymn, though it shows signs of being an $80 case (top panel is difficult to remove, after it's removed, the little chrome bars don't line up, poor rear fan mounting system, the top hole is a little far over, difficult to remove front panel...) it's really become close to my heart - enough room behind the tray to hold most wires, a 5 hdd cage that now has custom wiring, and TONS of room around where I need to be, (bottom of the case, the PSU can install in either orientation, motherboard cpu/ram area...)... anyway - it's proof of where innovating pays.
__________________
Desky
E8400 @ 4.0 1.42v; P5K-E WiFi; 4x1 Kingmax Mars 1066 @ 1129 CAS 5; 2x [TOO CHEAP TO SPONSOR] 4850 @ 675/1050; Enermax Liberty; WCing in a CM690
Tulatin is offline   Reply With Quote
Old 29th Mar 2008, 05:35   #11
Spaceraver
Weekend Junkie
Spaceraver's Avatar
Spaceraver is on a distinguished road
Looks a little meh. Is it possible to add weight and material to the intro along with the price? That way i know if i even have to read the article,
__________________
"Faith: not *wanting* to know what is true." - Friedrich Nietzsche. "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." - Seneca
Last thing I remember, I was drinking this glowing green sh*t out of a test tube and dancing like a b*stard.
Spaceraver is offline   Reply With Quote
Old 1st Aug 2008, 05:14   #12
tonschk
Modder
tonschk's Avatar
tonschk is on a distinguished road
+1 ...I agree
tonschk is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
