Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 28th Mar 2008, 15:38   #1
Hg
The game known as life
Hg's Avatar
Hg is a hoopy frood who really knows where their towel is.Hg is a hoopy frood who really knows where their towel is.Hg is a hoopy frood who really knows where their towel is.Hg is a hoopy frood who really knows where their towel is.Hg is a hoopy frood who really knows where their towel is.Hg is a hoopy frood who really knows where their towel is.Hg is a hoopy frood who really knows where their towel is.Hg is a hoopy frood who really knows where their towel is.Hg is a hoopy frood who really knows where their towel is.Hg is a hoopy frood who really knows where their towel is.Hg is a hoopy frood who really knows where their towel is.
CPU Backplate question?
Hi guys,
Doing a new build and im installing a water cooling kit and it comes with a backplate needed for the Intel cpu.
I have fitted it to the back of the mb, but im a bit concerned that it may short the board between the backplate and the Case?
Is this this case? should i try putting something in between the two?
The water cooling kit is a Gigabtye Galaxy 2 and the mb is a xfx 790i in a coolermaster cosmos case.
Any help?
Hg is offline   Reply With Quote
Old 29th Mar 2008, 19:25   #2
500mph
The Right man in the Wrong place
500mph's Avatar
500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel
If you can get a real thin sheet of plastic, you should be able to place it in between the case and backplate.
Just tape/glue the piece of plastic to the backplate.
__________________
Rocketfeesh Emergen-C!
[Web][Twitter][Steam]
500mph is offline   Reply With Quote
Old 29th Mar 2008, 19:47   #3
chrisb2e9
Dont do that...
chrisb2e9's Avatar
chrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysischrisb2e9 can run Crysis
electrical tape should work.
chrisb2e9 is offline   Reply With Quote
Reply
Tags
cooling
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
