Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 2nd Apr 2008, 08:54   #1
Xtrafresh
It never hurts to help
Xtrafresh's Avatar
Xtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run Crysis
Spec check: which low-end GPU should i use?
I'm building a PC for a friend. He's gunna use it as a workstation, for various tasks, but nothing heavy. He's not a gamer, so the GPU doesn't need to pump out mad HDR effects at 4xAA 16xAF or anything. That pretty much makes all the benchmarks on this site useless for this purpose (sorry Tim).
There's two demands that te GPU must meet:
1) it needs to be futureproof. He wants to use this computer at least 5-6 years, preferrably 10 with ome upgrades.
2) it is going to drive a 24" monitor.
Now comes the big question... what GPU should i stick in there?
The budget is 1000 euro, but 350 of that is sucked up by the monitor.
here's the specs i have so far:
Code:
Monitor:   TFT 24" Acer P241WD                              € 352,57
System:    ASUS P5K-V (iG33 - S775)                          € 91,39
           INTEL Core2Duo E4500 (S775 - 800MHz - 2x1 MB)2,2 € 108,12
           Arctic Freezer 7 Pro (Socket 775)                 € 19,16
           PC2-6400 - 1 GBx2 - DDR2 - OCZ ATI XTC 2K C4      € 54,05
           Western Digital 500 GB 5000AAKS (SATA300 - 16MB)  € 85,00
Generic:   Cooler Master Centurion 532 (Zonder voeding)      € 69,13
           500 Watt PSU - OCZ StealthXStream Silent          € 56,10
           DVD±RW Asus DRW-1814BLT SATA - Retail - Zwart     € 32,65
Total:                                                    €   868,18
Here's a list of the graphics cards i could put in there:
Code:
MSI RX3850 - 512 MB - PCIe - TV+2xDVI               € 147,95
MSI RX3650 - 512 MB DDR3 - PCIe - TV+2xDVI           € 83,69
Asus EAH3650 Silent/HTDI - 512 MB- PCIe - TV+2xDVI   € 81,98
MSI RX2600 XT Silent - 256 MB - PCIe - TV+2xDVI      € 86,08
Asus EAH2600 XT/HTDP - 256 MB - PCIe - TV+2xDVI      € 69,97
Sapphire HD 2600 Pro - 512 MB - PCIe - TV+2xDVI      € 61,18
Hey, what can i do, he's an ATI fanboi
I'm worried the 3850 is overkill, but i'm also totally oblivious of how well the other cards would be able to drive a 1920x1200 dektop for the coming 5-6 years. Again, all it needs to do is mild desktop tasks. This PC will never ever be used for games. (such a waste )
If the lower budget cards on the above list work, i could upgrade the CPU and/or RAM to further futureproof the PC.
Note: he has an XP license atm. He's not so snappy about uprading to Vista yet, but he will eventually, so the hardware needs to be capable, but i don't need to buy the license.
Aside from the RAM i think this PC is pretty future proofed. RAM, CPU and GPU can be upgraded easily and cheaply on this mobo (potential crossfire).
My two questions:
1) which GPU should i put in there?
2) Am i making any mistakes?
__________________
Think of how stupid the average person is, and realize half of them are stupider than that.
- George Carlin
Xtrafresh is offline   Reply With Quote
Old 2nd Apr 2008, 09:56   #2
Realiks
Multimodder
Realiks's Avatar
Realiks has yet to learn the way of the Dremel
I was planning to take the same motherboard and cpu for my sister computer.
So the motherboard is a good chose
Why do you take a new cpu cooler the E4500 cpu hase a stock cooler he's not planning to overclock so I dont see why.
The Ram and hard disk are nice and a good chose. Maby you can take 3gig ram then he's ready for Vista.
The vga is a bit difficult. I personly would take the MSI RX3650 Its not extremly overkill and its not cheapendo
__________________
Post your case in progress on www.casemodproject.be
Realiks is offline   Reply With Quote
Old 2nd Apr 2008, 10:08   #3
Xtrafresh
Xtrafresh's Avatar
Two reasons for the cooler:
1: I plan to make this PC as silent as i can get it. The Freezeris still pretty excellent when youtake the fan off, using it as a passive cooler.
2: cheapest upgrade scheme ever: click the fan in place, bump the clock on the e4500, done.
__________________
- George Carlin
Old 2nd Apr 2008, 10:20   #4
Realiks
Multimodder
Realiks's Avatar
ach I see. Jup the freezers are pretty still.
__________________
Old 2nd Apr 2008, 12:55   #5
Xtrafresh
Xtrafresh's Avatar
Freezer cheesecake
Any other suggestions anyone? I'm going to order tomorrow i think...
__________________
- George Carlin
Old 2nd Apr 2008, 14:35   #6
oasked
Stuck in the Mud
oasked's Avatar
oasked can run Crysisoasked can run Crysisoasked can run Crysisoasked can run Crysisoasked can run Crysisoasked can run Crysisoasked can run Crysisoasked can run Crysis
1Gb of RAM isn't particularly future proof. If you can find one 2Gb stick of DDR2 that would be better I would think.
__________________
Intel i7 920 @ Stock | 6GB Corsair DDR3 | Gigabyte GA-EX58-UD5 | WD6401 AALS
Zotac GeForce 560Ti | Lian-Li PC65 | Enermax 600W SLI | Dell 2408WFP
oasked is offline   Reply With Quote
Old 2nd Apr 2008, 15:02   #7
mm vr
The cheesecake is a lie
mm vr's Avatar
mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!
Even actually 4GB (just to future proof ) wouldn't be overkill IMO. That stuff is cheap nowadays.
Even tho XP 32-bit cant address the full amount, but when he goes Vista (64-bit) it would be good.
Otherwise it looks good.
mm vr is offline   Reply With Quote
Old 2nd Apr 2008, 15:31   #8
crazybob
Voice of Reason
crazybob's Avatar
crazybob has yet to learn the way of the Dremelcrazybob has yet to learn the way of the Dremel
Out of that list, I think I'd get the HD3650. For the kind of work it's going to be used for, you're not generally going to see a difference between any of those cards (and certainly not enough to justify the high price of the 3850). However, the 3650 uses the least electricity and runs the coolest, and has the most modern and up-to-date features. For that, I think it's probably worth the extra €20 over the cheapest option.
crazybob is offline   Reply With Quote
Old 2nd Apr 2008, 20:13   #9
Xtrafresh
Xtrafresh's Avatar
thanks for that, 3650 it is
and the memory is a 2gb kit. not very clear, but it sais 1 gbx2. With the cheaper GPU i can even afford 2 of those kits, i think i'll do that
__________________
- George Carlin
Old 3rd Apr 2008, 09:04   #10
dazmanultra
What's a Dremel?
dazmanultra has yet to learn the way of the Dremel
I've been very impressed with my ATI 3650 - make sure you get the GDDR3 version over DDR2 though.
dazmanultra is offline   Reply With Quote
Reply
Tags
graphics, graphics card
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
