RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Apr 2008, 09:24   #1
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Ten minute modding
http://www.bit-tech.net/modding/2008...nute_modding/1
Not everyone has days upon days of time to pour into a case mod. However, that doesn't mean that the quick builds need to look like a wire explosion on the inside and boring black on the outside! Years of modding have made companies develop some great products that make formerly huge projects into ten minute mods.
Bindibadgi is offline   Reply With Quote
Old 3rd Apr 2008, 10:00   #2
badders
Neuken in de Keuken
badders's Avatar
badders is just really nicebadders is just really nicebadders is just really nicebadders is just really nicebadders is just really nice
Right, that's it - I'm taking my side panel off tonight, sanding the paint off, and cutting a big hole in the side ready for me to find some plexi to Araldite in.
__________________
Have You been Drinking?!?!?
Why, yes I have! Thankyou!
badders is offline   Reply With Quote
Old 3rd Apr 2008, 10:22   #3
Juppun
Run Sackboy Run!
Juppun's Avatar
Juppun is on a distinguished road
Nice article, I think I might pick up one of those internal HDD enclosures to shut up my Raptor once and for all.
__________________
Workstation: Mac Pro [ 2*3.2Ghz, 8GB, 3TB, 8800GT ] SR80i.
Rig: Antec P182 [ P5N32-E SLi, Q6600 G0, HX620W, 4GB, Raptor X, 8800GTX OC ACS3, 8600GT, X-Fi XtremeMusic ] Z-5500.
Flickr| PSN/XBL: OrcaGT
Juppun is offline   Reply With Quote
Old 3rd Apr 2008, 13:29   #4
Blademrk
Why so serious?
Blademrk's Avatar
Blademrk has a spectacular aura aboutBlademrk has a spectacular aura about
I like the idea of EL SATA cables.
__________________
The Bit-Tech.net X-Box Live! Leaderboard
My X-Box Live & X-Fire GamerTag: BladeMRK
WII#: 0379 8536 3210 2060
My Flikr albums
Twitter
Blademrk is offline   Reply With Quote
Old 3rd Apr 2008, 13:35   #5
MrWillyWonka
Moderator
MrWillyWonka's Avatar
MrWillyWonka will become famous soon enough
Never knew about EL sata cables and two-way mirrors (I did know about it but never thought of using it). Is it possible to use EL wire on a two way mirror or is that silly?
Nice article Bindi Da Dego
__________________
Project Red - HL2 - PSOne LCD S-Video Guide
Main Rig: Asus Striker Extreme, Intel Core 2 Quad Q6600 G0 OC'd to 2.65GHz, 4GB Corsair XMS, 8800GTS in SLI, 36 & 74GB Raptors
MrWillyWonka is offline   Reply With Quote
Old 3rd Apr 2008, 14:04   #6
Da Dego
Brett Thomas
Da Dego's Avatar
Da Dego is on a distinguished road
Nice article Bindi
Hey now, bindi doesn't do the modding :P I do And thanks.
As for the 2 way mirror - to be honest, I never thought about that. I think I have some mirror plexi hanging around, and I know I have an EL kit somewhere round here... might have to give it a try and report back to you!
__________________
"Frankly that seems overkill. iluvtrees2 arguing with spec is the intellectual equivalent of a bunny rabbit taking on a pissed-off lion." - Nexxo
Da Dego is offline   Reply With Quote
Old 3rd Apr 2008, 14:17   #7
MrWillyWonka
Moderator
Shoudl've checked the author, corrected Would be nice to know about the EL wire + two way mirror. My mod could do with an upgrade after... wow 27 months now!
__________________
Old 3rd Apr 2008, 14:32   #8
wuyanxu
quad fuelled, GTX200 powered
wuyanxu's Avatar
wuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura about
£20 for some foam..... or use some egg container? how well do they work with my p182 case?
another question: my Antec pro (not TriCool, the ones have 3pin mobo connector) fan will resonate at a certain RPM.... eg, at 1200rpm, very quiet; at 1500rpm, resonates, very annoying; at 1700rpm, quiet enough. now grommets probably won't cure this, any way of changing the fan's property to make it quiet at all rpm?
just this morning, i re-did all my cables, now is a bit nicer. well said in your article on cable management issues.
the issue about data cable and power cables: i run all my SATA cable through the back of my mobo tray, on p182, together with all the power cables (including 24pin, 2* PCIe cables). should i be alerted?
__________________
Death to consolification !!!
Core i7 860 @ 4Ghz Cooled by Corsair H50 // Asus P7P55D Deluxe // 8GB of Corsair Dominators @ 1528Mhz 8-8-8-24 //
BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240
wuyanxu is offline   Reply With Quote
Old 3rd Apr 2008, 14:34   #9
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
No problem, I try my best putting things live!
Old 3rd Apr 2008, 16:32   #10
Nature
Supermodder
Nature's Avatar
Nature is on a distinguished road
I though the quickest way to mod was to have bit-tech send me one!
__________________
Peace, Love, Empathy, Respect, Generosity, Smiles, and Hugs
Nature is offline   Reply With Quote
Old 3rd Apr 2008, 16:57   #11
wharrad
Hypermodder
wharrad's Avatar
wharrad is on a distinguished road
That two way mirror looks finally like a cheap solution for a DIY HUD in the car.... Must investigate! Cheers guys
__________________
Jimmy Carr - "It's easier to get forgiveness than permission"
wharrad is offline   Reply With Quote
Old 3rd Apr 2008, 17:03   #12
MrWillyWonka
Moderator
I want piccies!
__________________
Old 3rd Apr 2008, 18:09   #13
Cheapskate
know-it-all b*stard...
Cheapskate's Avatar
Cheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud of
Skip the HUD. Go for a targeting sight.
Cheapskate is offline   Reply With Quote
Old 3rd Apr 2008, 20:53   #14
brinkz0r
Supermodder? Well tnx :)
brinkz0r's Avatar
brinkz0r is on a distinguished road
No ten minute modding for me, I only do ten hour modding
__________________
My finished casemod: Cubeleon
Find out what's in my avatar: Phase 2 Casemodding
brinkz0r is offline   Reply With Quote
Old 3rd Apr 2008, 22:48   #15
The_Beast
I *am* The Stig
The_Beast's Avatar
The_Beast is a jewel in the roughThe_Beast is a jewel in the roughThe_Beast is a jewel in the rough
nice article
__________________
Rendering Machine - Gigabyte DS3L P35 - C2Q Q6600 - Antec New Solution Series NSK4480B - Corsair XMS2 2Gb - Sapphire 2600 XT 256mb - Seagate 'Cuda 320 GB - Antec Earthwatt 430 watt - Windows XP Pro -
The_Beast is online now   Reply With Quote
Old 4th Apr 2008, 15:13   #16
Stuey
You will be defenestrated!
Stuey's Avatar
Stuey will become famous soon enough
Great article! The new Feser tubing sounds interesting, although it looks a bit costly.
__________________
ToolGuyd
Stuey is offline   Reply With Quote
Old 4th Apr 2008, 23:18   #17
Shadowed_fury
Natural Born Chaos
Shadowed_fury's Avatar
Shadowed_fury is on a distinguished road
I did the two way mirror on previous case I had, its pretty cool actually
I really need to get round sorting the window on this one...
__________________
Steam: kev_fury New Frag Video
- Gigabyte EP43-DS3L - E8200 - XFX 4870 1GB - 4GB Kingston -
- Steel Series 7.1s - Logitech G11 - Razer Diamondback 3G - 2209WA -
Shadowed_fury is offline   Reply With Quote
Old 5th Apr 2008, 07:58   #18
1398342003
Ubermodder
1398342003's Avatar
1398342003 is on a distinguished road
I've seen the same "concept" of moving the drives to more spacious environs with a rather creative adaptation - rubber bands and sticks. The rubber bands are threaded through the screw holes on the drive bay and sticks keep them stretched. The hard drive is then tucked in between the rubber bands, to be hopefully held fast and completely dampened from the case.
If it's a drive you need, please don't do this. I think that's all I have to say about that.
This is actually done fairly regularly at SPCR, and it's quite reliable. (according to them) They use elastic cords though. Here's a link to their forum gallery.
__________________
Boss: Wireless ethernets are faster because the radio waves the signals are sent over travel at the speed of light.
1398342003 is offline   Reply With Quote
Old 9th Apr 2008, 13:25   #19
mnpctech
I *am* a Dremel
mnpctech's Avatar
mnpctech is a jewel in the roughmnpctech is a jewel in the roughmnpctech is a jewel in the rough
Thank you for the mention!
Mnpctech is a small mom and pop online shop that strives to offer unique parts and enjoys supporting modding throughout the enitre community.
Bill Owen
Owner of mnpctech,com
__________________
mnpctech.com (web's most unique case mod parts, international orders welcome!)
My Case Mods: NVIDIA ION Cube / Bio-Mechanical Khaos / AMD Corporation / HD 100 / CPU Stingray / The Wall
mnpctech is offline   Reply With Quote
Old 9th Apr 2008, 13:55   #20
wharrad
Hypermodder
wharrad's Avatar
Yeah, from my understanding the rubber bands break under prolonged exposure to heat and vibration... Elastic however doesn't. But like going outside of the norm on anything, just be careful and check on your work often.
And yeah, good to see people who work in the modding industry on here Now I know where to complain (errr... I mean... well, they're more likey to get my cash in the first place! )
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
