Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 4th Apr 2008, 00:26   #1
ashchap
Multimodder
ashchap can run Crysisashchap can run Crysisashchap can run Crysisashchap can run Crysisashchap can run Crysisashchap can run Crysisashchap can run Crysisashchap can run Crysis
Hard Drive Enclosures
after reading the Ten Minute Modding article I now want to buy a hard drive enclosure or two to shut up my drives. I have a WD1600JB (western digital 160GB) IDE and a WD3200JS (western digital 320GB) SATA and when my fans are throttled down they are pretty much the noisiest part of my system.
It would also be nice to cool them down a bit, but my main priority is to silence them.
can you guys recommend any particular enclosures, and do you know where I can buy them (either in the UK or shipped here)?
Thanks
ashchap
ashchap is offline   Reply With Quote
Old 4th Apr 2008, 01:28   #2
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
Look at the AluBox enclosures from A.C. Ryan. I have a Duo and the fan is quite quiet. The quality is excellent and the prices are really in-line with other enclosures. http://www.acryan.com/ and look under Pro Data section.
John
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 4th Apr 2008, 02:57   #3
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpitGoodBytes is almost as Godly as yodasarmpit
If your hard drives are all inside your case....
I have the Antec Solo case, it has sound damping material on each panels on on the top of the case.
Perhaps purchasing such inexpensive material will help diminish fan and hard drive noise.
Moreover, my case has the option to attach the hard drive with elastic/material bands so that hard drive floats, so when it vibrate it you don't hear it. It works very well, waaayy better than nothing, and better than using the silicon screws type of thing. I suggest maybe a possible case mode to make it possible. Specially that I don't think it cost much.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features.
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 4th Apr 2008, 11:32   #4
ashchap
Multimodder
yeah, I looked at some of the AC ryan stuff and it looks good, but I cant find anywhere to buy it in the uk...
as far as elastic bands go, that might work but I move my case around a lot going back and forth between home and uni so I doubt they would hold up too well in transit
Old 4th Apr 2008, 13:12   #5
skpstr
Multimodder
skpstr's Avatar
skpstr can run Crysisskpstr can run Crysisskpstr can run Crysisskpstr can run Crysisskpstr can run Crysisskpstr can run Crysisskpstr can run Crysisskpstr can run Crysisskpstr can run Crysis
Have a look at quietpc (www.quietpc.co.uk) they have various HDD silencing products that might be what you're after.
skpstr is offline   Reply With Quote
Old 5th Apr 2008, 14:42   #6
Hazardous
Mod Master
Hazardous's Avatar
Hazardous has yet to learn the way of the Dremel
A number of online stores sell 'em!
Two that I know of off the top of my head, are SpecialTech and Kustom PCs
__________________
Beauty is in the eye of the beer-holder
Hazardous is offline   Reply With Quote
Old 5th Apr 2008, 14:48   #7
Matticus
Matticus's Avatar
Matticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpitMatticus is almost as Godly as yodasarmpit
I too am looking at some internal (edit: I assume you are after an internal solution) hard drive sound proofing/cooling solutions.
As most of the noise from harddrives is just vibrations something like
this http://www.specialtech.co.uk/spshop/...cat=244&page=1
or this http://www.scan.co.uk/Products/Produ...oductID=657361
would be an excelent way of quieting them down, obviously the latter does not provide any cooling, but I would say most hard drives do not need any extra coolig if they are mounted internally as the natural flow of the case should insure they dont sit in a hot pocket of air. Plus my case has meshed 5 1/4bay covers so air will get drawn in through them.
Matticus is offline   Reply With Quote
Old 5th Apr 2008, 14:53   #8
Matticus
Matticus's Avatar
Also I just saw this http://forums.bit-tech.net/showthread.php?p=1702986.
Old 8th Apr 2008, 22:35   #9
ashchap
Multimodder
thanks for the input guys, I've decided to take the cheap option and see how it goes - I've ordered the rubber mountings (http://www.scan.co.uk/Products/Produ...oductID=657361), cant really go wrong for a fiver
Reply
Tags
cooling
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
