Reply
Thread Tools View Mode
Old 11th Apr 2008, 14:54   #61
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
I got the big grommets (ones used for the radiator pass through and reservoir pass through) from my local hardware store. They come packaged as a pair and are labeled as cable grommets. They fit snugly around the tubing I am using. The smaller grommets I got from Jaycar (the equivalent of your Radio Shack) and came in packs of 10.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 11th Apr 2008, 15:07   #62
Thacrudd
Where's the any key?!?
Thacrudd's Avatar
Thacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run Crysis
Thanks, you just solved a small problem I had!
__________________
Just as you touch the lives of every life form you meet, so, too, will their energy strengthen you. Fail to live up to your potential, and you will never win... - Gaspar, The Guru of Time
Project: Andromeda
CurseMyStuff.com
Thacrudd is offline   Reply With Quote
Old 11th Apr 2008, 15:23   #63
The boy 4rm oz
Project: Elegant-Li
No problem. Glad I could help.
__________________
Old 13th Apr 2008, 09:19   #64
The boy 4rm oz
Project: Elegant-Li
Time for another update.
Today I got stuck into mounting my radiator.
Here I where the radiator will be mounted, all taped up and ready to go:
HDD racks removed:
Plenty of room for the radiator:
I traced an outline of the radiator to help with the mounting:
All marked for cutting:
All the useless lines removed, only the cuts left:
All cut out:
And a shot with the radiator where it should be:
However, I made one mistake. Take a look at the last pic. I cut the width too wide. I measured from the outside of the radiator rather than the inside. It still fits but there is a tiny gap either side now. One I put the fan hole molding on the cut it should be just fine. Well that's it for now, may have some more towards the end of the week. Until then...
Happy Modding.
__________________
Old 13th Apr 2008, 12:32   #65
ModimusPrime
The Dremelator
ModimusPrime has yet to learn the way of the Dremel
Looking really good. The contrast in the yellow and black will look awesome once all the plexi lights up. Will keep an eye out for the finished result. Keep it up.
ModimusPrime is offline   Reply With Quote
Old 13th Apr 2008, 12:54   #66
The boy 4rm oz
Project: Elegant-Li
Thanks mate. I am a bit pissed off about that gap on that radiator though. I guess it just learnt my lesson...measure twice, cut once. It will look fine painted up though.
__________________
Old 25th Apr 2008, 05:50   #67
The boy 4rm oz
Project: Elegant-Li
Sorry for the lack of updates guys. I was away all last week and half of this week and to top it all off the house is being painted, not much time for modding. Any way I did manage to get some work on the case feet and spacers done before I went away and finished them today.
On to the pictures.
Ok so I went out and got myself some more bolts and domed nuts:
I also got myself a pair of small clamps:
They are perfect for what I need them for.
I clamped the mesh to the plexi spacers and then through the holes I drilled in the spacers I drilled identical holes in the mesh:
All drilled:
The plexi attached to the mesh with the domed nuts and bolts I brought:
Ok so that's the stuff I did before I went away last week. Now here is what I did today.
The Spacers are FINISHED!!!
All 4 feet with spacers in all their glory:
A close up of the completed case foot:
A pic of the mounting bolts:
Sorry I don't have pics of working towards the finished product but I can run you through it. Basically I just filed down the overhanging mesh while it was still attached to the spacers. Then I removed the protective tape from the spacers and taped off each end. I then painted the center stem of the spacer. Then I removed the protective plastic film from the mesh and bolted it to the spacer followed by the case foot. Quite boring steps, I know you guys like the eye candy lol .
I have also found a way around the gap I made while cutting the hole for my radiator. I will be using 2 mesh strips to cover the gap from the underside. These will be painted black to fit in with the rest of the case. Well that's all I have for now. The last few days of my holidays will be dedicated towards my homework so don't expect another update this week. Until then...
Happy Modding.
__________________
Old 27th Apr 2008, 14:54   #68
m0o0oeh
Tech noob. I know.
m0o0oeh's Avatar
m0o0oeh has yet to learn the way of the Dremelm0o0oeh has yet to learn the way of the Dremelm0o0oeh has yet to learn the way of the Dremelm0o0oeh has yet to learn the way of the Dremelm0o0oeh has yet to learn the way of the Dremelm0o0oeh has yet to learn the way of the Dremelm0o0oeh has yet to learn the way of the Dremelm0o0oeh has yet to learn the way of the Dremel
Nicely done! Watching with interest!
Joe
__________________
Moriquendi: Indeed, resistance is Relix as they say.
Silver51: A fizzy can of sudo?
Mac Quiksilver 733, 768 SDRAM, NVidia GeForce 2MX 32 Mb RAM. "Dr. Horrible"
Acer Aspire One A150, 1.66 Intel Atom, 1 gig DDR2 RAM. "Captain Hammer"
m0o0oeh is offline   Reply With Quote
Old 27th Apr 2008, 17:36   #69
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.
Oh, wow! I almost bought the same handles the other day. I would have... The price sign said 'stainless steel', but they only had nickel plate. Nice baseplates. It's a shame they won't be very visible.
Cheapskate is offline   Reply With Quote
Old 30th Apr 2008, 08:39   #70
The boy 4rm oz
Project: Elegant-Li
Thanks for your interest guys. I haven't been on lately cos we have been painting the house. My PC has been out of commission lol.
__________________
Old 30th Apr 2008, 08:43   #71
b4i7
modding dreams into reality
b4i7 has yet to learn the way of the Dremel
ah ive been wonderin where you disappeared to... the feet look great!
b4i7 is offline   Reply With Quote
Old 30th Apr 2008, 09:20   #72
The boy 4rm oz
Project: Elegant-Li
Thanks mate. I am going to see if I can mount them this weekend.
__________________
Old 9th May 2008, 15:42   #73
dia2777
Minimodder
dia2777's Avatar
dia2777 has yet to learn the way of the Dremel
Yuo gave me a tons of good ideas!
Really good job, I like the mesh/plaxy effect, and, by the way, the rubber grommets looks so cool in this case!
Keep on mod, mate!
__________________
My current project : Glacial was in the MOM April 08 !
dia2777 is offline   Reply With Quote
Old 9th May 2008, 16:05   #74
The boy 4rm oz
Project: Elegant-Li
Thanks mate. Those comments mean a lot coming from someone with your skills. Yeah I like the grommets too. I used them originally to protect the tubing from the rough mesh cuts but it turned out looking awesome.
I will have an update in the afternoon (it's 1.30am here at the moment ).
__________________
Old 9th May 2008, 16:11   #75
Jokkocze
Hypermodder
Jokkocze's Avatar
Jokkocze has yet to learn the way of the Dremel
This might be really intresting.. *Subscribes*
__________________
Main rig: Intel C2D E8400 @ 3.91ghz | 6GB Corsair Dominator | EVGA GTX 280 SSC | ASUS P5E | 1x150gb Raptor & 3tb storage | 550w Corsair PSU | 2x Samsung T220
HTPC: Intel C2D E8400 | 2GB Corsair XMS | XFX 8800GT 512mb (Passive) | ASUS P5Q-VM | 4x1.5TB | 550w Corsair PSU | Sony 46V4500
Jokkocze is offline   Reply With Quote
Old 9th May 2008, 16:42   #76
ModimusPrime
The Dremelator
Progressing well mate, though the u-channel around the mesh isn't working for me. Besides the edges looked nice and straight, I don't see the need for them.
__________________
Current Mod: L3 - "Liquid Lan-Li"
http://forums.bit-tech.net/showthread.php?t=150023
Old 10th May 2008, 00:02   #77
MrWizard
Supermodder
MrWizard's Avatar
MrWizard has yet to learn the way of the Dremel
Very nice idea for the feet, they turned out really clean. I was hoping this LEXA project would re-surface
__________________
Gigabyte P35-DS3L | Intel E2220 @ 3.0GHz | AC Freezer 7 Pro | eVGA 8800GT 512MB | 2GB Crucial Ballistix DDR2-800 | 1 x Seagate 250GB SATA | 1 x WD Raptor 74GB SATA | X-Fi Extreme Gamer | Silverstone Strider 600 Modular | Modded Antec Nine Hundred
MrWizard is offline   Reply With Quote
Old 10th May 2008, 00:37   #78
The boy 4rm oz
Project: Elegant-Li
I will take some pics without the U channel on the mesh. I thought it just made it look a bit cleaner, the mesh is straight it just looks rough when you look at it through the window.
Thanks for your comments guys. It means a lot.
__________________
Old 10th May 2008, 06:13   #79
The boy 4rm oz
Project: Elegant-Li
Well guess what guys??? UPDATE TIME!!!
I finally got my case feet mounted so here are some pics.
First I masked off the area and marked the holes for drilling:
Holes drilled:
After that it was a simple matter of cutting the mounting bolts down to size and then mounting the completed feet:
Time for the money shots:
Yes it does look awesome (applause lol) but there are still a few problems with them. The feet cover up some rivet holes so I will have to counter sink a hole under some spots on the feet to allow the rivet to fit.
Example:
You can see in the pic the rivet hole in the center of the green part of the spacer.
Another problem (which I already knew about) are the spacers themselves. Yes they did bring the height of the case closer to stock height but they are still about 2-3mm too short.
Example:
You can see the difference in the image above.
I am thinking of adding 1 or 2 washers in between the mesh and the handle (foot) to add the desired height (I think this may look quite good). The other option in cutting the difference off the front fascia itself which I don't want to do.
ModimusPrime here is a pic of part of the mesh without the U channel on it, personally I think it looks better with it on. What do you guys think???
Pic:
Well that's all I have for now. I have got a small order which is almost complete for me to pick up which will allow me to finish mounting the radiator. Until then...
Happy Modding.
__________________
Old 11th May 2008, 16:44   #80
dia2777
Minimodder
dia2777's Avatar
U Channel rulez!
I hate to see the grill without the u-channel, my two cents :-)
__________________
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
